I am working on a real-time object detection project in my company, and we plan to use YOLO for inference on multiple IP cameras. Currently, we do not have an on-premise GPU server, so we are considering purchasing a system equipped with an NVIDIA A100 GPU with this, I’m going to run the llm model in the future.
Our goal is to run 8 separate IP camera streams, each at:
Resolution: 1920 × 1080
Target inference speed: 30 FPS
Model: YOLOv11-L (Ultralytics)
Before making a purchase, I would like to confirm the following:
1. Can a single A100 GPU run 8 YOLOv11-L models in parallel at 1080p 30FPS?
If anyone has benchmark experience with YOLOv8/L11-L on A100, I would appreciate performance guidance—especially regarding GPU throughput, memory usage, and expected real-time stability across 8 streams.
2. If the A100 cannot reliably support this load, what edge system would you recommend?
We are open to alternatives such as:
Jetson AGX Orin industrial edge PCs
x86-based industrial computers with RTX A2000/A4000
Any proven hardware configuration capable of handling 8 channels of 1080p YOLO inference at 30FPS
If possible, we prefer a design suitable for factory environments.
Any recommendations, benchmarks, or architectural guidance would be extremely helpful.
Thank you in advance for your support.
