I have read several forum threads with similar questions and responses, and tried to follow the insights from the good folks responding to these questions, but to no avail. I am using Ubuntu 22.04, and believe I am using the proprietary 525 drivers for my Quadro P5200 mobile on a Lenovo Thinkpad P72. When I attach my HDMI cable to an external monitor, I get nothing: no recognition that anything has been attached on the external device, and on my Thinkpad, I do not see any indication that an external monitor is available in Settings > Displays. I did have external displays working on previous versions of Ubuntu with this machine.
Any help appreciated.
I can open the NVIDIA Settings GUI app and, for example, select “NVIDIA (Performance Mode)”. However, when I type:
$ sudo nvidia-smi
No devices were found
Seeing a common bit of advice given to folks in similar positions, I have done sudo apt install linux-headers-$(uname -r), but everything was already up to date.
Here’s some more information along with the attached output of nvidia-bug-report.sh to help me start troubleshooting:
nvidia-bug-report.log.gz (145.0 KB)
$ sudo lshw -c display
[sudo] password for MyAccount:
*-display
description: VGA compatible controller
product: GP104GLM [Quadro P5200 Mobile]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:16 memory:c0000000-c0ffffff memory:60000000-6fffffff memory:70000000-71ffffff ioport:2000(size=128) memory:c1080000-c10fffff
*-display
product: Intel Corporation
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
logical name: /dev/fb0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom fb
configuration: depth=32 driver=i915 latency=0 resolution=3840,2160
resources: irq:156 memory:bf000000-bfffffff memory:80000000-8fffffff ioport:3000(size=64) memory:c0000-dffff
$ sudo dkms status
nvidia/525.78.01, 5.15.0-58-lowlatency, x86_64: installed
virtualbox/6.1.38, 5.15.0-56-generic, x86_64: installed
virtualbox/6.1.38, 5.15.0-57-generic, x86_64: installed
virtualbox/6.1.38, 5.15.0-57-lowlatency, x86_64: installed
virtualbox/6.1.38, 5.15.0-58-generic, x86_64: installed
virtualbox/6.1.38, 5.15.0-58-lowlatency, x86_64: installed
$ dpkg -l |grep nvidia
ii libnvidia-cfg1-525:amd64 525.78.01-0ubuntu0.22.04.1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-525 525.78.01-0ubuntu0.22.04.1 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-525:amd64 525.78.01-0ubuntu0.22.04.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-525:i386 525.78.01-0ubuntu0.22.04.1 i386 NVIDIA libcompute package
ii libnvidia-decode-525:amd64 525.78.01-0ubuntu0.22.04.1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-525:i386 525.78.01-0ubuntu0.22.04.1 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-egl-wayland1:amd64 1:1.1.9-1.1 amd64 Wayland EGL External Platform library -- shared library
ii libnvidia-encode-525:amd64 525.78.01-0ubuntu0.22.04.1 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-525:i386 525.78.01-0ubuntu0.22.04.1 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-525:amd64 525.78.01-0ubuntu0.22.04.1 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-525:amd64 525.78.01-0ubuntu0.22.04.1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-525:i386 525.78.01-0ubuntu0.22.04.1 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-525:amd64 525.78.01-0ubuntu0.22.04.1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-525:i386 525.78.01-0ubuntu0.22.04.1 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
rc linux-modules-nvidia-470-5.15.0-58-generic 5.15.0-58.64 amd64 Linux kernel nvidia modules for version 5.15.0-58
rc linux-modules-nvidia-510-5.15.0-25-generic 5.15.0-25.25 amd64 Linux kernel nvidia modules for version 5.15.0-25
rc linux-modules-nvidia-510-5.15.0-41-generic 5.15.0-41.44+1 amd64 Linux kernel nvidia modules for version 5.15.0-41
rc linux-modules-nvidia-510-5.15.0-43-generic 5.15.0-43.46+1 amd64 Linux kernel nvidia modules for version 5.15.0-43
rc linux-modules-nvidia-510-5.15.0-46-generic 5.15.0-46.49 amd64 Linux kernel nvidia modules for version 5.15.0-46
rc linux-modules-nvidia-510-5.15.0-47-generic 5.15.0-47.51 amd64 Linux kernel nvidia modules for version 5.15.0-47
rc linux-modules-nvidia-510-5.15.0-48-generic 5.15.0-48.54 amd64 Linux kernel nvidia modules for version 5.15.0-48
rc linux-modules-nvidia-510-5.15.0-50-generic 5.15.0-50.56+1 amd64 Linux kernel nvidia modules for version 5.15.0-50
rc linux-modules-nvidia-510-5.15.0-52-generic 5.15.0-52.58+1 amd64 Linux kernel nvidia modules for version 5.15.0-52
rc linux-modules-nvidia-510-5.15.0-53-generic 5.15.0-53.59+1 amd64 Linux kernel nvidia modules for version 5.15.0-53
ii linux-modules-nvidia-525-5.15.0-58-generic 5.15.0-58.64+1 amd64 Linux kernel nvidia modules for version 5.15.0-58
ii linux-modules-nvidia-525-generic-hwe-22.04 5.15.0-58.64+1 amd64 Extra drivers for nvidia-525 for the generic-hwe-22.04 flavour
ii linux-objects-nvidia-470-5.15.0-58-generic 5.15.0-58.64+1 amd64 Linux kernel nvidia modules for version 5.15.0-58 (objects)
rc linux-objects-nvidia-510-5.15.0-25-generic 5.15.0-25.25 amd64 Linux kernel nvidia modules for version 5.15.0-25 (objects)
rc linux-objects-nvidia-510-5.15.0-41-generic 5.15.0-41.44+1 amd64 Linux kernel nvidia modules for version 5.15.0-41 (objects)
ii linux-objects-nvidia-510-5.15.0-43-generic 5.15.0-43.46+1 amd64 Linux kernel nvidia modules for version 5.15.0-43 (objects)
rc linux-objects-nvidia-510-5.15.0-46-generic 5.15.0-46.49 amd64 Linux kernel nvidia modules for version 5.15.0-46 (objects)
rc linux-objects-nvidia-510-5.15.0-47-generic 5.15.0-47.51 amd64 Linux kernel nvidia modules for version 5.15.0-47 (objects)
rc linux-objects-nvidia-510-5.15.0-48-generic 5.15.0-48.54 amd64 Linux kernel nvidia modules for version 5.15.0-48 (objects)
rc linux-objects-nvidia-510-5.15.0-50-generic 5.15.0-50.56+1 amd64 Linux kernel nvidia modules for version 5.15.0-50 (objects)
rc linux-objects-nvidia-510-5.15.0-52-generic 5.15.0-52.58+1 amd64 Linux kernel nvidia modules for version 5.15.0-52 (objects)
rc linux-objects-nvidia-510-5.15.0-53-generic 5.15.0-53.59+1 amd64 Linux kernel nvidia modules for version 5.15.0-53 (objects)
ii linux-objects-nvidia-510-5.15.0-56-generic 5.15.0-56.62+1 amd64 Linux kernel nvidia modules for version 5.15.0-56 (objects)
ii linux-objects-nvidia-510-5.15.0-57-generic 5.15.0-57.63+1 amd64 Linux kernel nvidia modules for version 5.15.0-57 (objects)
ii linux-objects-nvidia-510-5.15.0-58-generic 5.15.0-58.64+1 amd64 Linux kernel nvidia modules for version 5.15.0-58 (objects)
ii linux-objects-nvidia-525-5.15.0-58-generic 5.15.0-58.64+1 amd64 Linux kernel nvidia modules for version 5.15.0-58 (objects)
ii linux-signatures-nvidia-5.15.0-43-generic 5.15.0-43.46+1 amd64 Linux kernel signatures for nvidia modules for version 5.15.0-43-generic
ii linux-signatures-nvidia-5.15.0-56-generic 5.15.0-56.62+1 amd64 Linux kernel signatures for nvidia modules for version 5.15.0-56-generic
ii linux-signatures-nvidia-5.15.0-57-generic 5.15.0-57.63+1 amd64 Linux kernel signatures for nvidia modules for version 5.15.0-57-generic
ii linux-signatures-nvidia-5.15.0-58-generic 5.15.0-58.64+1 amd64 Linux kernel signatures for nvidia modules for version 5.15.0-58-generic
ii nvidia-compute-utils-525 525.78.01-0ubuntu0.22.04.1 amd64 NVIDIA compute utilities
ii nvidia-dkms-525 525.78.01-0ubuntu0.22.04.1 amd64 NVIDIA DKMS package
ii nvidia-driver-525 525.78.01-0ubuntu0.22.04.1 amd64 NVIDIA driver metapackage
ii nvidia-kernel-common-525 525.78.01-0ubuntu0.22.04.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-525 525.78.01-0ubuntu0.22.04.1 amd64 NVIDIA kernel source package
ii nvidia-prime 0.8.17.1 all Tools to enable NVIDIA's Prime
ii nvidia-settings 510.47.03-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-525 525.78.01-0ubuntu0.22.04.1 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18.2 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-525 525.78.01-0ubuntu0.22.04.1 amd64 NVIDIA binary Xorg driver
