Can I use STL containers inside kernels (of course in emulation mode)?
I tried using std::map, but there were strange errors:
1>c:/Users/HP/Documents/Visual Studio 2008/Projects/CUDA/CUDAFiles/TrainNetwork.cu(30) : error C2065: ‘_ZN9CUDATools20m_mapAllocatedMemoryE’ : undeclared identifier
1>c:/Users/HP/Documents/Visual Studio 2008/Projects/CUDA/CUDAFiles/TrainNetwork.cu(30) : error C2228: left of ‘.__b_St5_TreeISt12_Tmap_traitsIPviSt4lessIS1_ESaISt4pair
IKS1_iEELb0EEE’ must have class/struct/union
1> type is ‘‘unknown-type’’
Is there some special configuration needed?
When I include files containing only declarations of STL containers, compilation works OK. But I can’t use these containers.
I don’t believe so. If you have host side code which uses a lot of stl container types, then one way to use them with CUDA is via the thrust library, which provides a lot of useful C++ host side CUDA functionality in the style of the STL.
I think that this library is not for me. It is used from the host code to perform some algorithms on GPU. I want something else - use STL containers inside kernel code…
u can use any regular c++ libraries and code in emulation mode. but if you want to run it on the gpu then you can’t. the way around that is to use ifdef statements
Emulation mode is not terribly well supported, and tmurray has regularly stated that he wants to see it dropped (meanwhile, a number of us would like to see ‘emulation’ mode become a proper multicore x86 backend). I’ve found that even just can confuse the emulator, so more advanced things could certainly cause more trouble.
