Thank you for investigating.
I was using parent process to watch illegal end of child process or shutdown to restart or want to shutdown.
This is the reason.
DaneLLL, can we get some clarification about what case is not supported? As you know all processes in linux are typically children of some other process, so I guess that’s not the issue by itself… What exactly is the scenario that’s not supported?
As it happens, I have a process that launches a child which does JPEG encoding. It seems to work 99% of the time, but sometimes, for no reason that I can determine, I get the “Tegra Acceleration failed” crash. Any pointers in the right direction would be appreciated…
Running NVJpegEncoder on child process works ok on BSP 28.1.0 but is definitely broken on BSP 28.2.1.
Issue is 100 % repeatable on 28.2.1, but never fails on 28.1.0.
On this light, I bit curious of your statement that “This case is not supported by default” as it was supported on 28.1.0 and on 28.2.1 it has regressed.
Our test cases run default 05_jpeg_encode. For your usecase of running jpeg encoding in child process, you have to modify the sample code, so it is neither verified on r28.1, nor on r28.2.1.
If you would like to prioritize this issue, please contact NVIDIA salesperson to have further cooperation with us. Thanks.
