I’m experiencing an issue with 8 GMSL2 cameras (IMX490 sensors) connected to a Jetson AGX Orin (running Jetpack 5.1.1).
The problem:
After running the cameras for 1–3 hours, some of them start displaying a black screen. Occasionally, frames from these cameras appear partially black (e.g., one-half of the image is black). The affected cameras are still visible in v4l2, but their images are corrupted. This issue does not occur on all cameras; some continue to function normally.
Similar setup was tested on a copy of hardware but with 4 cameras, and everything works fine under the same conditions
