I’m trying to create 2 nccl-communicators with eth0 and ib0. First I set the “NCCL_SOCKET_NAME = ib0” and create the first communicater successfully. However, after that, I change the “NCCL_SOCKET_NAME” to “eth0”, trying to create the second communicator on the eth NIC,but it didnt work.
Related topics
Topic | Replies | Views | Activity | |
Create NCCl Communicator with different NIC | 0 | 39 | October 21, 2024 | |
Is it possible to use one GPU as the root of different communicator groups using NCCL? | 0 | 451 | August 30, 2018 | |
The NCCL communications on dual cpus and multi gpus | 0 | 284 | January 23, 2024 | |
NCCL discussion bug | 3 | 904 | July 13, 2018 | |
How to perform inter-GPU communication using NCCL2 across different hosts without MPI? | 1 | 884 | May 10, 2018 | |
How to use NCCL2 to communicate other server? | 0 | 544 | August 18, 2017 | |
Is there a NCCL 2.x for Windows? | 4 | 6410 | August 1, 2020 | |
Does the virbr0 or other virtual NIC affect the ring building of NCCL? | 0 | 415 | August 21, 2023 | |
How to use NCCL to communicate between nodes? | 0 | 1288 | June 19, 2023 | |
New Scaling Algorithm and Initialization with NVIDIA Collective Communications Library 2.23 | 1 | 23 | January 31, 2025 |
