AVRCK 3.0: Reducing Inference Cost by Routing Causal Gaps Across Local and Cloud Models
I recently read NVIDIA’s article on full-stack inference software and lowering token costs:
NVIDIA is addressing one side of the inference-cost equation:
- Lower cost per token
- Higher throughput
- Better GPU utilization
- Faster inference runtimes
- Improved performance across large-scale and agentic workloads
I have been designing a complementary architecture called AVRCK 3.0 — Answer Vector Responsibility Closure Kernel.
The central idea is simple:
NVIDIA optimizes inference execution.
AVRCK 3.0 is designed to optimize inference necessity.
Current LLM and agent systems often send the entire task into a large model, repeatedly loading context, reconstructing rules, selecting tools, and regenerating reasoning that may already have been established during earlier runs.
AVRCK 3.0 places a causal and failure-condition routing layer between the user request and model execution.
Instead of immediately asking a model to generate an answer, the system first determines:
- What task is actually being requested
- Which rules and signed conditions already exist
- What must be true for the result to be valid
- Which conditions would make the result fail
- Which parts can be handled by deterministic functions
- Which parts can be handled by a local small model
- Which unresolved gaps genuinely require a larger cloud model
- Whether the completed result can be compiled into a reusable local runtime package
The intended execution flow is:
User Request
→ Local Small-Model Precompile
→ Causal and Failure-Condition Extraction
→ Bottleneck Detection
→ Cloud Model for Unresolved Gaps Only
→ Closure Verification
→ Owner Review
→ Compile-Down
→ Signed Local Runtime Package
The local model does not need to solve the entire complex task immediately.
It can first produce:
- A task decomposition
- A base draft
- A causal map
- Validity conditions
- Failure conditions
- Unresolved gaps
When the remaining task exceeds the local model’s reliable capacity, the system creates a compact escalation handoff package containing only the unresolved causal load.
A larger model then processes that limited scope rather than recalculating the entire task and context.
After the result is verified, it is compiled into a reusable structure containing:
- Rules
- Functions
- Variables
- State transitions
- Tool routes
- Tests
- Rollback conditions
- Re-escalation triggers
Future tasks can then run locally using the signed runtime package plus only the new input differences.
The intended cost model is therefore:
Traditional optimization:
Cost per token ↓
AVRCK 3.0 optimization:
Tokens per task ↓
Repeated reasoning passes ↓
Unnecessary large-model calls ↓
Repeated context reconstruction ↓
These two approaches are complementary.
NVIDIA can make each inference call faster and less expensive.
AVRCK 3.0 is designed to reduce how often expensive inference is required and how much of the task must enter the large model in the first place.
I am currently translating this architecture into a local-and-cloud hybrid Chat Runtime that can connect local models, cloud APIs, retrieval systems, and external tools under the same causal, failure-condition, and responsibility layer.
This is currently an architecture and implementation project, not a claim of completed NVIDIA hardware benchmarks. I would be interested in discussing how this approach could be evaluated with NVIDIA inference technologies such as TensorRT-LLM, NIM, Triton, and Blackwell-based deployments.
If this direction is relevant to NVIDIA’s inference software, agentic AI, hybrid AI, or runtime optimization teams, I would be glad to discuss the architecture, implementation plan, and possible benchmarking methodology.
NVIDIA optimizes the inference factory.
AVRCK 3.0 asks which work should never need to re-enter the factory again.
— Wen-Yao Hsu
Founder of SCBKR / AVRCK
Email: ken0963521@gmail.com
