I installed CUDA libraries on my system using the .run file for Leap 15, as specified on this thread . I downloaded the 12.4.0_550.54.14 version as my current driver is 550, i’ve then unmarked the driver and module installation as i’ve it already installed from the package manager, i’ve then checked PATH and ldconfig and added the missing paths where needed, and also downloaded CuDNN and copied the libs, however nothing can detect it.
Tensorflow was giving me CUDA_ERROR_NOT_INITIALIZED, while Blender was saying i had no compatible GPU. As mentioned in this thread, the open kernel module has to be the same version as the CUDA component, so i uninstalled the open-source module and installed the old proprietary one. However, after that, CUDA still can’t work. Now Tensorflow gives me CUDA_ERROR_UNKNOWN and Blender still says i have no compatible GPU.
So i’ve asked in the OpenSUSE Forums about this problem, made some diagnostics and checked the libraries are installed and detectable, but programs still can’t detect them and neither the drive can initialize them. Another user told me he got issues using NVIDIA alongside AMD. I’ve checked it on Windows aswell and CUDA does works (also alongside AMD HIP), but i would like to have it working on Linux.
My system specifications:
(⌚qui jun-6 9:38:57)-(🦊joseskvolpe:~)-( 304K:62)
$ neofetch
_aaaymQQmwaaa, joseskvolpe@ProtoFOX
,wWQQQD????????$QQQQa,. --------------------
_wQQB?" ??QQQa, OS: openSUSE Tumbleweed-Slowroll x86_64
sQQD^ ?QQ6\ Host: Nitro AN515-47 V1.14
yWW' 4QQg Kernel: 6.9.5-1-default
,QQD .aaaaaaaa ^4Q6 Uptime: 55 mins
,mQP _wWQW?????YWWQa, 4Qm Packages: 3449 (rpm), 44 (flatpak)
jQ@ wWW?' ^4QQc ^$QL Shell: bash 5.2.26
,QQ' jWW' )QW\ ]QQ Resolution: 1920x1080
|QQ ,QW' ]QQ ^QQ| DE: Plasma 6.0.5
|QQ |QQ ]QQ QQ| WM: kwin
|QQ 4Qg ]QQ .QQ| Theme: [Plasma], X-Vulpus-DarkRed [GTK2/3]
'QQ6 '$WQac. _QQ( jQQ Icons: [Plasma], Vulpinity [GTK2/3]
]QQw "?QWQQf _mQP ,QQ( Terminal: yakuake
4QQga wQQP ,mQ? CPU: AMD Ryzen 5 7535HS with Radeon Graphics (12) @ 4.603GHz
4QQQga, saQWP' jQQf GPU: AMD ATI Radeon 680M
?QQQQQQwaaaaaaaayWWW?' _mQ@' GPU: NVIDIA GeForce RTX 3050 Mobile
?WQQQP?9VWUV???^ _amQP^ Memory: 6362MiB / 15171MiB
"4QQQaa, ,awQQQ?^
"?VQQQQQQQQQQQQQQP?'
inxi:
$ inxi -GSaxxz
System:
Kernel: 6.9.5-1-default arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
clocksource: tsc avail: hpet,acpi_pm
parameters: BOOT_IMAGE=/vmlinuz-6.9.5-1-default
root=/dev/mapper/OpenSUSE-SYSTEM splash=silent resume=/dev/OpenSUSE/SWAP
quiet pcie_aspm=force acpi_backlight=native security=apparmor rd.shell=0
mitigations=auto
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
wm: kwin_wayland tools: avail: xscreensaver vt: 2 dm: SDDM Distro: openSUSE
Tumbleweed-Slowroll 20240605
Graphics:
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 550.90.07
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 ports: active: none off: HDMI-A-1 empty: none
bus-ID: 01:00.0 chip-ID: 10de:25a2 class-ID: 0300
Device-2: AMD Rembrandt [Radeon 680M] vendor: Acer Incorporated ALI
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-3,eDP-1 empty: DP-1, DP-2, DP-4, DP-5, DP-6, DP-7, DP-8,
Writeback-1 bus-ID: 75:00.0 chip-ID: 1002:1681 class-ID: 0300 temp: 47.0 C
Device-3: Chicony ACER HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 04f2:b76f
class-ID: fe01 serial: <filter>
Display: wayland server: X.org v: 1.21.1.12 with: Xwayland v: 24.1.0
compositor: kwin_wayland driver: X: loaded: modesetting dri: radeonsi
gpu: nvidia,amdgpu d-rect: 5376x3024 display-ID: 0
Monitor-1: DP-3 pos: primary,top-left res: 1920x1080 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: bottom-c res: 1920x1080 size: N/A modes: N/A
Monitor-3: eDP-1 pos: middle-r res: 1536x864 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast surfaceless:
drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
inactive: gbm,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.0.8 glx-v: 1.4
direct-render: yes renderer: AMD Radeon 660M (radeonsi rembrandt LLVM
18.1.6 DRM 3.57 6.9.5-1-default) device-ID: 1002:1681 memory: 500 MiB
unified: no display-ID: :0.0
API: Vulkan v: 1.3.283 layers: 2 device: 0 type: integrated-gpu name: AMD
Radeon 660M (RADV REMBRANDT) driver: N/A device-ID: 1002:1681
surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu name: NVIDIA
GeForce RTX 3050 Laptop GPU driver: N/A device-ID: 10de:25a2
¿Something i’m missing?
