I cannot use VILA on jetson-containers, as like NanoVLM, or Live LLaVA.
Are there anything wrong when using VILA on jetson-containers?
At previous time (as yesterday), it worked fine.
For example, I execute NanoVLM following tutorial, an error is showed as below.
https://www.jetson-ai-lab.com/tutorial_nano-vlm.html
$ jetson-containers run $(autotag nano_llm)
python3 -m nano_llm.chat --api=mlc
–model Efficient-Large-Model/VILA1.5-3b
–max-context-len 256
–max-new-tokens 32
vila_error_0.txt (3.2 KB)
This error (… /data/models/mlc/dist/VILA1.5-3b-ctx256 ’ returned non-zero exit status 1) is also showed when running Live LLaVA.
Then, I tried other models, VILA1.5-3b, and liuhaotian/llava-v1.5-7b.
When with VILA1.5-3b, an error (Repository Not Found for url: https://huggingface.co/api/models/VILA1.5-3b/revision/main ) was occurred.
–model VILA1.5-3b
–max-new-tokens 32
vila_error_1.txt (3.1 KB)
And with llava-v1.5-7b, it worked fine.
–model liuhaotian/llava-v1.5-7b
–max-new-tokens 32
Please give some information to improve it.
Best regards,
Hi @masaki_yamagishi , perhaps it was some temporary network issue or corruption - the correct model name/repo should be Efficient-Large-Model/VILA1.5-3b
If you had used previous version of VILA but not updated your NanoLLM container, please do a docker pull $(autotag nano_llm) (it required code updates to support VILA-1.5)
You might also try deleting/re-downloading your VILA-1.5 model under jetson-containers/data/models/huggingface
Hi, @dusty_nv
Thank you for your dedicated reply.
I can use Efficient-Large-Model/VILA1.5-3b today.
So that might be temporary network issue.
And I understood how update VILA network.
Thank you for your support.
Additional:
WebUI of NanoDB is still disappeared when running Live LLaVA as below.
If you can, please help me.
I tried Live LLaVA Tutorial following below instruction, but it not shows NanoDB UI.
How can I integrate NanoDB to Live LLaVA appropriately?
My webUI of LLaVA is like below.
[live_llava_no_nanodb]
In same environment, NanoDB is works fine.
[work_nanodb]
And “chrome://flags/#enable-webrtc-hide-local-ips-with-mdns” is disabled.
[chrome_settings]
I use below equipment.
Jetson AGX Orin 32GB Devkit / JetPack 6.0DP / 2.0 TB NVMe SSD / Logicool C615 HD Webcam
Best regards,
OK great, glad to hear that you got VILA-1.5 working @masaki_yamagishi ! We will tackle the NanoDB issue you have next!
