I am testing with the nvstreammux plugin. When I specify the width or height property of nvstreammux to zero, the plugin reports error: Output height not set
The test command is
gst-launch-1.0 filesrc location=streams/sample_720p.h264 ! h264parse ! nvdec_h264 ! m.sink_0 nvstreammux name=m batch-size=1 width=1080 height=0 gpu-id=0 ! fakesink
The output is
Setting pipeline to PAUSED ...
ERROR: Pipeline doesn't want to pause.
ERROR: from element /GstPipeline:pipeline0/GstNvStreamMux:m: Output height not set
Additional debug info:
gstnvstreammux.c(1623): gst_nvstreammux_change_state (): /GstPipeline:pipeline0/GstNvStreamMux:m
Setting pipeline to NULL ...
Freeing pipeline ...
According to the DeepStream 3.0 plugin manual, the width or height value ranges from 0 to 4,294,967,295. I was thinking if width or height equals 0, the plugin should automatically get original width and height from upstream.
So nvstreammux’s width and height must be set to positive values?
