Hello , I have a kernel and I am calling it in a loop , something like:
int NX = 80 , NY = 80;
dim3 BlocksDim ( BlocksPerGridX , BlocksPerGridY ); // 16 * 16
dim3 ThreadsPerBlock ( ThreadsPerBlockX , ThreadsPerBlockY ); // 16 * 16
for ( int i = 0; i < NX*NY; i++ )
gpuErrchk( cudaMemcpy( devX , X[ i ] , Count[ i ] * sizeof( float ), cudaMemcpyHostToDevice ) );
gpuErrchk( cudaMemcpy( devY , Y[ i ] , Count[ i ] * sizeof( float ), cudaMemcpyHostToDevice ) );
myKernel<<< BlocksDim,ThreadsPerBlock >>>(
Count[ i ], // size is : NX * NY
devX, // size is : the maximum value returned from 'Count' ( around 1-100)
devY, // -||-
devV, // -||-
devResult ); // size is : BlocksDim * ThreadsPerBlock
I want to ask if I can you use streams in this situation and how I can use them . I am trying something like:
const int NbOfStreams = 32;
const int N = BlocksDim * ThreadsPerBlock;
const int StreamSizeResult = N / NbOfStreams;
const int StreamBytesResult = StreamSizeResult * sizeof(float);
const int StreamSize = MaxCount / NbOfStreams;
const int StreamBytes = StreamSize * sizeof(float);
//allocate as host malloc the memory for X,Y,Count
// create events and streams
cudaEvent_t startEvent, stopEvent;
cudaStream_t stream[ NbOfStreams ];
checkCuda( cudaEventCreate(&startEvent) );
checkCuda( cudaEventCreate(&stopEvent) );
for ( int i = 0; i < NbOfStreams; i++ )
cudaStreamCreate(&stream[ i ]);
int offset = i * StreamSizeResult;
cudaMemcpyAsync( &devX[offset], &X[offset],StreamBytes, cudaMemcpyHostToDevice,stream[ i ] );
cudaMemcpyAsync( &devY[offset], &Y[offset],StreamBytes, cudaMemcpyHostToDevice,stream[ i ] );
myKernel<<< StreamSizeResult / ThreadsPerBlock , ThreadsPerBlock , 0, stream[ i ] >>>(
Count[ i ],
devX,
devY,
devV,
devResult );
cudaMemcpyAsync( &host_Result[offset], &devResult[offset],StreamBytesResult, cudaMemcpyDeviceToHost, stream[ i ]);
I have difficulties to setup properly the above.
I am not sure about the streamsize etc.
I used another size (StreamSizeResult) for the devResult and another for devX and devY.
I am not sure how I can put it all together.Any help appreciated.
