I know this is 10 years old, but I had a similar question while playing with textures and surfaces myself.
I have worked out an example that does exactly what you suggested using texture references.
// Code adapted from stack overflow:
// https://stackoverflow.com/a/38749995
#include <stdio.h>
#include <helper_cuda.h>
#include <cuda_runtime.h>
#include <cuda_runtime_api.h>
#include <cuda_texture_types.h>
texture<float, cudaTextureType3D, cudaReadModeElementType> volumeTexIn;
surface<void, 3> volumeTexOut;
__global__ void
surf_write(float *data, cudaExtent volumeSize, float offset)
int x = blockIdx.x * blockDim.x + threadIdx.x;
int y = blockIdx.y * blockDim.y + threadIdx.y;
int z = blockIdx.z * blockDim.z + threadIdx.z;
if (x >= volumeSize.width || y >= volumeSize.height || z >= volumeSize.depth)
return;
float output = data[z * (volumeSize.width * volumeSize.height) + y * (volumeSize.width) + x];
surf3Dwrite(output + offset, volumeTexOut, x * sizeof(float), y, z);
__global__ void
tex_read(float x, float y, float z)
printf("texture: x: %f, y: %f, z:%f, val: %f\n", x, y, z, tex3D(volumeTexIn, x, y, z));
__global__ void
regular_read(int x, int y, int z, float * array)
printf("regular: x: %d, y: %d, z:%d, val: %f\n", x, y, z, array[x+y*8+z*64]);
void runtest(float *data, cudaExtent vol, float x, float y, float z)
cudaChannelFormatDesc channelDesc = cudaCreateChannelDesc<float>();
cudaArray_t content;
checkCudaErrors(cudaMalloc3DArray(&content, &channelDesc, vol, cudaArraySurfaceLoadStore));
float *d_data;
checkCudaErrors(cudaMalloc(&d_data, vol.width * vol.height * vol.depth * sizeof(float)));
checkCudaErrors(cudaMemcpy(d_data, data, vol.width * vol.height * vol.depth * sizeof(float), cudaMemcpyHostToDevice));
regular_read<<<1, 1>>>((int)x, (int)y, (int)z, d_data);
// Binding the texture and surface
checkCudaErrors(cudaBindSurfaceToArray(volumeTexOut, content));
checkCudaErrors(cudaBindTextureToArray(volumeTexIn, content));
dim3 blockSize(8, 8, 8);
dim3 gridSize((vol.width+7)/8,(vol.height+7)/8, (vol.depth+7)/8);
surf_write<<<gridSize, blockSize>>>(d_data,vol, 0);
volumeTexIn.filterMode = cudaFilterModePoint; // Non interpolated
tex_read<<<1, 1>>>(x, y, z);
volumeTexIn.filterMode = cudaFilterModeLinear; // Interpolated
surf_write<<<gridSize, blockSize>>>(d_data,vol, 42);
checkCudaErrors(cudaDeviceSynchronize());
cudaFreeArray(content);
cudaFree(d_data);
return;
int main()
const int dim = 8;
float *data = (float *)malloc(dim * dim * dim * sizeof(float));
for (int z = 0; z < dim; z++)
for (int y = 0; y < dim; y++)
for (int x = 0; x < dim; x++)
data[z * dim * dim + y * dim + x] = z * 100 + y * 10 + x;
// printf("x: %d, y: %d, z:%d, val: %f\n",
// x, y, z, data[z * dim * dim + y * dim + x]);
cudaExtent vol = {dim, dim, dim};
runtest(data, vol, 1.5, 1.5, 1.5);
runtest(data, vol, 1.9, 1.9, 1.9);
runtest(data, vol, 5, 5, 5);
free(data);
return 0;
It produces the following output:
regular: x: 1, y: 1, z:1, val: 111.000000 // Read from regular device mem
texture: x: 1.500000, y: 1.500000, z:1.500000, val: 111.000000 // texture read
texture: x: 1.500000, y: 1.500000, z:1.500000, val: 153.000000 // texture read
texture: x: 1.900000, y: 1.900000, z:1.900000, val: 111.000000 // Non interpolated
texture: x: 1.900000, y: 1.900000, z:1.900000, val: 155.187500 // Interpolated
texture: x: 1.900000, y: 1.900000, z:1.900000, val: 153.000000 // Non interpolated after adding 42 to surf
texture: x: 1.900000, y: 1.900000, z:1.900000, val: 197.187500 // Interpolated after adding 42 to surf
regular: x: 5, y: 5, z:5, val: 555.000000
texture: x: 5.000000, y: 5.000000, z:5.000000, val: 555.000000
texture: x: 5.000000, y: 5.000000, z:5.000000, val: 499.500000
texture: x: 5.000000, y: 5.000000, z:5.000000, val: 597.000000
texture: x: 5.000000, y: 5.000000, z:5.000000, val: 541.500000
For additional info on texture memory, the documentation is a good resource: CUDA C++ Programming Guide (Legacy) — CUDA C++ Programming Guide
