❌ RTX 6000 Blackwell Workstation Edition (96 GB) Compatibility Issue
I am encountering a critical issue trying to run three specific NVIDIA NIM Blueprints on my RTX Pro 6000 Blackwell (Workstation Edition) 96 GB GPU.
The problem appears to be with the LLM server, which is failing to correctly identify or recognize the GPU profile of the RTX 6000 Blackwell . As a result, all three blueprints failed to execute or run.
The specific blueprints that failed are:
3D Generation Blueprint (via NVIDIA NIM)
3D Guided Generative AI Blueprint (via NVIDIA NIM)
Retail Shopping Assistant Blueprint (via NVIDIA NIM)
I require a solution to ensure the LLM server properly profiles the RTX 6000 so these blueprints can run smoothly.
