I have a caffe model that successfully converted to tensorrt 5.0. However, it fails when I upgrade to TensorRT 7.0. After looking to the error code, I found that the exception happened when converting pool layer to TensorRT. The snippet below is the setup for pooling in the protobuf file:
CAFFE_ROUND_UP: B >= (F + 1) is an error if (B + S) >= (F + 1)
I don’t know why there’s such limitation and even if I add pad: 0, it does not help.
Does anyone have the same problem ? Any help would be appreciated.
I didn’t change my prototxt but got the above error after upgrading to tensorrt7. Would it be possible that there are some bugs in the conversion code?
Can you provide the following information so we can better help?
Provide details on the platforms you are using:
o Linux distro and version
o GPU type
o Nvidia driver version
o CUDA version
o CUDNN version
o Python version [if using python]
o Tensorflow/PyTorch/Caffe version
o TensorRT version
Please share the script & model file to reproduce the issue.
“Padding = 0 assertion failure” is fixed and should be available in next release.
We are deprecating Caffe Parser and UFF Parser in TensorRT 7. Hence going forward, we are recommending the onnx parser path.
