Currently I am working in a camera project with the following setup:
- Jetson AGX Xavier Developer Kit
- GMSL2 (Serializer: MAX9295, Deserializer: MAX96712)
- Camera AR0234
I have 3 cameras connected to a single deserializer. The drivers are working for ser/des and for the camera.
However I am having the following behavior:
1- Load the driver, capture with v4l2-ctl from 3 cameras simultaneously works correctly, stop capture, restart capture works correctly.
2- Load the driver, capture with v4l2-ctl from 3 cameras simultaneously works correctly, stop capture, try to capture from GStreamer using nvarguscamerasrc, does not work. The pipeline just hangs and no frames are received.
3- Load the driver, capture with GStreamer using nvarguscamerasrc from 3 cameras simultaneously works correctly, stop capture, try to capture again with GStreamer using nvarguscamerasrc, does not work. The pipeline just hangs and no frames are received.
Conclusion: After the first capture, no matter the method, capture again from nvarguscamerasrc is failing. If the first capture is with v4l2-ctl I can stop and restart the capture without problems.
---- Logs -----
Log from nvargusdaemon (correct first capture with GStreamer):
root@localhost:/home/nvidia# /usr/sbin/nvargus-daemon
=== NVIDIA Libargus Camera Service (0.97.3)=== Listening for connections...=== gst-launch-1.0[8659]: Connection established (7FABF8E1D0)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module3
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: virtual device driver node not found in proc device-tree: /proc/device-tree/tegra-virtual-camera-platform/modules/module0/drivernode1
OFParserGetVirtualDevice: virtual device driver node not found in proc device-tree: /proc/device-tree/tegra-virtual-camera-platform/modules/module1/drivernode0
---- imager: No override file found. ----
LSC: LSC surface is not based on full res!
=== gst-launch-1.0[8659]: CameraProvider initialized (0x7fa4964a20)LSC: LSC surface is not based on full res!
=== gst-launch-1.0[8659]: CameraProvider destroyed (0x7fa4964a20)=== gst-launch-1.0[8659]: Connection closed (7FABF8E1D0)=== gst-launch-1.0[8659]: Connection cleaned up (7FABF8E1D0)
Log from nvargusdaemon (failed second capture with GStreamer):
=== NVIDIA Libargus Camera Service (0.97.3)=== Listening for connections...=== gst-launch-1.0[8759]: Connection established (7F8A6191D0)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
=== gst-launch-1.0[8759]: CameraProvider initialized (0x7f84b85ed0)LSC: LSC surface is not based on full res!
(NvCapture) Error Timeout: capture waiting for status timeout (in /dvs/git/dirty/git-master_linux/camera/capture/nvcapture/capture_hw_linux.c, function NvCaptureLinuxGetCaptureStatus(), line 362)
(NvCapture) Error Timeout: (propagating from /dvs/git/dirty/git-master_linux/camera/capture/nvcapture/capture.c, function NvCaptureDequeue(), line 1055)
SCF: Error Timeout: (propagating from src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 851)
SCF: Error InvalidState: Timeout waiting on frame end sensor guid 0, capture sequence ID = 1, channel = 1/1 (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 858)
SCF: Error InvalidState: Something went wrong with waiting on frame end (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 939)
SCF: Error InvalidState: Timeout waiting on frame start sensor guid 0, capture sequence ID = 1 (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 966)
SCF: Error InvalidState: Something went wrong with waiting on frame start (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 1021)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceDeviceViCsi.cpp, function waitCompletion(), line 335)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceDevice.cpp, function pause(), line 938)
SCF: Error Timeout: During capture abort, syncpoint wait timeout waiting for current frame to finish (in src/services/capture/CaptureServiceDevice.cpp, function handleCancelSourceRequests(), line 1032)
PowerServiceCore:handleRequests: timePassed = 3030
SCF: Error InvalidState: Timeout waiting on frame end sensor guid 0, capture sequence ID = 4, channel = 1/1 (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 858)
SCF: Error InvalidState: Timeout waiting on frame start sensor guid 0, capture sequence ID = 4 (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 966)
PowerServiceCore:handleRequests: timePassed = 1506
If any other log information is needed, please let me know.
Regards,
Fabian
www.ridgerun.com
