if anyone can tell me that in the cudnn, is every image has many feature maps, and if that, what that feature maps mean? in my conception, every image is sent to the net and then the net is trained by that, in the process, every layer has many feature maps. so what does the cudnnSetTensor4dDescriptor function’s parameter ‘n’ mean,which is described as number of images? aren’t that parameter only be 1?
hit5042
2
i think parameter ‘n’ means the number of image u put into the network one times, also means the batchsize number
Related topics
| Stride parameters of cudnnSetTensor4dDescriptorEx and cudnnGetTensor4dDescriptor | 0 | 903 | July 4, 2016 | |
| cudnnSetTensor4dDescriptor & cudnnSetTensorNdDescriptor parameters opposite params | 0 | 1588 | May 31, 2018 | |
| Some question abort cudnnSetTensorNdDescriptor and cudnnSetTensor4dDescriptor. | 0 | 599 | November 21, 2017 | |
| Some question abort cudnnSetTensorNdDescriptor and cudnnSetTensor4dDescriptor. | 0 | 636 | November 13, 2017 | |
| cuDNN: "cudnnTensor4dDescriptor_t" for sigmoid component in fully connected layer | 1 | 1555 | November 12, 2014 | |
| Does cudnn support Convolution in 4d or higher dimensions..?? | 0 | 535 | August 16, 2018 | |
| Convolution with cuDNN | 7 | 2207 | January 10, 2018 | |
| Question About CudNN V2 Example Code | 1 | 1117 | August 17, 2015 | |
| 4d descriptors vs Nd descriptors | 0 | 497 | June 24, 2019 | |
| cuDNN: How is the notion of the tensor dimensions preserved in Nd layouts? | 4 | 2991 | December 1, 2016 |
