I have a problem with recovering the board after unsuccessful update with JetPack1-1.0 from July version. During the update I had this:
sudo ./flash.sh jetson-tk1 mmcblk0p1
copying bctfile(/home/grid/JetPackTK1-1.0/Linux_for_Tegra/bootloader/ardbeg/BCT/PM375_Hynix_2GB_H5TC4G63AFR_RDA_924MHz.cfg)... done.
copying bootloader(/home/grid/JetPackTK1-1.0/Linux_for_Tegra/bootloader/ardbeg/u-boot.bin)... done.
populating kernel to rootfs... done.
populating jetson-tk1_extlinux.conf.emmc to rootfs... done.
done.
Making system.img...
populating rootfs from /home/grid/JetPackTK1-1.0/Linux_for_Tegra/rootfs ... done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image...
---- Raw to Sparse Image Converter v1.0 ----------------------------
0: RAW: 3706880( 905 blks) ==> 28:3706892
1: SKP: 32768( 8 blks) ==> 3706920:32780
2: RAW: 24576( 6 blks) ==> 3706932:24588
3: SKP: 40960( 10 blks) ==> 3731520:40972
4: RAW: 10969088( 2678 blks) ==> 3731532:10969100
5: SKP: 22585344( 5514 blks) ==> 14700632:22585356
6: RAW: 28696576( 7006 blks) ==> 14700644:28696588
7: SKP: 68161536( 16641 blks) ==> 43397232:68161548
8: RAW: 8192( 2 blks) ==> 43397244:8204
1823: SKP: 4096( 1 blks) ==> 2266289552:4108
1824: RAW: 5369856( 1311 blks) ==> 2266289564:5369868
1825: SKP: 4096( 1 blks) ==> 2271659432:4108
1826: RAW: 8192( 2 blks) ==> 2271659444:8204
1827: SKP: 49152( 12 blks) ==> 2271667648:49164
1828: RAW: 4096( 1 blks) ==> 2271667660:4108
1829: SKP: 61440( 15 blks) ==> 2271671768:61452
1830: RAW: 15159296( 3701 blks) ==> 2271671780:15159308
1831: SKP: 1317978112( 321772 blks) ==> 2286831088:1317978124
-- Total: -----------------------------------------------------------
1832 CHUNK 15032385536(3670016 blks) ==> 2286831100(558303 blks)
done.
system.img built successfully.
copying dtbfile(/home/grid/JetPackTK1-1.0/Linux_for_Tegra/kernel/dtb/tegra124-jetson_tk1-pm375-000-c00-00.dtb)... done.
copying cfgfile(/home/grid/JetPackTK1-1.0/Linux_for_Tegra/bootloader/ardbeg/cfg/gnu_linux_fastboot_emmc_full.cfg) to flash.cfg... done.
creating gpt(ppt.img)...
*** GPT Parameters ***
device size -------------- 15766388736
bootpart size ------------ 8388608
userpart size ------------ 15758000128
Erase Block Size --------- 2097152
sector size -------------- 4096
Partition Config file ---- flash.cfg
Visible partition flag --- GP1
Primary GPT output ------- PPT->ppt.img
Secondary GPT output ----- GPT->gpt.img
Target device name ------- none
*** PARTITION LAYOUT(20 partitions) ***
[ BCT] BH 0 16383 8.0MiB
[ PPT] UH 0 4095 2.0MiB ppt.img
[ PT] UH 4096 8191 2.0MiB
[ EBT] UH 8192 16383 4.0MiB u-boot.bin
[ LNX] UH 16384 49151 16.0MiB
[ SOS] UH 49152 61439 6.0MiB
[ NVC] UH 61440 65535 2.0MiB
[ MPB] UH 65536 77823 6.0MiB
[ MBP] UH 77824 90111 6.0MiB
[ GP1] UH 90112 94207 2.0MiB
[ APP] UV 94208 29454335 14336.0MiB system.img
[ DTB] UV 29454336 29462527 4.0MiB tegra124-jetson_tk1-pm375-000-c00-00.dtb
[ EFI] UV 29462528 29593599 64.0MiB
[ USP] UV 29593600 29601791 4.0MiB
[ TP1] UV 29601792 29609983 4.0MiB
[ TP2] UV 29609984 29618175 4.0MiB
[ TP3] UV 29618176 29626367 4.0MiB
[ WB0] UV 29626368 29630463 2.0MiB
[ UDA] UV 29630464 30773247 558.0MiB
[ GPT] UH 30773248 30777343 2.0MiB gpt.img
copying flasher(/home/grid/JetPackTK1-1.0/Linux_for_Tegra/bootloader/ardbeg/fastboot.bin)... done.
Existing flashapp(/home/grid/JetPackTK1-1.0/Linux_for_Tegra/bootloader/nvflash) reused.
*** Flashing target device started. ***
./nvflash --bct PM375_Hynix_2GB_H5TC4G63AFR_RDA_924MHz.cfg --setbct --configfile flash.cfg --create --bl fastboot.bin --odmdata 0x6009C000 --go
Nvflash 4.13.0000 started
BR_CID: 0x340010017408f0420400000019fe0580
rcm version 0X400001
Skipping BoardID read at miniloader level
System Information:
chip name: unknown
chip id: 0x40 major: 1 minor: 1
chip sku: 0x0
chip uid: 0x000000017408f0420400000019fe0580
macrovision: disabled
hdcp: disabled
jtag: disabled
sbk burned: false
board id: 0
warranty fuse: 0
dk burned: false
boot device: emmc
operating mode: 3
device config strap: 0
device config fuse: 0
sdram config strap: 0
RCM communication completed
BCT sent successfully
sending file: tegra124-jetson_tk1-pm375-000-c00-00.dtb
- 52986/52986 bytes sent
tegra124-jetson_tk1-pm375-000-c00-00.dtb sent successfully
odm data: 0x6009c000
downloading bootloader -- load address: 0x83d88000 entry point: 0x83d88000
sending file: fastboot.bin
- 594363/594363 bytes sent
fastboot.bin sent successfully
waiting for bootloader to initialize
bootloader downloaded successfully
ML execution and Cpu Handover took 2 Secs
Partition backup took 0 Secs
setting device: 2 3
deleting device partitions
deleteall failed
command failure/warning: create failed (bad data)
bootloader status: fatal failure to read / write to mass storage (code: 9) message: nverror:0x5 (0x5) DeleteAll 1350 flags: 0
Failed flashing ardbeg.
Log from UART:
[0000.000] [TegraBoot] (version UNDEF_BUILD)
[0000.004] Reset reason: power on reset
[0000.007] Processing in recovery mode
[0000.011] Established communication link with host
[0000.084] Downloaded bct successfully
[0000.094] No Battery Present
[0000.097] Sdram initialization is successful
[0000.138] Downloaded DTB successfully
[0000.176] No Battery Present
[0000.577] Downloaded bootloader successfully
[0000.581] CPU-bootloader entry address: 0x83d88000
[0000.585] BoardId: 375
[0000.587] Vpr Carveout Base=0x0f4600000 Size=0x00ba00000
[0000.592] Tsec Carveout Base=0x0f2600000 Size=0x002000000
[0000.598] Lp0 Carveout Base=0x0f25ff000 Size=0x000001000
[0000.603] Xusb Carveout Base=0x0f2300000 Size=0x000200000
[0000.608] Platform-DebugCarveout: 0
[0000.635] CPU power rail is up
[0000.638] Performing RAM repair
[0000.641] CPU clock init successful
[0000.644] Starting CPU & Halting co-processor
NVRM Initialized shmoo database
NVRM CLOCKS: PLLX0: 696000 Khz
NVRM CLOCKS: PLLM0: 924000 Khz
NVRM CLOCKS: PLLC0: 0 Khz
NVRM CLOCKS: PLLP0: 408000 Khz
NVRM CLOCKS: PLLA0: 11289 Khz
NVRM CLOCKS: CPU: 696000 Khz
NVRM CLOCKS: AVP: 48000 Khz
NVRM CLOCKS: System Bus: 48000 Khz
NVRM CLOCKS: Memory Controller: 924000
NVRM CLOCKS: External Memory Controller: 924000
EEPROM instance-5: No slave at this instance.
EEPROM instance-0: No slave at this instance.
EEPROM instance-0: Querying board info from BCT.
EEPROM instance-0: Board info present in BCT is invalid.
EEPROM instance-1: No slave at this instance.
EEPROM instance-1: Querying board info from BCT.
EEPROM instance-1: Board info present in BCT is invalid.
EEPROM instance-2: No slave at this instance.
EEPROM instance-2: Querying board info from BCT.
EEPROM instance-2: Board info present in BCT is invalid.
EEPROM instance-3: No slave at this instance.
EEPROM instance-3: Querying board info from BCT.
EEPROM instance-3: Board info present in BCT is invalid.
EEPROM instance-4: No slave at this instance.
EEPROM instance-4: Querying board info from BCT.
EEPROM instance-4: Board info present in BCT is invalid.
EEPROM instance-5: Querying board info from BCT.
EEPROM instance-5: Board info present in BCT is invalid.
EEPROM instance-6: BoardInfo: 0x0001:0x0007:0375:0000:03:E:00:0xff:0xff:0xff:0xff:0xff:0xff
EEPROM instance-7: No slave at this instance.
EEPROM instance-7: Querying board info from BCT.
EEPROM instance-7: Board info present in BCT is invalid.
Final BoardID: proc: 375 and pmu 375
ADJUSTED CLOCKS:
MC clock is set to 924000 KHz
EMC clock is set to 924000 KHz (DDR clock is at 924000 KHz)
PLLX0 clock is set to 696000 KHz
PLLC0 clock is set to 0 KHz
CPU clock is set to 696000 KHz
System and AVP clock is set to 48000 KHz
GraphicsHost clock is set to 163200 KHz
MSENC clock is set to 92400 KHz
Vde clock is set to 204000 KHz
Bootloader-Cpu Init at (time stamp): 504597084 us
Pinmux changes applied in kernel way
[bootloader] (version UNDEF_BUILD)
Platform Pre Boot configuration...
NvDdkUsbhBlockDevInit..
Initializing Display
The proc BoardInfo: 0x0177:0x0000:0x03:0x45:0x00
This Pmu Module is not present.
The best display mode is 2560x1600/60Hz, pclk: 268627Khz
DSI PAD calibration done
Entering NvFlash recovery mode / Nv3p Server
Nv3pServer Version 4.13.0000
SDIO_DDK polling read timeout Instance[3]
ReadExtCSD :Error 0x5
MmcIdentifyCard :Error 0x5
SdOpen: Error 0x5
DeleteAll failed. NvError 5 NvStatus 9
Now I have the same anyway. Sometimes I have hang on line “NvFlash starting…” when I experiment with “-S XXXX MiB” option. Tried nvidia usb cable with diff ports. No result.
