[BEGINNER] host memory and device memory question questions about host memory and device memory
hi, i m trying to wrap my head around the idea of host memory and device memory in CUDA.
this piece of code is copy from JuliaSet in the “CUDA by example” book
[codebox]
struct cuComplex {
float   r;
float   i;
cuComplex( float a, float b ) : r(a), i(B)  {}
__device__ float magnitude2( void ) {
    return r * r + i * i;
__device__ cuComplex operator*(const cuComplex& a) {
    return cuComplex(r*a.r - i*a.i, i*a.r + r*a.i);
__device__ cuComplex operator+(const cuComplex& a) {
    return cuComplex(r+a.r, i+a.i);
device int julia( int x, int y ) {
const float scale = .5;
float jx = scale * (float)(DIM/2 - x)/(DIM/2);
float jy = scale * (float)(DIM/2 - y)/(DIM/2);
cuComplex c(-0.8, 0.156);
cuComplex a(jx, jy);
int i = 0;
for (i=0; i<200; i++) {
    a = a * a + c;
    if (a.magnitude2() > 1000)
        return 0;
return 1;
}[/codebox]
the above code compiles and runs fine, but i m confuse at what the compiler is doing and what the memory looks like.
heres what i think the above code does, please correct me if i m wrong:
device function “Julia” returns 1 if some complex number “a” belongs in the julia set, and 0 otherwise. the device function also
calls device utility functions for complex numbers, defined in the cuComplex struct.
i understand, sort of, that the julia function resides in device memory, and all functions declare using the device syntax.
but i dont get how the julia function knows where “cuComplex” is, since it s a struct defined in host memory?
does the compiler store a pointer to the struct definition and pass to device? i dont see the code using cudaMalloc to allocate that pointer
in device memory in code.
any help or advice on where i should read in the programming guide would be great.
thanks in advance
[codebox]
struct cuComplex {
float   r;
float   i;
int i = 0;
    a = a * a + c;
        return 0;
return 1;
}[/codebox]
thanks in advance
[font=“Courier New”]struct cuComplex[/font] is a type, not a variable. Whether a particular variable of that type resides in host memory or device memory depends on the declaration of that variable.
