When I compile the following code containing the design C++11, in Windows7x64 (MSVS2012 + Nsight 2.0 + CUDA5.5), then I do not get errors, and everything compiles and works well:
#include <thrust/device_vector.h>
int main() {
thrust::device_vector<int> dv(10);
auto iter = dv.begin();
return 0;
But when I try to compile it under the Linux64 (Debian 7 Wheezy + Nsight Eclipse from CUDA5.5), I get errors:
../src/CudaCpp11.cu(5): error: explicit type is missing ("int" assumed)
../src/CudaCpp11.cu(5): error: no suitable conversion function from
"thrust::detail::normal_iterator>" to "int" exists
2 errors detected in the compilation of "/tmp/tmpxft_00001520_00000000-6_CudaCpp11.cpp1.ii". make: * [src/CudaCpp11.o] Error 2
When I added line:-stdc++11
in Properties-> Build-> Settings-> Tool Settings-> Build Stages-> Preprocessor options (-Xcompiler)
I get more errors:
/usr/lib/gcc/x86_64-linux-gnu/4.8/include/stddef.h(432): error: identifier "nullptr" is undefined
/usr/lib/gcc/x86_64-linux-gnu/4.8/include/stddef.h(432): error: expected a ";"
/usr/include/c++/4.8/bits/cpp_type_traits.h(314): error: namespace "std::__gnu_cxx" has no member
"__normal_iterator"
/usr/include/c++/4.8/bits/cpp_type_traits.h(314): error: expected a ">"
nvcc error : 'cudafe' died due to signal 11 (Invalid memory reference) make: * [src/CudaCpp11.o] Error 11
Only when I use thrust::device_vector::iterator iter = dv.begin(); in Linux-GCC then I do not get an error. But in Windows MSVS2012 all c++11 features works fine!
Can I use C++11 in the .cu-files (CUDA5.5) in Windows7x64 (MSVC) and Linux64 (GCC4.8.2)?
GCC 4.7.2 has the same effect - can’t compile C++11 in nvcc+gcc. Or nevertheless how can I do this, or can I use C++11 in nvcc+icc(Intel Compiler)?
