Can I write a plugin that only support INT8 implementation in TensorRT?
Description
I want to write a plugin that only support int8 in/out, so I here is my code in supportsFormatCombination.
Given conv2d as an example
bool GroupConv2dPlugin::supportsFormatCombination(
    int32_t pos, const nvinfer1::PluginTensorDesc* inOut, int32_t nbInputs,
    int32_t nbOutputs) noexcept {
  // support
  // input = filter = output = int8, bias = float, input, filter, output format = ncxhwx<32>
  if (pos == 0) {
    return ((inOut[pos].type == nvinfer1::DataType::kINT8 && inOut[pos].format == nvinfer1::TensorFormat::kCHW32));
  // // bias
  if (pos == 2) {
    return (inOut[0].type == nvinfer1::DataType::kINT8 && inOut[pos].type == nvinfer1::DataType::kFLOAT && inOut[pos].format == nvinfer1::TensorFormat::kLINEAR);
// filter and output
  return inOut[pos].type == inOut[0].type &&
          inOut[pos].format == inOut[0].format;
And when I want to build engine using tensorrt python API with those codes
# get onnx model
torch.onnx.export(
           module.float(),   # including my own plugin
            args,
            path,
            input_names=list(inputs.keys()),
            output_names=list(module.output_shapes.keys()),
            opset_version=opset_version,
            operator_export_type=OperatorExportTypes.ONNX_FALLTHROUGH,
# from onnx to engine
TRT_LOGGER = trt.Logger(trt.Logger.VERBOSE)
EXPLICIT_BATCH = 1 << int(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH)
def build_engine(
    onnx_file,
    int8=False,    # True in my case
    fp16=False,  # False in my case
    max_workspace_size=1,
    calibrator=None,
    """Takes an ONNX file and creates a TensorRT engine to run inference with"""
    with trt.Builder(TRT_LOGGER) as builder, builder.create_network(
        EXPLICIT_BATCH
    ) as network, builder.create_builder_config() as config, trt.OnnxParser(
        network, TRT_LOGGER
    ) as parser, trt.Runtime(
        TRT_LOGGER
    ) as runtime:
        config.profiling_verbosity = trt.ProfilingVerbosity.DETAILED
        # max_workspace_size GB
        config.set_memory_pool_limit(
            trt.MemoryPoolType.WORKSPACE, (1 << 32) * max_workspace_size
        # Parse model file
        if not parser.parse(onnx_file.read()):
            for error in range(parser.num_errors):
                print(parser.get_error(error))
            return None
        if int8:
            config.set_flag(trt.BuilderFlag.INT8)
            config.int8_calibrator = calibrator
        if fp16:
            config.set_flag(trt.BuilderFlag.FP16)
        plan = builder.build_serialized_network(network, config)
        engine = runtime.deserialize_cuda_engine(plan)
        return engine
However, I get a None type returned by builder.build_serialized_network, with those errors
From TRT LOG
[06/18/2024-07:38:42] [TRT] [I] Timing cache disabled. Turning it on will improve builder speed.
[06/18/2024-07:38:42] [TRT] [V] Constructing optimization profile number 0 [1/1].
[06/18/2024-07:38:42] [TRT] [E] 9: [pluginV2Builder.cpp::reportPluginError::23] Error Code 9: Internal Error (/$MYPLUGIN: could not find any supported formats consistent with input/output data types)
[06/18/2024-07:38:42] [TRT] [E] 2: [builder.cpp::buildSerializedNetwork::751] Error Code 2: Internal Error (Assertion engine != nullptr failed. )
Then python errors:
onnx_file = <_io.BufferedReader name='/tmp/tmp50t98b9f'>, int8 = True, fp16 = False,
max_workspace_size = 1, calibrator = <tests.common.utils.Calibrator object at 0x7f078d419770>
    def build_engine(
        onnx_file,
        int8=False,
        fp16=False,
        int8_fp16=False,
        calibrator=None,
            EXPLICIT_BATCH
            network, TRT_LOGGER
            TRT_LOGGER
        ) as runtime:
            # Parse model file
                return None
            if int8:
            if fp16:
E           TypeError: deserialize_cuda_engine(): incompatible function arguments. The following argument types are supported:
E               1. (self: tensorrt.tensorrt.Runtime, serialized_engine: buffer) -> tensorrt.tensorrt.ICudaEngine
E
E           Invoked with: <tensorrt.tensorrt.Runtime object at 0x7f07707848b0>, None
Environment
TensorRT Version: 8.5.3
GPU Type: RTX 4090
Nvidia Driver Version: 545.23.08
CUDA Version: 11.8
Operating System + Version: ubuntu 22.04
Python Version (if applicable): 3.8.10
PyTorch Version (if applicable): 2.3
Question
When I add float implementation, Those errors gone. So I was wondering can I write a plugin that only support int8. Or I make some mistake when building trt engines
Seems caused by Calibrator
In case of someone have same problem
