I am working on Windows 7 and using NVIDIA Quadro M4000 device for HEVC Encoding.
I am using ffmpeg 4.2 sdk for NVIDIA HEVC encoding.
I used pix_fmt = AV_PIX_FMT_0RGB32 for encoding the HEVC. It is working fine on my pc.
My problem is when I try add b frame video encoder crashed.
Note:I did not set profile,level,tier.
Should you help me please how can we add b frame in encoder?
Thank You,
Dhrumil Sheth
Hi Dhrumil,
As per “NVENC_Application_Note.pdf” from Video Codec SDK 9.0, HEVC B frame is supported in Turing GPUs (except TU117). B frame HEVC encoding is not expected to work on Quadro M4000. You can query for the B frame support using “NV_ENC_CAPS_NUM_MAX_BFRAMES” and enable the B frame if this value is non zero. This will help you build generic application that runs across GPU generations.
Can you elaborate more on what this crash is? Application should exit gracefully and not crash.
It is a bug if that is not happening.
