Hello, While using the TAO Toolkit to train the classification_tf2 model using byom approach, I am having following error. This error is not present if I train the model starting from a saved model weight file from the efficientnet_b0 file. However, when I try to have the byom pathway, I am having an error at the launch of
!tao model classification_tf2 train -e $SPECS_DIR/spec.yaml
cannot import name ‘conv_utils’ from ‘keras.utils’ (/usr/local/lib/python3.10/dist-packages/keras/utils/init.py)
Error executing job with overrides: Traceback (most recent call last):
File “/usr/local/lib/python3.10/dist-packages/hydra/_internal/utils.py”, line 213, in run_and_report
return func()
File “/usr/local/lib/python3.10/dist-packages/hydra/_internal/utils.py”, line 453, in
lambda: hydra.run(
File “/usr/local/lib/python3.10/dist-packages/clearml/binding/hydra_bind.py”, line 91, in _patched_hydra_run
return PatchHydra._original_hydra_run(self, config_name, task_function, overrides, *args, **kwargs)
File “/usr/local/lib/python3.10/dist-packages/hydra/_internal/hydra.py”, line 132, in run
_ = ret.return_value
File “/usr/local/lib/python3.10/dist-packages/hydra/core/utils.py”, line 260, in return_value
raise self._return_value
File “/usr/local/lib/python3.10/dist-packages/hydra/core/utils.py”, line 186, in run_job
ret.return_value = task_function(task_cfg)
File “/usr/local/lib/python3.10/dist-packages/clearml/binding/hydra_bind.py”, line 230, in _patched_task_function
return task_function(a_config, *a_args, **a_kwargs)
File “”, line 217, in main
File “”, line 93, in _func
File “”, line 60, in _func
File “”, line 178, in run_experiment
File “”, line 42, in init
File “”, line 86, in _build_models
File “”, line 579, in get_model
File “”, line 118, in get_byom
File “”, line 345, in decode_tltb
File “”, line 322, in deserialize_custom_layers
File “”, line 9, in
ImportError: cannot import name ‘conv_utils’ from ‘keras.utils’ (/usr/local/lib/python3.10/dist-packages/keras/utils/init.py)
For full error log, kindly find the attached file.
byom_tao_launch_error.txt (6.3 KB)
