I see exactly the same problem documented here by ncs1. But that thread did not provide solution in the end.
After fusing another Jetson Orin from scratch, I found that the issue is caused by the OemKeyValid bit 9 of BootSecurityInfo.
Basically, this bit must be marked in the same fusing operation when SBK key and SBK bit (3) in BootSecurityInfo fuse.
If OemKeyValid bit is not marked while SBK key and SBK bit (3) are set, the SOM is in a bad state that will report error on mb1. Below is the log:
[ 0.6874 ] Boot Rom communication
[ 0.6877 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader_encrypt.bin.signed --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader_encrypt.bin.signed --download bct_mb1 mb1_bct_MB1_sigheader_encrypt.bct.signed
[ 0.6880 ] BR_CID: 0x89012344705DF6C70C00000002018080
[ 0.7113 ] Sending bct_br
[ 0.7114 ] Sending mb1
[ 0.7119 ] ERROR: might be timeout in USB write.
Error: Return value 3
Because of this error (OemKeyValid not set), I cannot read fuse, neither can I fuse this bit now, although I have not sealed the fuse yet. I cannot re-flash the QSPI anymore.
Would you please provide a solution for me to recover SOM from this situation?
The only difference is the bit-9 oemKeyValid bit set or not
All PKC keys are RSA-3072.
It appears to me that BootROM is in bad state: It requires host to send encrypted MB1, but it does not decrypt MB1 because of OemKeyValid is not marked. Therefore, it refuses to boot as requested from USB-C and fall back to existing boot because I have not set SecureMode to 1 yet.
I cannot read fuse from force-recovery mode, neither can I fuse OemKeyValid bit now.
I can read fuse from Linux. The PKC and BootSecurityInfo match the content from fuse-conf.xml
and then, running with odmfuse script again with the same PKC/SBK you’ve burned to have additional fuses.
for instance, $ sudo ./odmfuse.sh -X <fuse_config> -i 0x23 -k PKC -S SBK <target_config>
It seems like we are not in sync with what the problem is.
The problem is: I cannot fuse it anymore. The mb1 sent to SOM is rejected. The host side (Linux PC) gets error “"ERROR: might be timeout in USB write.”
To fuse “oem key valid” bit, I tried both cases with/without “OemK1” content in fuse conf. Neither one worked.
See the log on both host(Linux) and target(Orin) sides: log-on-host-side-1.txt (19.3 KB) log-on-target-side-1.txt (37.4 KB)
The re-fuse conf is here. (It’s renamed from .xml to .txt so that it can be attached here) fuse-conf-1.txt (236 Bytes)
The error is the same: the MB1 sent from host to target is ignored by BootROM.
My guess is BootROM in one hand requires host to send encrypted MB1, while on the other hand does not decrypt the encrypted MB1 because the OemKeyValid not marked. That would cause such kind of deadlock.
BTW: Linux OS is still bootable because securemode is not set yet. If you have solution to fuse OemKeyValid bit from Linux OS, that would be good for me, too.
I dig around your(nvidia) tech support forums and found (so far) there 3 other threads (342811, 342924 and 300161) linked below.
They ALL point to the same problem:
OemKeyValid bit not set in first board and results in the same problem.
OemKeyValid bit set in 2nd board and works well.
There is no solution provided to recover the first board and the thread was closed.
I am seeking a solution to recover the first board. I believe this is an undocumented bug in BootROM. At a minimum, the document is misleading. OemKeyValid bit, by common sense, makes people think it is related to OemK1 & OemK2, and should NOT be related to SBC key.
please refer to previous post #5, let’s try running with odmfuse script again without given PKC/SBK keys (without -k and -S commands).
in other words, just treat the target as a NS board. for instance, $ sudo ./odmfuse.sh -X <fuse_config> -i 0x23 <target_config>
Can you please talk to your engineer team who work on BootROM or Fuse? When developers contact Nvidia, they have already exhausted all options that publicly available.
Of course, the first thing I tried was to treat the SOM like an NS board (without -k and -S command) since the “securemode” has not been set yet.
Your odmfuse.sh rejects it right away (tried both odmfuse.sh from r36.4.4 and r36.5.0):
Error: Either PKC or SBK key is not provided for SBK+PKC protected target board.
SBK key and PKC hashes are fused. BootSecurityInfo is set to 0x1e9. The OemKeyValid bit is NOT set.
The BootROM gets into buggy state: On one hand, it requires host side to send encrypted MB1. On the other hand, because OemKeyValid is not set, BootROM does not understand the encrypted MB1, therefore, it refuses to respond. That includes NOT responding the ECID query command. Therefore, your new “odmfuse.func” will NOT run (ECID is null)
