I have a simple program where you have an array with the next values: a[0]=0; a[1]=1; a[2]=2;…a[n]=n;
The aim of the kernel is plus by one each position: a[0]=1; a[1]=2;…a[n]=n+1;
I’ve used one block and the variable “size” contains the numbers of threads which is the size of the array too.
So if the size is less than 512 all is correct. But for example the size is 560 all is wrong because the result is the same of the first array (no change).
I know that maximum sizes of dimension of a thread block is 512.
I want to know how I can see the error! I put this but it’s not a solution: CUT_CHECK_ERROR(“Kernel execution failed”);
[codebox]
global void PLUS (float* C)
int i = threadIdx.x;
C[i]=C[i]+1.0;
int main(int argc, char** argv)
if (argc!=2){
printf("wrong number of arguments!!!!!!\n");
}else{
unsigned int size =512; //if size is bigger than 512 the array isn't change.
unsigned int mem_size = sizeof(float) * size;
float* h_C = (float*) malloc(mem_size);
for (int i = 0; i < size; i++)
h_C[i] = (float)i;
float* d_C;
CUDA_SAFE_CALL(cudaMalloc((void**) &d_C, mem_size));
CUDA_SAFE_CALL(cudaMemcpy(d_C, h_C, mem_size, cudaMemcpyHostToDevice) );
PLUS <<< 1 , size >>> (d_C);
CUDA_SAFE_CALL(cudaMemcpy(h_C,d_C, mem_size, cudaMemcpyDeviceToHost) );
CUT_CHECK_ERROR(“Memcpy execution failed”);
printf(“h_C[%d]=%f\n”,atoi(argv[1]),h_C[atoi(argv[1])]);
CUDA_SAFE_CALL(cudaFree(d_C));
free(h_C);
}[/codebox]
What is the command for watch the error???
Thank you,
