I read in the user guide:
“A subroutine or function with the device attribute must appear within a Fortran module, and may only be called from device subprograms in the same module.”
Now, have been using this tutorial Account Login | PGI, to call the Mersenne Twister in the CUDA C examples from the cuda fortran code. But now I need to modify it so that the RandomGPU C global subroutine becomes a device subroutine. Il have included an INTERFACE in the fortran module were I want to call it from but I get the following error message:
PGF90-S-0155-Illegal call from device code to randomgpu_dev (test_my_twist.cuf: 17)
Is it possible at all to call a C device subroutine from the CUDA fortran code? Or am I doing something wrong?
Here is a relevant part of the code:
MODULE WHATEVER
USE CUDAFOR
INTERFACE
subroutine RandomGPU_dev(d_Rand, n_per_rng) bind(c,name='randomgpu_dev__entry')
use iso_c_binding
real(c_float), dimension(:) :: d_Rand
integer, value :: n_per_rng ! pass by value
end subroutine RandomGPU_dev
END INTERFACE
CONTAINS
ATTRIBUTES(GLOBAL) SUBROUTINE RNG_TEST()
real, dimension(10) :: Y
call randomgpu_dev(Y,5)
END SUBROUTINE RNG_TEST
END MODULE WHATEVER
