Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
[*] NVIDIA DRIVE™ Software 10.0 (Linux)
other DRIVE OS version
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] NVIDIA DRIVE™ AGX Xavier DevKit (E3550)
other
SDK Manager Version
1.5.0.7774
other
Host Machine Version
[*] native Ubuntu 18.04
other
Understand Drive AGX is not optimal for development, but I want to use Pytorch for pre-processing. I follow PyTorch for Jetson and Build the pytorch from source for drive agx xavier to build the Pytorch from the source. It failed as follow:
[2909/4360] Building CXX object caffe2/CMakeFiles/torch_cpu.dir/onnx/backend.cc.o
FAILED: caffe2
/usr/bin/c++ -DAT_PARALLEL_OPENMP=1 -DCPUINFO_SUPPORTED_PLATFORM=1 -DFXDIV_USE_INLINE_ASSEMBLY=0 -DHAVE_MALLOC_USABLE_SIZE=1 -DHAVE_MMAP=1 -DHAVE_SHM_OPEN=1 -DHAVE_SHM_UNLINK=1 -DMINIZ_DISABLE_ZIP_READER_CRC32_CHECKS -DNNP_CONVOLUTION_ONLY=0 -DNNP_INFERENCE_ONLY=0 -DONNX_ML=1 -DONNX_NAMESPACE=onnx_torch -D_FILE_OFFSET_BITS=64 -Dtorch_cpu_EXPORTS -Iaten/src -I…/aten/src -I. -I…/ -isystem …/cmake/…/third_party/googletest/googlemock/include -isystem …/cmake/…/third_party/googletest/googletest/include -isystem …/third_party/protobuf/src -isystem …/third_party/XNNPACK/include -I…/cmake/…/third_party/benchmark/include -isystem …/cmake/…/third_party/eigen -isystem /home/nvidia/miniconda3/envs/py36/include/python3.6m -isystem /home/nvidia/miniconda3/envs/py36/lib/python3.6/site-packages/numpy/core/include -isystem …/cmake/…/third_party/pybind11/include -isystem /opt/rocm/hip/include -isystem /include -isystem …/cmake/…/third_party/cub -Icaffe2/contrib/aten -I…/third_party/onnx -Ithird_party/onnx -I…/third_party/foxi -Ithird_party/foxi -I/usr/local/cuda-10.2/include -I…/caffe2/…/torch/csrc/api -I…/caffe2/…/torch/csrc/api/include -I…/caffe2/aten/src/TH -Icaffe2/aten/src/TH -I…/caffe2/…/torch/…/aten/src -Icaffe2/aten/src -Icaffe2/…/aten/src -Icaffe2/…/aten/src/ATen -I…/caffe2/…/torch/csrc -I…/caffe2/…/torch/…/third_party/miniz-2.0.8 -I…/aten/src/TH -I…/aten/…/third_party/catch/single_include -I…/aten/src/ATen/… -Icaffe2/aten/src/ATen -I…/third_party/miniz-2.0.8 -I…/caffe2/core/nomnigraph/include -isystem include -I…/third_party/FXdiv/include -I…/c10/… -I…/third_party/cpuinfo/include -I…/third_party/NNPACK/include -I…/third_party/pthreadpool/include -I…/third_party/FP16/include -Wno-deprecated -fvisibility-inlines-hidden -fopenmp -DNDEBUG -DUSE_XNNPACK -DUSE_INTERNAL_THREADPOOL_IMPL -O2 -fPIC -Wno-narrowing -Wall -Wextra -Werror=return-type -Wno-missing-field-initializers -Wno-type-limits -Wno-array-bounds -Wno-unknown-pragmas -Wno-sign-compare -Wno-unused-parameter -Wno-unused-variable -Wno-unused-function -Wno-unused-result -Wno-strict-overflow -Wno-strict-aliasing -Wno-error=deprecated-declarations -Wno-stringop-overflow -Wno-error=pedantic -Wno-error=redundant-decls -Wno-error=old-style-cast -fdiagnostics-color=always -faligned-new -Wno-unused-but-set-variable -Wno-maybe-uninitialized -fno-math-errno -fno-trapping-math -Werror=format -Wno-stringop-overflow -O3 -DNDEBUG -DNDEBUG -fPIC -DCUDA_HAS_FP16=1 -D__NEON__ -DUSE_GCC_GET_CPUID -DTH_HAVE_THREAD -Wall -Wextra -Wno-unused-parameter -Wno-missing-field-initializers -Wno-write-strings -Wno-unknown-pragmas -Wno-missing-braces -Wno-maybe-uninitialized -fvisibility=hidden -O2 -DCAFFE2_BUILD_MAIN_LIB -pthread -std=gnu++14 -MD -MT caffe2/CMakeFiles/torch_cpu.dir/onnx/backend.cc.o -MF caffe2/CMakeFiles/torch_cpu.dir/onnx/backend.cc.o.d -o caffe2/CMakeFiles/torch_cpu.dir/onnx/backend.cc.o -c …/caffe2/onnx/backend.cc
…/caffe2/onnx/backend.cc:11:10: fatal error: onnx/optimizer/optimize.h: No such file or directory
#include “onnx/optimizer/optimize.h”
compilation terminated.
There is no such file “onnx/optimizer/optimize.h” in the source code. MKL is not available for aarch64, wound it affect the PyTorch compilation and usage?
