Hi folks,
I’m participating in a couple distributed computing projects that run on the BOINC framework. One - Rosetta - is CPU bound and the other - GPUGRID - uses CPU only to keep the GPU busy. This is running on a 4 core AMD system with a GTX 460 adapter. I find that with Rosetta using 4 cores at 100%, the GPUGRID application uses about 2% CPU and drives the GPU at about 10%:
hbarta@olive:~$ top -n 1
top - 11:59:54 up 18:29, 5 users, load average: 5.15, 5.46, 5.40
Tasks: 251 total, 7 running, 244 sleeping, 0 stopped, 0 zombie
Cpu(s): 1.4%us, 0.6%sy, 97.2%ni, 0.5%id, 0.0%wa, 0.1%hi, 0.1%si, 0.0%st
Mem: 4057932k total, 4020360k used, 37572k free, 52612k buffers
Swap: 8000288k total, 20184k used, 7980104k free, 1078336k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
17736 boinc 39 19 447m 441m 400 R 98 11.1 24:18.51 minirosetta_2.1 <<<<<<<<<<
17737 boinc 39 19 440m 433m 624 R 98 10.9 24:20.91 minirosetta_2.1 <<<<<<<<<<
17738 boinc 39 19 453m 445m 304 R 98 11.2 24:25.14 minirosetta_2.1 <<<<<<<<<<
17735 boinc 39 19 437m 430m 368 R 89 10.9 24:13.27 minirosetta_2.1 <<<<<<<<<<
41 root 20 0 0 0 0 S 2 0.0 0:03.56 ata/3
1908 root 20 0 156m 46m 15m S 2 1.2 20:03.41 Xorg
2265 hbarta 20 0 294m 39m 13m S 2 1.0 5:49.05 compiz
2398 hbarta 20 0 299m 25m 14m S 2 0.6 16:20.79 boincmgr
8431 hbarta 20 0 208m 22m 11m S 2 0.6 0:07.46 gnome-terminal
8886 boinc 30 10 166m 90m 32m R 2 2.3 1:54.67 acemd2_6.13_x86 <<<<<<<<<<
13624 hbarta 20 0 537m 92m 32m S 2 2.3 1:30.03 chromium-browse
13967 hbarta 25 5 876m 79m 22m S 2 2.0 1:04.08 chromium-browse
16389 hbarta 25 5 906m 99m 20m S 2 2.5 1:00.22 chromium-browse
18396 hbarta 20 0 862m 66m 26m S 2 1.7 0:17.94 chromium-browse
{zero CPU users deleted}
hbarta@olive:~$ nvidia-smi -a
==============NVSMI LOG==============
Timestamp : Fri Apr 15 12:00:35 2011
Driver Version : 260.19.29
GPU 0:
Product Name : GeForce GTX 460
PCI Device/Vendor ID : e2210de
PCI Location ID : 0:1:0
Board Serial : 650381377
Display : Connected
Temperature : 53 C
Fan Speed : 26%
Utilization
GPU : 8%
Memory : 1%
hbarta@olive:~$
If I suspend Rosetta, the GPUGRID task uses about 8% CPU and keeps the GPU closer to 100%:
top - 12:01:19 up 18:31, 5 users, load average: 5.69, 5.55, 5.44
Tasks: 235 total, 1 running, 234 sleeping, 0 stopped, 0 zombie
Cpu(s): 1.4%us, 0.7%sy, 97.2%ni, 0.5%id, 0.0%wa, 0.1%hi, 0.1%si, 0.0%st
Mem: 4057932k total, 2219820k used, 1838112k free, 48924k buffers
Swap: 8000288k total, 20288k used, 7980000k free, 1074920k cached
8886 boinc 30 10 166m 90m 32m S 8 2.3 1:56.26 acemd2_6.13_x86 <<<<<<<<<<
1908 root 20 0 156m 46m 15m S 6 1.2 20:07.18 Xorg
2265 hbarta 20 0 294m 39m 13m S 2 1.0 5:50.29 compiz
2334 hbarta 20 0 215m 9380 7096 S 2 0.2 2:55.87 multiload-apple
2398 hbarta 20 0 299m 25m 14m S 2 0.6 16:22.21 boincmgr
8431 hbarta 20 0 208m 22m 11m S 2 0.6 0:08.33 gnome-terminal
13624 hbarta 20 0 537m 92m 32m S 2 2.3 1:31.34 chromium-browse
13721 hbarta 20 0 270m 87m 20m S 2 2.2 2:25.03 npviewer.bin
16389 hbarta 25 5 906m 100m 20m S 2 2.5 1:01.81 chromium-browse
20289 hbarta 20 0 19352 1372 928 R 2 0.0 0:00.03 top
Timestamp : Fri Apr 15 12:01:32 2011
GPU 0:
Display : Connected
Temperature : 57 C
Fan Speed : 34%
Utilization
GPU : 91%
Memory : 12%
hbarta@olive:~$
Are there any tweaks I can apply to get the GPUGRID task more CPU w/out sacrificing too much for Rosetta? I know I can configure Rosetta to use only three cores and that will help, but I havte to give up nearly 100% of one core in order to gain the 8% required to feed the GPU. I’ve tried bumping the nice value of the CUDA task but that seems not to help (and it is already less nice than the CPU bound tasks.)
