Can volatile just bypass L1 but still use L2?
__device__ unsigned int count = 0;
__shared__ bool isLastBlockDone;
__global__ void sum(const float* array, unsigned int N,
volatile float* result)
// Each block sums a subset of the input array.
float partialSum = calculatePartialSum(array, N);
if (threadIdx.x == 0) {
// Thread 0 of each block stores the partial sum
// to global memory. The compiler will use
// a store operation that bypasses the L1 cache
// since the "result" variable is declared as
// volatile. This ensures that the threads of
// the last block will read the correct partial
// sums computed by all other blocks.
https://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#memory-fence-functions
