Hi all,
I try the demo on [u]https://devblogs.nvidia.com/speed-up-inference-tensorrt/[/u]. But there are some problems.
First, I install onnx library as indicated in the devblog, and compile SampleOnnx_1.cpp. But the compiler complains it can’t find IParser. So I git clone the onnx-tensorrt on github. And Then compiler compains IParser has no member “parseFromFile”. I can’t find this member function in header file. Any suggestions?
class IParser
public:
/** \brief Parse a serialized ONNX model into the TensorRT network.
* \param serialized_onnx_model Pointer to the serialized ONNX model
* \param serialized_onnx_model_size Size of the serialized ONNX model
* in bytes
* \return true if the model was parsed successfully
* \see getNbErrors() getError()
virtual bool parse(void const serialized_onnx_model,
size_t serialized_onnx_model_size) = 0;
/** \brief Check whether TensorRT supports a particular ONNX model
* in bytes
* \return true if the model is supported
virtual bool supportsModel(void const *serialized_onnx_model,
* with consideration of user provided weights
* in bytes
* \param weight_count number of user provided weights
* \param weight_descriptors pointer to user provided weight array
virtual bool parseWithWeightDescriptors(
void const *serialized_onnx_model, size_t serialized_onnx_model_size,
uint32_t weight_count,
onnxTensorDescriptorV1 const *weight_descriptors) = 0;
/** \brief Returns whether the specified operator may be supported by the
* parser.
* Note that a result of true does not guarantee that the operator will be
* supported in all cases (i.e., this function may return false-positives).
* \param op_name The name of the ONNX operator to check for support
virtual bool supportsOperator(const char* op_name) const = 0;
/** \brief destroy this object
virtual void destroy() = 0;
/** \brief Get the number of errors that occurred during prior calls to
* \p parse
* \see getError() clearErrors() IParserError
virtual int getNbErrors() const = 0;
/** \brief Get an error that occurred during prior calls to \p parse
* \see getNbErrors() clearErrors() IParserError
virtual IParserError const* getError(int index) const = 0;
/** \brief Clear errors from prior calls to \p parse
* \see getNbErrors() getError() IParserError
virtual void clearErrors() = 0;
protected:
virtual ~IParser() {}
