Can multiple CUDA contexts share an inference engine?
Description
I am trying to do inference with TensorRT in a multi-threaded Python environment.
I generate a CUDA context for each sub-thread (cuda.Device(0).make_context()) and an execution context (engine.create_execution_context()).
The inference engine for generating the execution context is deserialized in the main thread and shared with the subthreads.
However, this method causes an error.
It works well if the inference engine is deserialized for each execution context.
Do I need to generate an inference engine for each CUDA context?
I am using the following as a reference for testing with modifications.
Please point out if my understanding of this matter is incorrect and provide pointers to the documents.
Your support is sincerely appreciated.
import threading
import time
from my_tensorrt_code import TRTInference, trt
exitFlag = 0
class myThread(threading.Thread):
   def __init__(self, func, args):
      threading.Thread.__init__(self)
      self.func = func
      self.args = args
   def run(self):
      print ("Starting " + self.args[0])
      self.func(*self.args)
      print ("Exiting " + self.args[0])
if __name__ == '__main__':
    # Create new threads
    format thread:
        - func: function names, function that we wished to use
        - arguments: arguments that will be used for the func's arguments
    trt_engine_path = 'mnist.trt'
    TRT_LOGGER = trt.Logger(trt.Logger.INFO)
    trt.init_libnvinfer_plugins(TRT_LOGGER, '')
    runtime = trt.Runtime(TRT_LOGGER)
    # deserialize engine
    with open(trt_engine_path, 'rb') as f:
        buf = f.read()
        engine = runtime.deserialize_cuda_engine(buf)
    max_batch_size = 1
    trt_inference_wrapper = TRTInference(engine,
        trt_engine_datatype=trt.DataType.FLOAT,
        batch_size=max_batch_size)
    # Get TensorRT SSD model output
    input_img_path = '/mnt/ogasawara/teams/rd/inoue67/tmp/TensorRT-10.6.0.26/data/mnist/3.pgm'
    thread1 = myThread(trt_inference_wrapper.infer, [input_img_path])
    # Start new Threads
    thread1.start()
    thread1.join()
    trt_inference_wrapper.destory();
    print ("Exiting Main Thread")
from PIL import Image
import numpy as np
import tensorrt as trt
import pycuda.autoinit
import pycuda.driver as cuda
import threading
import time
import math
class TRTInference:
    def __init__(self, engine, trt_engine_datatype, batch_size):
        self.cfx = cuda.Device(0).make_context()
        stream = cuda.Stream()
        context = engine.create_execution_context()
        # prepare buffer
        host_inputs  = []
        cuda_inputs  = []
        name_inputs  = []
        host_outputs = []
        cuda_outputs = []
        name_outputs = []
        bindings = []
        for binding in engine:
            size = trt.volume(engine.get_tensor_shape(binding))
            host_mem = cuda.pagelocked_empty(size, np.float32)
            cuda_mem = cuda.mem_alloc(host_mem.nbytes)
            bindings.append(int(cuda_mem))
            if engine.get_tensor_mode(binding) == trt.TensorIOMode.INPUT:
                host_inputs.append(host_mem)
                cuda_inputs.append(cuda_mem)
                name_inputs.append(binding)
            else:
                host_outputs.append(host_mem)
                cuda_outputs.append(cuda_mem)
                name_outputs.append(binding)
        # store
        self.stream  = stream
        self.context = context
        self.engine  = engine
        self.host_inputs = host_inputs
        self.cuda_inputs = cuda_inputs
        self.name_inputs = name_inputs
        self.host_outputs = host_outputs
        self.cuda_outputs = cuda_outputs
        self.name_outputs = name_outputs
        self.bindings = bindings
    def infer(self, input_img_path):
        self.cfx.push()
        # restore
        stream  = self.stream
        context = self.context
        engine  = self.engine
        host_inputs = self.host_inputs
        cuda_inputs = self.cuda_inputs
        name_inputs = self.name_inputs
        host_outputs = self.host_outputs
        cuda_outputs = self.cuda_outputs
        name_outputs = self.name_outputs
        bindings = self.bindings
        # read image
        image = 1 - (np.asarray(Image.open(input_img_path), dtype=np.float32)/255)
        np.copyto(host_inputs[0], image.ravel())
        # inference
        start_time = time.time()
        for i, name in enumerate(name_inputs):
            context.set_tensor_address(name, cuda_inputs[i])
        for i, name in enumerate(name_outputs):
            context.set_tensor_address(name, cuda_outputs[i])
        cuda.memcpy_htod_async(cuda_inputs[0], host_inputs[0], stream)
        context.execute_async_v3(stream_handle=stream.handle)
        cuda.memcpy_dtoh_async(host_outputs[0], cuda_outputs[0], stream)
        stream.synchronize()
        print("execute times "+str(time.time()-start_time))
        # parse output
        output = np.array([math.exp(o) for o in host_outputs[0]])
        output /= sum(output)
        for i in range(len(output)): print("%d: %.2f"%(i,output[i]))
        self.cfx.pop()
    def destory(self):
        self.cfx.pop()
Environment
TensorRT Version: 10.6
GPU Type: RTX 4070 Ti
Nvidia Driver Version: 535.154.05
CUDA Version: 12.2
Python Version (if applicable): 3.9
To address your concerns regarding the use of multiple CUDA contexts sharing an inference engine in TensorRT in a multi-threaded Python environment, here are several key points and recommendations to consider:
Key Insights
  1. Multiple Execution Contexts:
    • TensorRT allows for multiple execution contexts to be created from a single inference engine. Each context can handle its own input and output buffers for simultaneous inference tasks.
  2. CUDA Context Management:
    • Each thread can create its own CUDA context. However, TensorRT is designed to use the same execution context for multiple CUDA contexts when inference engines are shared. You must ensure proper management of these contexts.
  3. Buffer Management:
    • When passing input and output buffers for inference, you need to handle them carefully. Each execution context manages its memory, making it crucial to pass the correct data buffers for inference.
  4. Dynamic Shapes and Input Management:
    • If your engine supports dynamic input shapes, make sure to set the input shapes appropriately using setInputShape, as you mentioned.
  5. Thread-Safe Execution:
    • Accessing TensorRT objects from multiple threads can cause race conditions or access violations unless properly synchronized. Each thread should manage its own execution context and CUDA context where possible.
Recommendations for Your Implementation
  1. Single CUDA Context:
    • Instead of creating a new CUDA context for each thread, consider sharing a single CUDA context across threads if feasible. It can simplify resource management and might yield better performance by reducing context-switching overhead.
  2. Creating Execution Contexts:
    • Create execution contexts from your TensorRT engine in the main thread and share them among the worker threads. Each thread can then use its own CUDA context but refer back to the shared execution context.
  3. Synchronization:
    • Use mutexes or other synchronization mechanisms to avoid simultaneous access to the inference engine or execution context from multiple threads.
  4. Profiling and Tuning:
    • Profile the performance of your multi-threading setup to identify bottlenecks. Optimize based on the findings, adjusting the number of threads, execution context sharing, and memory usage strategies.
  5. Refer to Documentation:
    • Review TensorRT documentation to understand more about execution context management, memory handling, and multithreading best practices. NVIDIA’s developer forums can also provide insights and shared experiences from other developers.
Example Workflow
Here’s a potential workflow for your implementation based on your description:
  • Master Thread:
    • Deserialize the TensorRT engine.
    • Create a shared CUDA context.
    • Create execution contexts from the engine.
  • Worker Threads:
    • Restore the shared CUDA context.
    • Use the shared execution context for inference.
    • Manage buffers and run inference.
    • Cleanup the thread’s resources after inference:
# Pseudocode
# Master thread
engine = load_engine("mnist.trt")
shared_cuda_context = create_cuda_context()
execution_contexts = [engine.create_execution_context() for _ in range(num_threads)]
# Worker threads
def worker_thread(execution_context, input_buffer):
    restore_cuda_context(shared_cuda_context)
    execute_inference(execution_context, input_buffer)
    # Do any necessary cleanup
By following these practices and recommendations, you can effectively share a TensorRT inference engine while managing CUDA contexts in a multi-threaded Python environment.
Thank you very much for your answer.
I will refer to your answer.
