I had a working gstreamer pipeline for converting + scaling MPEGTS (h264/mp2) into an rtsp-stream. It utilized nvv4l2decoder as well as nvv4l2h264enc which used to work just fine on JetPack 4.4. When I updated to 4.5 using nvv4l2decoder for decoding still works, but nvv4l2h264enc will only result in an rtsp-stream without video, no meaningful errormessage. In fact the stream seems to run just fine technically.
When I replace nvv4l2h264enc with omxh264enc (and adjust parameters accordingly) everything is working just fine.
Checked both streams via ffmpeg (what it actually detects in the resulting rtsp-stream). Results are exactly identical. Funny enough, VLC has no issues playing the rtsp-stream from nvv4l2h264enc.
But my intended usecase is that the rtsp-stream is requested via TVHeadend (through an ffmpeg pipe) and the actual client is Kodi. I am totally lost why Kodi will play the stream from omxh264enc but not the one from nvv4l2h264enc with the exact same pipeline.
idrinterval : Encoding IDR Frame occurance frequency
flags: readable, writable, changeable only in NULL or READY state
Unsigned Integer. Range: 0 - 4294967295 Default: 256
Please set it to a smaller value like 30 and 60 for a try.
@DaneLLL Yep, setting it to 30 as well as 60 does work! But what’s the recommended value and why? Personally always thought the defaults should be fine for every usecase ;)
Some “rampup” issues seem to persist even with 30 or 60. I use an onDemand RTSP-Server to start streaming when clients connect. If I start the stream manually and consume it, it works reliably. If I start in onDemand and directly consume it I get audio, but no video. If I stop and immediately restart (so I will get the stream already being published) everything works. This, too, works when utilizing omxh264enc.
30 is a good value for idrinterval. For 30fps, you will see one IDR frame every second. 45 or 60 is also good.
You may try to set idrinterval=iframeinterval, and h264parse config-interval=1 . If the issue still persists, please dump the h264 stream and check the deviation through JM decoder. Please refer to
