After swapping one of my 8800GTX’s for a T10P, I get quite slow memory bandwith for host-device and device-host copies. And also the device-device copies are not as much faster as I expected. Are these expected pre-production effects?
Device 0: “GeForce 8800 GTX”
Major revision number: 1
Minor revision number: 0
Total amount of global memory: 804585472 bytes
Number of multiprocessors: 16
Number of cores: 128
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.35 GHz
Concurrent copy and execution: No
Device 1: “GT200”
Minor revision number: 3
Total amount of global memory: 4294705152 bytes
Number of multiprocessors: 30
Number of cores: 240
Total number of registers available per block: 16384
Warp size: 32
Clock rate: 1.51 GHz
Concurrent copy and execution: Yes
bandwidthTest --device=0
Using device 0: GeForce 8800 GTX
Quick Mode
Host to Device Bandwidth for Pageable memory
Transfer Size (Bytes) Bandwidth(MB/s)
33554432 2000.4
Quick Mode
Device to Host Bandwidth for Pageable memory
33554432 1842.8
Quick Mode
Device to Device Bandwidth
33554432 71468.5
bandwidthTest --memory=pinned --device=0
Quick Mode
Host to Device Bandwidth for Pinned memory
33554432 3151.8
Quick Mode
Device to Host Bandwidth for Pinned memory
33554432 2956.5
Quick Mode
33554432 71468.5
bandwidthTest --memory=pinned --device=1
Using device 1: GT200
Quick Mode
33554432 1718.5
Quick Mode
33554432 1663.2
Quick Mode
33554432 74748.9
bandwidthTest --device=1
Quick Mode
33554432 1666.5
Quick Mode
33554432 1502.1
Quick Mode
33554432 74818.8
