Bug in cuda-memcheck?
Hi All,
I have a code with structs in shared memory with member variables initialized in a function called from the main kernel. Regular execution produces no problems, but cuda-memcheck throws an “Address out of bounds error”. If I move the initialization to the main kernel, cuda-memcheck doesn’t complain. Is this a “feature” or a bug or is there something I’m missing?
Below is the simplest reproducible code I could come up with. I use CUDA 5.0 on a CentOS 6.3 x64 and driver 304.54.
//main.cpp
include “gpu.h”
int main(int argc, char* argv){
run_kernel();
return 0;
//gpu.h
#ifndef GPU_H_
define GPU_H_
void run_kernel();
struct cuda_model{
int size;
endif /* GPU_H_ */
//gpu.cu
include <stdio.h>
include “gpu.h”
define FUNCTION 0 //use 1 to select in-function initialization
device shared cuda_model model;
device void init(cuda_model* model){
if (threadIdx.x == 0){
model->size = 5;
__syncthreads();
global void compute(){
if (FUNCTION){
    init(&model);
else{
    if (threadIdx.x == 0) model.size = 5;
host void run_kernel(){
compute<<<1,1>>>();
cudaDeviceSynchronize();
[sasha@gpudev Debug]$ cuda-memcheck ./Test
========= CUDA-MEMCHECK
========= Invalid global write of size 4
========= at 0x00000088 in /home/sasha/cuda-workspace/Test/Debug/../gpu.cu:11:init(cuda_model*)
========= by thread (0,0,0) in block (0,0,0)
========= Address 0x01000000 is out of bounds
========= Device Frame:/home/sasha/cuda-workspace/Test/Debug/../gpu.cu:19:compute(void) (compute(void) : 0x100)
========= Saved host backtrace up to driver entry point at kernel launch time
========= Host Frame:/usr/lib64/libcuda.so (cuLaunchKernel + 0x3dc) [0xc9edc]
========= Host Frame:/usr/local/cuda-5.0/lib64/libcudart.so.5.0 [0x11d54]
========= Host Frame:/usr/local/cuda-5.0/lib64/libcudart.so.5.0 (cudaLaunch + 0x182) [0x38152]
========= Host Frame:./Test [0x92a]
========= Host Frame:./Test [0x9b9]
========= Host Frame:/lib64/libc.so.6 (__libc_start_main + 0xfd) [0x1ecdd]
========= Host Frame:./Test [0x749]
========= Program hit error 4 on CUDA API call to cudaDeviceSynchronize
========= Saved host backtrace up to driver entry point at error
========= Host Frame:/usr/lib64/libcuda.so [0x26a180]
========= Host Frame:/usr/local/cuda-5.0/lib64/libcudart.so.5.0 (cudaDeviceSynchronize + 0x1dd) [0x412dd]
========= ERROR SUMMARY: 2 errors
Hi Shura58. Thanks for reporting this issue. Can you try the latest publicly available driver from www.nvidia.com and see if your issue still presents ? I believe the latest driver for Linux64 is 310.40.
Thanks, Vyas. The updated driver actually fixed the issue.
