Batched multiplication with sparse matrices and dense vectors
I have a situation where I need to multiply various sparse matrices with an unchanging dense vector. I first attempted to solve this using cusparseSpSV and cusparseCooSetStridedBatch, however, this resulted in an error when calling cusparseSpSV_bufferSize that said “On entry to cusparseSpMV_bufferSize(): batched computation is unsupported”.
Then, I tried cusparseSpMM. This worked when the dense matrix B had more than one column, but when I tried to represent my dense vector as a dense matrix with a single column, I encountered some strange behaviour. The multiplication would work correctly for the first matrix-vector product, but all subsequent matrix-vector products would have all zeros in the resultant C vector. Looking at the docs for cuSPARSE I’m fairly confident I’ve found why this is happening. Under cusparseSpMM performance notes, there is a dot point that says “For n == 1, the routine uses cusparseSpMV() as fallback”, where n is the number of columns in the B matrix. So, I’m guessing what happens is that cusparseSpMM recognises that B only has 1 column, and uses cusparseSpMV instead, but cusparseSpMV can’t do batched operations and so only performs the first matrix-vector product.
So, I was wondering if there are any plans to include batched operations for cusparseSpMV, or a way to disable the fallback to cusparseSpMV in cusparseSpMM, or another workaround? Thanks.
Hi. We haven’t had plan to do batched SpMV, but if there are many requests we’ll consider doing it.
2 potential workarounds that I can think of:
  1. pad the vector to make it a 2-column matrix to bypass the SpMV fallback.
  2. Concatenate your matrices into a single matrix of size (k*m) x n, where k is the batch size. This requires a preprocessing step for constructing the big matrix.
Would you mind telling us what is your use case of batched SpMV?
Hi thanks for the response. You’re right, batched SpMV isn’t really necessary in this case, since my dense vector is unchanging I can concatenate my matrices into one large matrix and multiply that with the dense vector. Thanks.
Glad it helps. Just one note that when you concatenate the matrices you’ll need to update row indexes of subsequent matrices so that the indexes are in range [0, k*m).
