Build TRT engine with onnx QAT model throws segmentation fault
Description
Hello
I’m trying to build onnx model with quantization aware training following this:
it was successful until exporting onnx model from pytorch. The onnx model passed onnx.checker.check_model() as well.
But building tensorrt engine failed with segmentation fault
trtexec --onnx=model.onnx --workspace=3000 --int8 --verbose
[08/10/2021-18:38:51] [V] [TRT] Parsing node: DequantizeLinear_276 [DequantizeLinear]
[08/10/2021-18:38:51] [V] [TRT] Searching for input: 318
[08/10/2021-18:38:51] [V] [TRT] Searching for input: 319
[08/10/2021-18:38:51] [V] [TRT] Searching for input: 320
[08/10/2021-18:38:51] [V] [TRT] DequantizeLinear_276 [DequantizeLinear] inputs: [318 -> (192, 128, 3, 3)[FLOAT]], [319 -> ()[FLOAT]], [320 -> ()[INT8]],
[08/10/2021-18:38:51] [V] [TRT] Registering tensor: 321 for ONNX tensor: 321
[08/10/2021-18:38:51] [V] [TRT] DequantizeLinear_276 [DequantizeLinear] outputs: [321 -> (192, 128, 3, 3)[FLOAT]],
[08/10/2021-18:38:51] [V] [TRT] Parsing node: ConvTranspose_277 [ConvTranspose]
[08/10/2021-18:38:51] [V] [TRT] Searching for input: 315
[08/10/2021-18:38:51] [V] [TRT] Searching for input: 321
[08/10/2021-18:38:51] [V] [TRT] Searching for input: body.11.bias
[08/10/2021-18:38:51] [V] [TRT] ConvTranspose_277 [ConvTranspose] inputs: [315 -> (1, 192, 180, 320)[FLOAT]], [321 -> (192, 128, 3, 3)[FLOAT]], [body.11.bias -> (128)[FLOAT]],
[08/10/2021-18:38:51] [V] [TRT] Convolution input dimensions: (1, 192, 180, 320)
here is my onnx file :
https://drive.google.com/file/d/1gaUvxaFLcb2cinXcM6CW3pNbN9KOeI4W/view?usp=sharing
Environment
TensorRT Version: 8.0.1.6
GPU Type: NVIDIA 2080 ti
Nvidia Driver Version: 465.19.01
CUDA Version: 11.3
CUDNN Version: 8.2
Operating System + Version: Ubuntu 20.04
Python Version (if applicable): 3.8
TensorFlow Version (if applicable): -
PyTorch Version (if applicable): 1.8.1
Baremetal or Container (if container which image + tag): baremetal
Hi @k961118,
We could reproduce the same error. Are you able to successfully run the inference using onnx-runtime ?
Hi @spolisetty
No, running inference with onnx-runtime failed while creating inference session
import onnx
import onnxruntime
model = onnx.load("model.onnx")
onnx.checker.check_model(model)
ort_session = onnxruntime.InferenceSession("model.onnx")
I found this issue and i think it is related
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
  1. validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
https://github.com/NVIDIA/TensorRT/tree/master/samples/opensource/trtexec
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
