Hi. I need to run Pytorch 2.8 on Jetson AGX Orin with JetPack 6.2. The pre-built wheels from NVIDIA are great, but all seem to use Numpy 1, which causes issues once torch is imported.
I have followed the good instructions here: PyTorch environment and Zed SDK conflicts on Jetpack 6.2 - #5 by AastaLLL , ensuring that I install numpy 2 along with requirements.txt and clone torch 2.8 (not 2.7) for the build.
This successfully produced a wheel that I could import with numpy 2, but then torch.cuda.is_available() and torch.backends.cuda.is_built()both return False, while torch.version.cudareturns None.
What did I miss so that torch built without CUDA? Thanks for the help.
I fixed it! Here are tips that should generalize across Pytorch and JetPack versions, as well as specifics that worked in my case.
General Principles
- When building torch using
setup.py, open the file to see which environment variables can be used and which are relevant to you. For example, though the post suggested USE_NATIVE_ARCH=1 for 2.7 builds, that environment variable doesn’t seem to be used when building torch 2.8.
- Install build dependencies in a virtual environment. This is usually my practice, but I originally skipped it for speed. Then I regretted it.
- Check the errors and CMake warnings during build. This will help you catch errors and kill the build early, rather than waiting 2 hours.
Specific Steps
- As suggested here,
git clone --depth=1 --recursive -b v<PYTORCH_VERSION> https://github.com/pytorch/pytorch
cd pytorch
- Create a virtual environment for the build packages (set that up yourself using
venv, uv, etc.)
- Install packages outlined in original post into the virtual environment
- Install
numpy>2 into the virtual environment
- Obtain your CUDA Arch Bin using
jtop (mine was 8.7 for AGX Orin Dev Kit)
- Set environment variables and build as follows:
USE_CUDA=1 USE_CUDNN=1 USE_CUSPARSELT=1 USE_CUDSS=1 USE_CUFILE=1 TORCH_CUDA_ARCH_LIST="<CUDA Arch Bin>" USE_DISTRIBUTED=1 USE_FLASH_ATTENTION=1 USE_MEM_EFF_ATTENTION=1 USE_TENSORRT=0 python3 setup.py bdist_wheel
During the build, check for Cmake warnings. For example, I encountered and fixed the following
-- Could NOT find CUDA (missing: CUDA_TOOLKIT_ROOT_DIR CUDA_NVCC_EXECUTABLE CUDA_INCLUDE_DIRS CUDA_CUDART_LIBRARY)
CMake Warning at cmake/public/cuda.cmake:31 (message):
PyTorch: CUDA cannot be found. ...
This happened because I didn’t include Jetson SDK Components when using the SDKManager to flash my Orin. I resolved it using sudo apt install nvidia-jetpack on the Orin
-- Could NOT find CUSPARSELT (missing: CUSPARSELT_LIBRARY_PATH CUSPARSELT_INCLUDE_PATH)
CMake Warning at cmake/public/cuda.cmake:276 (message):
Cannot find cuSPARSELt library. Turning the option off
I downloaded cusparselt 0.6.3 from here: using the Linux → aarch64-jetson → Ubuntu 22.04 → deb (local) steps. The install_cusparselt.sh script mentioned here didn’t seem to work.
-- Could NOT find CUDSS (missing: CUDSS_LIBRARY_PATH CUDSS_INCLUDE_PATH)
CMake Warning at cmake/public/cuda.cmake:242 (message):
Cannot find CUDSS library. Turning the option off
I downloaded cudss 0.7.1 from cuDSS 0.7.1 Downloads | NVIDIA Developer using the Linux → aarch64-jetson → Ubuntu 22.04 → deb (local) steps.
Once your wheel is built in dist, you can move it to your desired deployment environment and install it there.
Test your installed wheel in Python:
import torch, numpy
print("torch: ", torch.__version__)
print("numpy: ", numpy.__version__)
print("torch.version.cuda: ", torch.version.cuda)
print("cuda built: ", torch.backends.cuda.is_built())
print("cuda available: ", torch.cuda.is_available())
print("cuda device count: ", torch.cuda.device_count())
