Originally published at: https://developer.nvidia.com/blog/build-vlm-powered-visual-ai-agents-using-nvidia-nim-and-nvidia-via-microservices/
Traditional video analytics applications and their development workflow are typically built on fixed-function, limited models that are designed to detect and identify only a select set of predefined objects. With generative AI, NVIDIA NIM microservices, and foundation models, you can now build applications with fewer models that have broad perception and rich contextual understanding. The…
Hello, I couldn’t pull nvcr.io/metropolis/vita-dp/vita-engine:2.0-dp docker image with NGC API Key. The error is: “Error response from daemon: pull access denied for nvcr.io/metropolis/vita-dp/vita-engine, repository does not exist or may require ‘docker login’: denied: requested access to the resource is denied”. But when I tested other images, it downloads without problems
@agajan Thank you for the interests in VITA. You may refer to Getting Started - NVIDIA Docs for how to set up the NIM docker. If there are more questions, you may raise topic in the NIM forum Latest AI & Data Science/NVIDIA NIM topics - NVIDIA Developer Forums
