After inspection, if i remove below code (draw code) from pgie call back function, it will work as normal
for frame_object in frame_object_list:
add_obj_meta_to_frame(
frame_object, batch_meta, frame_meta, label_names)
Why?
Reproduce:
draw func
def add_obj_meta_to_frame(frame_object, batch_meta, frame_meta, label_names):
""" Inserts an object into the metadata """
# this is a good place to insert objects into the metadata.
# Here's an example of inserting a single object.
obj_meta = pyds.nvds_acquire_obj_meta_from_pool(batch_meta)
# Set bbox properties. These are in input resolution.
rect_params = obj_meta.rect_params
# rect_params.left = int(IMAGE_WIDTH * frame_object.left)
# rect_params.top = int(IMAGE_HEIGHT * frame_object.top)
# rect_params.width = int(IMAGE_WIDTH * frame_object.width)
# rect_params.height = int(IMAGE_HEIGHT * frame_object.height)
rect_params.left = int(frame_object.left)
rect_params.top = int(frame_object.top)
rect_params.width = int(frame_object.width)
rect_params.height = int(frame_object.height)
# Semi-transparent yellow backgroud
rect_params.has_bg_color = 0
rect_params.bg_color.set(1, 1, 0, 0.4)
# Red border of width 3
rect_params.border_width = 3
rect_params.border_color.set(1, 0, 0, 1)
# Set object info including class, detection confidence, etc.
obj_meta.confidence = frame_object.detectionConfidence
obj_meta.class_id = frame_object.classId
# There is no tracking ID upon detection. The tracker will
# assign an ID.
obj_meta.object_id = UNTRACKED_OBJECT_ID
lbl_id = frame_object.classId
if lbl_id >= len(label_names):
lbl_id = 0
# Set the object classification label.
obj_meta.obj_label = label_names[lbl_id]
# Set display text for the object.
txt_params = obj_meta.text_params
if txt_params.display_text:
pyds.free_buffer(txt_params.display_text)
txt_params.x_offset = int(rect_params.left)
txt_params.y_offset = max(0, int(rect_params.top) - 10)
txt_params.display_text = (
label_names[lbl_id] + " " +
"{:04.3f}".format(frame_object.detectionConfidence)
# Font , font-color and font-size
txt_params.font_params.font_name = "Serif"
txt_params.font_params.font_size = 10
# set(red, green, blue, alpha); set to White
txt_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
# Text background color
txt_params.set_bg_clr = 1
# set(red, green, blue, alpha); set to Black
txt_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
# Inser the object into current frame meta
# This object has no parent
pyds.nvds_add_obj_meta_to_frame(frame_meta, obj_meta, None)
pgie call back
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garbage collector will leave
# it alone.
except StopIteration:
break
frame_number = frame_meta.frame_num
print("frame_number: ", frame_number)
l_user = frame_meta.frame_user_meta_list
while l_user is not None:
try:
# Note that l_user.data needs a cast to pyds.NvDsUserMeta
# it alone.
user_meta = pyds.NvDsUserMeta.cast(l_user.data)
break
if (
user_meta.base_meta.meta_type
!= pyds.NvDsMetaType.NVDSINFER_TENSOR_OUTPUT_META
continue
tensor_meta = pyds.NvDsInferTensorMeta.cast(
user_meta.user_meta_data)
# Boxes in the tensor meta should be in network resolution which is
# found in tensor_meta.network_info. Use this info to scale boxes to
# the input frame resolution.
layers_info = []
for i in range(tensor_meta.num_output_layers):
layer = pyds.get_nvds_LayerInfo(tensor_meta, i)
layers_info.append(layer)
frame_object_list, faces = nvds_infer_parse_custom_tf_ssd(
layers_info, batch_meta, frame_meta, label_names
# if len(faces) > 0:
# batch_inferences[frame_meta.pad_index][frame_number] = faces
print("faces: ", faces)
# create_display_meta(faces, frame_meta)
try:
l_user = l_user.next
break
