Can not upgrade from JP5.1 to JP5.1.2?
I followed this guide How to Install JetPack :: NVIDIA JetPack Documentation.
After changed file /etc/apt/sources.list.d/nvidia-l4t-apt-source.list
deb https://repo.download.nvidia.com/jetson/common r35.4 main
deb https://repo.download.nvidia.com/jetson/t194 r35.4 main
How to solve this problem? Thanks.
and run sudo apt update. I encountered an error
Ign:1 https://repo.download.nvidia.com/jetson/common r35.4 InRelease
Ign:2 https://repo.download.nvidia.com/jetson/t194 r35.4 InRelease
Err:3 https://repo.download.nvidia.com/jetson/common r35.4 Release
  Certificate verification failed: The certificate is NOT trusted. The certificate chain uses not yet valid certificate.  Could not handshake: Error in the certificate verification. [IP: 118.69.17.196 443]
Hit:4 http://ports.ubuntu.com/ubuntu-ports focal InRelease
Err:5 https://repo.download.nvidia.com/jetson/t194 r35.4 Release
Get:6 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease [114 kB]
Get:7 http://ports.ubuntu.com/ubuntu-ports focal-backports InRelease [108 kB]
Get:8 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease [114 kB]
Reading package lists... Done
E: The repository 'https://repo.download.nvidia.com/jetson/common r35.4 Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'https://repo.download.nvidia.com/jetson/t194 r35.4 Release' does not have a Release file.
E: Release file for http://ports.ubuntu.com/ubuntu-ports/dists/focal-updates/InRelease is not valid yet (invalid for another 369d 14h 46min 49s). Updates for this repository will not be applied.
E: Release file for http://ports.ubuntu.com/ubuntu-ports/dists/focal-backports/InRelease is not valid yet (invalid for another 369d 13h 28min 36s). Updates for this repository will not be applied.
E: Release file for http://ports.ubuntu.com/ubuntu-ports/dists/focal-security/InRelease is not valid yet (invalid for another 369d 14h 11min 5s). Updates for this repository will not be applied.
The Jetson Nano is not able to upgrade to JP5.x SW.
May I know what’s you Jetson platform?
Are you using devkit or with custom carrier board?
are you using Jetson Nano or Jetson Orin Nano?
For Jetson Nano, JetPack 5 does not support it.
For Jetson Orin Nano, you should use
deb https://repo.download.nvidia.com/jetson/t234 r35.4 main
instead of
@DaveYYY I am using Jetson Xavier NX. What is correct?
Then this one is right.
Does this post help?
