Is there any way to call a simple c function in global function?? If someone have some idea could please help me out. Otherwise I have change a lot …
“Is there any way to call a simple c function in global function??”
it really depends on what you mean by ‘simple c function’
you can call a device function from within a global function, but ‘terms and conditions’ apply
it would be a device function, within the context of the calling kernel, etc
what is it that you want/ need to do?
Thank you…
I have a header file for Simplex. So Is there any way out to call the simplex constructor in device function directly or all I have to change all related functions in the header file itself to device function…???
My main aim is to run two or more simplex in parallel…!!
If you have no qualifiers (or host, which is the same) , it’s like a normal method and you can call it from the host side.
If you qualify your constructor with device, you are be able to call it from device side.
If you qualify your constructor with both qualifiers, you’ll be able to call it on both sides.
“I have a header file for Simplex.”
"My main aim is to run two or more simplex in parallel…!! "
to be clear, by simplex you mean what exactly?
are you referring to the simplex algorithm/ method as part of LP?
Yes I am referring Simplex algorithm as a whole. I want make an parallel LPP solver library using simplex method. So for that I have a simplex.h file.
Thank you AlexIanevski
Yes …If I want to qualify the constructor with device, then for adding “device” this line to my header file, should I also be need to change the .h file to .cuh or what else I need to do??
i do not see how you would be able to simply take the simplex header file, and change a few qualifiers, in order to end up with a parallel platform implementation of what i take to be largely a serial platform implementation
you would lose out on a lot of performance gain that way too, i would think
noting 3 typical parallel classifications:
a) embarrassingly parallel; b) coarse grained; c) fine grained
you could first of all have thread blocks of a kernel jointly calculate and work on individual steps of (an iteration of) the simplex algorithm - in general, the next vertex to step to
thereafter, you could implement a next tier of parallelization, by implementing a number of (similar/ identical) kernels, each with a different starting point - in essence, both implementing a grain parallelization as well as an embarrassingly parallel implementation
the parallel kernels can signal via global memory when they have found the optimal solution, such that the kernels know when to terminate
this way, you may arrive at the global solution quicker
if the simplex algorithm executes in polynomial time, n parallel executions thereof may finish execution in (polynomial time / n) under ideal conditions, also provided that you have spare processing power (my take is that on a gpu workhorse, you would)
Ok…
Can you then in this regard help me how to use ublas library for matrices and vectors???
[b]Maybe i am missing what you are saying
you were referring to a header file, and mentioned making a parallel lp solver library, so i took it that you have a host simplex algorithm implementation as reference
i would also argue that the simplex algorithm includes matrices and vectors, but is not confined to mere matrices and vectors
adding additional layers of parallelization would of course require a deep(er) understanding of the algortihm as prerequisite
[/b]
could you affirm the current simplex ‘source’/ reference you are working from, such that it is easier to follow exactly where you are in terms of your implementation
i am currently under the impression that you are working from a host simplex implementation; could you confirm or refute this
if that is the case, representing the lp feasible region in matrix form is well documented
also, moving such a representation to standard form is also well documented
selecting the next pivot as part of the simplex algorithm is also documented, generally consists of matrix operations, and may be something you can utilize the said libraries for
the libraries are well documented
as a more advanced level, to move to multiple parallel implementations, you need duplicate the feasible region standard matrix representations, and need to select - or force - different starting pivots per implementation, to get different starting points
and you would likely need to use streams to implement such a design
The following is my simplex.hpp
//#include “simplex.h”
#include
#include
#include
#include “math/matrix.h”
bool maybe_equal(double x, double y){
double tol = 1e6; // precision op to 6 decimal places
double xt= 1= xtol;
double yt = ytol;
template
simplex::simplex() {
max_iters=50;
dim = 0;
template
simplex::~simplex() {
//dtor
template
void simplex::pivot(int e, int lv) {
std::cout << “pivot called with entering var =” << e << "leaving var = "
<< lv << std::endl;
// Compute the coefficeints of the equation for new basic variables x_e
math::matrix Anew(As.size1(), As.size2());
std::vector bnew(bs.size(), 0);
//std::cout << "As(lv,e) = " << As(lv,e) << std::endl;
assert(As(lv, e) != 0);
bnew[e] = bs[lv] / As(lv, e);
std::cout << " bs[lv] = " << bs[lv] << " As[lv,e] = " << As(lv, e)
<< "bnew[e] = " << bnew[e] << std::endl;
typename std::set<int>::iterator it, it1;
for (it = N.begin(); it != N.end(); it++) {
if (*it == e)
continue;
int j = *it;
Anew(e, j) = As(lv, j) / As(lv, e);
// std::cout<<" Anew(e, j) = " << Anew(e, j) <<std::endl;
Anew(e, lv) = 1 / As(lv, e);
// Compute the coefficients of the remaining constraints
for (it = B.begin(); it != B.end(); it++) {
int i = *it;
if (i == lv) {
for (int entire_row = 0; entire_row <= B.size() + N.size();
entire_row++) // Amit
Anew(lv, entire_row) = 0;//Amit entire row for the leaving variable coefficient set to 0
continue;
bnew[i] = bs[i] - As(i, e) * bnew[e];
for (it1 = N.begin(); it1 != N.end(); it1++) {
int j = *it1;
if (j == e) {
Anew(i, e) = 0; //AMIT for the same entering variable, coefficient is set to 0
continue;
Anew(i, j) = As(i, j) - As(i, e) * Anew(e, j);
std::cout << " Anew(i, j) = " << Anew(i, j) << std::endl;
Anew(i, lv) = -1 * As(i, e) * Anew(e, lv);
Anew(i, i) = 0; //AMIT for the same basic variable, coefficient is set to 0
std::cout << " Anew(i, lv) AMIT = " << Anew(i, lv) << std::endl;
std::cout << "state of the constraints matrix Amit Check here\n";
for (int i = 1; i < Anew.size1(); i++) {
for (int j = 1; j < Anew.size2(); j++)
std::cout << Anew(i, j) << " ";
std::cout << std::endl;
// Compute the objective function
obj_val = obj_val + cs[e] * bnew[e];
//std::vector<T> cnew(dim + 1, 0);
std::vector<T> cnew(cs.size(), 0); //Code tried by Amit
int j = *it1;
if (j == e)
continue;
/*std::cout << "cs at " << j << " = " << cs[j] << std::endl;
std::cout << "cs at e =" << cs[e] << std::endl;
std::cout << "As at e,j = " << As(e,j) << std::endl; */
cnew[j] = cs[j] - cs[e] * Anew(e, j);
cnew[lv] = -1 * cs[e] * Anew(e, lv);
// Compute new sets of basic and nonbasic variables
cs = cnew;
As = Anew;
bs = bnew;
N.erase(e);
N.insert(lv);
B.erase(lv);
B.insert(e);
Converts the LP problem from Standard form to Slack form, initialises the data structures
to be used by the simplex algorithm. The slack form is such that the initial basic solution
is feasible. The function stops if the lp is infeasible or unbounded with a proper message.
template
void simplex::initialize() {
obj_val = 0;
int M = A.size1(); // Number of constrains in the LP.
int D = A.size2(); // Number of variables of the LP.
dim = M + D;
// set variable 1 to N as the non-basic variables
for (unsigned int i = 1; i <= D; i++)
N.insert(i);
//set variables N+1 to M as the basic variables (the slack variables)
for (unsigned int i = 1; i <= M; i++)
B.insert(D + i);
// A larger coefficient matrix, constants vector, objective vector defined
As = math::matrix(dim + 1, dim + 1);
bs = std::vector(dim + 1, 0);
cs = std::vector(dim + 1, 0);
// populate the members of the As matrix, bs vector
typename std::set::iterator it;
assert(B.size() == b.size());
// As,bs,cs are initialised as 1 index arrays from A,b,c
int i = 0;
for (it = B.begin(); it != B.end(); it++, i++) {
int m = *it;
for (unsigned int j = 0; j < D; j++) {
As(m, j + 1) = A(i, j);
bs[m] = b[i];
cs[*it] = c[*it - 1];
template
void simplex::display_state() {
std::cout << “state of the simplex :\n”;
std::set::iterator it1;
std::cout << “Non basic variables:\n”;
std::cout << *it1 << std::endl;
std::cout << “Basic variables:\n”;
for (it1 = B.begin(); it1 != B.end(); it1++) {
std::cout << “\nSize of the Total Variable : “<<cs.size()<<”\n”;
std::cout << “objective function coefficients:\n”;
for (int i = 1; i < cs.size(); i++)
std::cout << cs[i] << std::endl;std::cout << “constants:\n”;
for (int i = 1; i < bs.size(); i++)
std::cout << bs[i] << std::endl;std::cout << “state of the constraints matrix\n”;
for (int i = 1; i < As.size1(); i++) {
for (int j = 1; j < As.size2(); j++)
std::cout << As(i, j) << " ";
std::cout << "Objective function value at current iteration = " << obj_val
<< std::endl;
std::cout
<< “============================================================= \n”;
template
std::vector simplex::solve() {
int n = N.size() + B.size();
std::vector x(n, 0);
/* //Amit:: Debug
for (unsigned int i = 1; i <= n; i++) {
std::cout << "Debug Amit :: delta at Creation " << i << " = " << delta[i] << std::endl;
int e, l, iters = 0;
//typename std::set::iterator it, it1,it2;
// start solving with simplex algorithm
while (iters <= max_iters) {
std::vector<T> delta(n + 1, INT_MAX); //AMIT : this declaration should be inside the loop to see the INT_MAX changes reflect
e = -1;
for (std::set<int>::iterator it = N.begin(); it != N.end(); it++) {
if (cs[*it] <= 0)
continue;
e = *it;
//std::cout << "Adding entering var =" << e << ", as cs[e] = " << cs[e] << std::endl;
break;// after choosing the entering variable, find the leaving variable
if (e == -1) {
for(IT = B.begin(); IT!=B.end();IT++){
x[*IT] = bs[*IT];
// std::cout << "Landed inside exit condition\n";
break;// break from the while loop;
} else {
std::cout << "The entering variable is " << e << std::endl;
for (std::set<int>::iterator it2 = B.begin(); it2 != B.end();
it2++) {
int i = *it2;
if (As(i, e) > 0) {
delta[i] = bs[i] / As(i, e);
std::cout << "delta at var " << i << " = " << delta[i]
<< std::endl;
std::cout << "bs at " << i << " = " << bs[i] << std::endl;
std::cout << "As at i,e" << "= " << As(i, e) << std::endl;
//std::cout << "Amit: Coefficient at " << i << " = " << As(i, e)<<"\n";
double min = INT_MAX;
//Amit:: Debug
std::cout << "Debug Amit :: delta at var " << i << " = " << delta[i] << std::endl;
if (delta[i] < min) {
min = delta[i];
l = i;
std::cout << "min delta = " << min << std::endl;
std::cout << "leaving variable = " << l << std::endl;
if (min == INT_MAX) {
std::cout << "Unbounded LP";
exit(0);
} else {
std::cout << "simplex state BEFORE calling pivot from solve:\n";
//display_state();binayak
pivot(e, l);
std::cout << "simplex state AFTER calling pivot from solve:\n";
std::cout << "simplex state after pivoting\n" << std::endl;
display_state();
iters++; // one simplex iteration complete
} // end of while
return x;
template
void simplex::process_lp() {
unsigned int k, m, n;
for (unsigned int i = 0; i < b.size(); i++) {
if (b[i] < min) {
min = b[i];
k = i;
if (b[k] >= 0) {
initialize();
// std::cout << “LP processed\n”;
return;
k = k + 1; // since we start indexing arrays at 1 in our simplex implementation
m = A.size1(); // no. of constraints of the LP
n = A.size2(); // no. of variables in the LP
std::cout << “k= " << k << " m =” << m << ", n = " << n << std::endl;
std::vector<T> x(m + n, 0);
bool flag = false;
math::matrix<T> Anew(m, n + 1); // no. of vars is with the added extra variable of the auxiliary LP.
c.resize(n + 1);
for (unsigned int i = 0; i < m; i++) {
for (unsigned int j = 0; j < n; j++) {
Anew(i, j) = A(i, j);
if (!flag) // if c not yet changed to the obj of L_aux, then change it
c[j] = 0;
Anew(i, n) = -1;
flag = true;
c[n] = -1;
A = Anew;
// * debug purpose
std::cout << "Anew matrix\n" << std::endl;
for (unsigned int i = 0; i < A.size1(); i++) {
for (unsigned int j = 0; j < A.size2(); j++) {
std::cout << A(i, j) << " ";
std::cout << "elements of cnew\n" << std::endl;
for (unsigned int i = 0; i < c.size(); i++) {
std::cout << c[i] << std::endl;
std::cout << "elements of bnew\n" << std::endl;
std::cout << b[i] << std::endl;
initialize(); // get the slack form
// std::cout << “Printing After Initialize\n” << std::endl;
int lv = N.size() + k; // set the leaving variable
int e = N.size(); // the entering variable is the var added in the Auxiliary LP.
std::cout << "leaving = " << lv << ", entering = " << e << std::endl;
std::cout << "Before pivot Call\n";
pivot(e, lv); //Data Mismatch for matrix A detected here
//display_state();
std::cout << "After first pivot successful\n";
solve(); // run simplex on the previously obtained slack form. it is guaranteed that the initial basic solution is feasible.
std::cout << "process_lp: reached after call to solve auxiliary LP"
<< std::endl;
if (get_obj_val() == 0) { // To be changed to check the value of x[e], e being the index of the auxiliary variable
//if(x[lv] == 0) // the aux variable of the lp_aux has value 0 in the optimal vector
int en;
//std::cout<<"Amit:: x0 is lv = "<< lv <<" or e = "<< e <<std::endl;
for (std::set<int>::iterator it = B.begin(); it != B.end(); it++) {
if (*it == e) { // aux variable as basic variable
for (std::set<int>::iterator it1 = N.begin(); it1 != N.end();
it1++) {
if (As(e, *it1) != 0) {
en = *it1;
break;
pivot(en, e);
std::cout << "STATE BEFORE RESTORING TO ORIGINAL OBJECTIVE FUNCTION\n";
//Anew = math::matrix<T>(As.size1() - 1, As.size2() - 1);
Anew.resize(As.size1() - 1, As.size2() - 1); //AMIT resizing the array
std::vector<T> bnew(bs.size() - 1, 0);
std::vector<T> cnew(cs.size() - 1, 0);
// remove the row and column for the auxiliary variable from As
int row = 0;
for (unsigned int i = 1; i < As.size1(); i++) {
if (i == e) {
continue;
row++;
int k = 1;
for (unsigned int j = 1; j < As.size2(); j++) {
if (j != e) {
Anew(row, k) = As(i, j);
k++;
//AMIT debug
std::cout<<"debugging \n";
for (int x=1;x<Anew.size1();x++){
for (int y=1;y<Anew.size2();y++)
std::cout<<"Anew(x,y) = "<<Anew(x,y)<<"\t";
std::cout<<std::endl;
int k = 1;
if (j != e) {
bnew[k] = bs[j];
k++;
As = Anew;
bs = bnew;
T v = T(0);
T alpha;
for (unsigned int i = 0; i < c_orig.size(); i++) {
cnew[i + 1] = c_orig[i];
std::cout << "STATE AFTER RESTORING THE ORIGINAL OBJECTIVE FUNCTION\n";
//debug
// std::cout << “values at cnew\n”;
// for(unsigned int i=1;i<cnew.size();i++)
// std::cout << cnew[i] << std::endl;
//std::cout << "Value of new objective functions = " << std::endl;
for (unsigned int i = 1; i < cnew.size(); i++) {
if (cnew[i] != 0) {
for (typename std::set::iterator iter = B.begin();
iter != B.end(); iter++) {
if (*iter == i) {
alpha = cnew[i];
cnew[i] = 0;
cnew[j] += -As(i, j) * alpha;
std::cout << “Amit::” << cnew[j] << std::endl;
std::cout << “end of new obj function\n” << std::endl;
v += bs[i] * alpha;
iter = B.end();
break;
//AMIT debug
std::cout << "values at cnew\n";
cs = cnew;
/* Debug::
//AMIT: Now resize cs as size - 1 for removing auxiliary variable
std::cout<<“Amit Gurung :: cs Size BEFORE = “<<cs.size()<<”\n”;
cs.resize(cs.size() - 1);
std::cout<<“Amit Gurung :: cs Size AFTER = “<<cs.size()<<”\n”;
//AMIT debug
std::cout << "values at cs after copying\n";
for(unsigned int i=1;i<cs.size();i++)
std::cout << "Value of new objective function = " << v << std::endl;
obj_val = v;
N.clear();
B.clear();
int D = c_orig.size();
N.insert(i);
for (unsigned int i = 1; i <= A_orig.size1(); i++)
B.insert(D + i);
//Code tried by :: AMIT
std::set<int> tempN, tempB; // .
tempN = N;
tempB = B;
N.clear();
B.clear();
for (typename std::set<int>::iterator iter = tempN.begin();
iter != tempN.end(); iter++) {
if (*iter == e) { //e is the x0 variable or the auxiliary variable
continue; //skiping or removing the auxiliary variable
//Inserting/Renaming the remaining variable but if the variables are greater than auxiliary variable name/index subtracted by 1
if (*iter > e)
N.insert(*iter - 1); //requires variable renaming
else
N.insert(*iter); //Does Not requires variable renaming
for (typename std::set<int>::iterator iter = tempB.begin();
iter != tempB.end(); iter++) {
//Inserting/Renaming the variable but if the variables are greater than auxiliary variable name/index subtracted by 1
if (*iter > e)
B.insert(*iter - 1); //requires variable renaming
else
B.insert(*iter); //Does Not requires variable renaming
std::cout << "LP processed\n";
//display_state(); binayak
std::cout<<"\n===============Initialize Simplex Call Over=====================\n";
} else {
std::cout << "Simplex::process_lp: LP has infeasible solution\n";
exit(0);
If I be able to use ublas libray in cuda progarmming, then I may able to make the same LP Solver using simplex on my own in cuda.
Some questions for Binaryak:
Do you understand the simplex algorithm ? Are you capable of writing one from scratch ?
I assume you do not yet know how to program CUDA or parallel solutions suited for cuda ?
Why do you want to run two simplex algorithms at the same time ? (most interesting question)
Have you tried to parallelize the simplex algorithm ?
Do you think the simplex algorithm can be parallelized ?
“Why do you want to run two simplex algorithms at the same time ? (most interesting question)”
why wouldn’t you?
if you can cut the feasible region, similar to a cut and branch approach, you would be able to run multiple instances on the same overall feasible region
i was under the impression that the simplex algorithm’s performance - or simply calculation time - is dependent on the starting point
with multiple instances - the feasible region cut into smaller regions - you should have multiple starting points, and thus potentially better odds
particularly when you have a plethora of lp coefficients
not so?
Answer to question 1. I went through the algorithm, I know it is working. I can write a Simplex program by using this same algorithm from book(Introduction to Algorithm by Thomas H. Cormen)
Answer to question 2. Yes I am new in cuda programming, Just came now to learn Cuda for my this work only.
Answer to question 3. I don’t know the answer right now. I just my expert has a tool and that tool needs a Parellel LPP solver
Answer to question 4. Why not? Yes It’s possible…And I’ll have to do the same. Its my work now on me…
Thank you :)
