I executed the bandwidth program in CUDA SDK.
Does the following numbers look right to you ? or they are very small ?
If I should upgrade the computer, then could you recommend model for the motherboard ?
I am using 8800GTX
Quick Mode
Host to Device Bandwidth for Pageable memory
Transfer Size (Bytes) Bandwidth(MB/s)
33554432 1652.5
Quick Mode
Device to Host Bandwidth for Pageable memory
33554432 1331.5
Quick Mode
Device to Device Bandwidth
33554432 63048.0
The notion “Host to Device Bandwidth for Pageable memory” means you’ve ran the test with non-pinned memory (this is the default setting). To get best bandwidth results (and get close to the physical limit of your PCI-E slot), you need to run “bandwidth.exe --memory=pinned”. You will only have 2-2.5gb/s transfer if you use pinned memory.
