I am trying to use multiple gpu on single. Here is the simple code. I encountered call to cuLaunchKernel returned error 400: Invalid handle
program test
use mpi
use openacc
implicit none
!usual mpi variables
integer :: mype, npes, ierr
integer :: status(MPI_STATUS_SIZE)
integer::ngpus,mydevice,a(10000),i
call MPI_Init(ierr)
call MPI_Comm_size(MPI_COMM_WORLD, npes, ierr)
call MPI_Comm_rank(MPI_COMM_WORLD, mype, ierr)
ngpus=acc_get_num_devices(acc_device_nvidia)
mydevice=mod(mype,ngpus)
call acc_set_device_num(mydevice,acc_device_nvidia)
print*,mydevice
!$acc kernels deviceid(mydevice)
do i=1,10000
a(i)=a(i)*2
end do
!$acc end kernels
call MPI_finalize(ierr)
end program test
Please help me, i have contest submission tomorrow night(less than 24 hrs)
Looks like a problem with “deviceid” which is an old PGI extension that isn’t used very much. I added a problem report (TPR#22703) and sent it off to engineering.
It’s not needed here since your setting the device number via “acc_set_device_num” so the solution is to simply remove “deviceid(mydevice)”.
% cat test.f90
program test
use mpi
use openacc
implicit none
call MPI_Init(ierr)
print*,mydevice
!$acc kernels
do i=1,10000
a(i)=a(i)*2
end do
!$acc end kernels
end program test
% mpif90 -acc -Minfo=accel test.f90
test:
23, Generating implicit copy(a(:))
24, Loop is parallelizable
Accelerator kernel generated
Generating Tesla code
24, !$acc loop gang, vector(128) ! blockidx%x threadidx%x
% mpirun -np 4 a.out
0
1
3
