Bad performance of cublas for extremely small matrix multiplication?
I’m trying to accelerate a code which does many small matrix (3*3) multiplications. I compared the performance of CPU serial code, CPU OpenMP code, cuBLAS (strided batched gemm), and OpenACC. From the results, I see the worst performance from cuBLAS, which is tens of times slower than the CPU OpenMP version. It’s even slower than the CPU serial version.
For cuBLAS and OpenACC, I only copy the data once to the device and then do multiple iterations of matrix multiplications. For OpenACC I used PGI compiler, but I used Intel compiler for the others. My hardware specifications are, Intel Xeon W-2145 CPU and Quadro P2200 GPU.
Is it normal to see this low performance from cuBLAS for this type of calculations ?
Thanks,
Can you provide reproducer code/snippet?
Hi, here’s the function for cuBLAS,
typedef float mytype;
void GPU_MultiStridedBatch(mytype *M, mytype *N, mytype *P, size_t pr, size_t pc, size_t mc, mytype alpha, mytype beta, int num_mat, int niter)
mytype *devM, *devN, *devP;
size_t p_size =sizeof(mytype) *pr*pc;
size_t m_size =sizeof(mytype) *pr*mc;
size_t n_size =sizeof(mytype) *mc*pc;
cudaMalloc((void**)&devM, m_size*num_mat );
cudaMalloc((void**)&devN, n_size*num_mat );
cudaMalloc((void**)&devP, p_size*num_mat );
cudaMemcpy(devM, M, m_size*num_mat , cudaMemcpyHostToDevice);
cudaMemcpy(devN, N, n_size*num_mat , cudaMemcpyHostToDevice);
cublasHandle_t myhandle;
cublasStatus_t cublas_result;
cublas_result = cublasCreate(&myhandle);
assert(cublas_result == CUBLAS_STATUS_SUCCESS);
for (int i=0; i<niter; i++){
cublas_result = cublasSgemmStridedBatched(myhandle, CUBLAS_OP_N, CUBLAS_OP_N
  , pr, pc, mc
  , &alpha, devM, pr, pr*mc, devN, mc, mc*pc
  , &beta, devP, pr, pr*pc
  , num_mat);
cudaMemcpy(P, devP, p_size*num_mat, cudaMemcpyDeviceToHost);
cudaFree(devM);
cudaFree(devN);
cudaFree(devP);
cublasDestroy(myhandle);
And for the CPU version,
struct element{
mytype m[ROWM][COLM], n[COLM][COLN], p[ROWM][COLN];
int CPU_multi(int num_mat, int niter)
struct element* elms;
elms =new element[num_mat];
for(int i=0; i<num_mat; i++){
	for(int j=0; j<ROWM; j++)
		for(int k=0; k<COLM; k++)
			elms[i].m[j][k] = 3.0f;
	for(int j=0; j<COLM; j++)
		for(int k=0; k<COLN; k++)
			elms[i].n[j][k] = 2.0f;
			elms[i].p[j][k] = 0.0f;
double t1 = omp_get_wtime();
for(int it = 0; it<niter; it++)
	for(int k =0; k<num_mat; k++)
		for(int i=0; i< ROWM; i++){
			for(int j=0; j<COLN; j++){
				elms[k].p[i][j] = 0.0f;
				for(int m=0; m<COLM; m++){
					elms[k].p[i][j] += elms[k].m[i][m] * elms[k].n[m][j];
double t2 = omp_get_wtime();
printf("CPU serial time : %e seconds \n", t2-t1);
delete elms;
return 0;
@mnicely is there any progress on speeding up cuBLAS for small matrices? It has really big inpact on downstream frameworks that use it (e.g. pytorch)
Have you tried using cublasDx? As some point, small matrices become latency/memory bound on larger GPUs.
