Hi! I need to use about 4 different textures and they all need the same configuration (liner interpolation and normalized index), I thought I could have a cleaner code while saving a few lines by encapsulating all the setup, including the texture binding inside a function.
I read that I can’t pass a texture as a function argument in the host but I thought I could use textureReference as a workaround. So far I haven’t been able to make it work as it’s giving me problems due to the texture reference not being a constant.
Anyone has some suggestions?
Here’s a non-working pseudo-code:
texture<float, 1, cudaReadModeElementType> tex1, tex2;
void
load_tex(float *data, int length, cudaArray *data_array,
textureReference *tref){
//allocate cuda array memory
checkCudaErrors(cudaMallocArray(&data_array, &tref->channelDesc,
length, 1));
//copy data vector to cuda array
checkCudaErrors(cudaMemcpyToArray(data_array, 0, 0, data,
sizeof(float)*length,
cudaMemcpyHostToDevice));
//bind array to texture
checkCudaErrors(cudaBindTextureToArray(&tref, data_array));
//set texture parameters
tref->addressMode[0] = cudaAddressModeBorder;
tref->addressMode[1] = cudaAddressModeBorder;
tref->filterMode = cudaFilterModeLinear;
tref->normalized = true;
int main(){
textureReference *tref;
cudaArray *data_array1, *data_array2;
float *data1, *data2;
int length = 10;
//initialize, allocate and populate data
//load textures using functions
cudaGetTextureReference(&tref, &tex1);
load_tex(data1, length, data_array1, &tref);
cudaGetTextureReference(&tref, &tex2);
load_tex(data2, length, data_array2, &tref);
