I am trying to compile my imaging sensor driver as a module with the command:
make ARCH="arm64" O=$TEGRA_KERNEL_OUT -j$(nproc)
Yet, the compiler throws out this error:
rm drivers/misc/mods/mods.dtb drivers/misc/mods/mods.dtb.S
Building modules, stage 2.
MODPOST 656 modules
WARNING: could not open drivers/misc/mods/mods.dtb.S: No such file or directory
FATAL: modpost: GPL-incompatible module imx392.ko uses GPL-only symbol 'tegracam_v4l2subdev_register'
/home/ubuntu/repositories/Stereo-Vision_TX2/build/Linux_for_Tegra/sources/kernel/kernel-4.9/scripts/Makefile.modpost:107: recipe for target '__modpost' failed
make[2]: *** [__modpost] Error 1
/home/ubuntu/repositories/Stereo-Vision_TX2/build/Linux_for_Tegra/sources/kernel/kernel-4.9/Makefile:1333: recipe for target 'modules' failed
make[1]: *** [modules] Error 2
make[1]: Leaving directory '/home/ubuntu/repositories/Stereo-Vision_TX2/build/Linux_for_Tegra/images'
Makefile:171: recipe for target 'sub-make' failed
make: *** [sub-make] Error 2
I wrote my driver almost like the IMX185 (v2) driver. It compiles correctly if the driver is set to “y” in tegra_defconfig.
Any idea how I can solve this issue?
I tried following the building of EKM and got as far as just the preparation of the sources. The docs specify to change the directory to <path_to_module_source>. I looked around, tried different paths but I can’t find which path is meant by “module_source”.
Furthermore, since I updated the sources to 32.4.2, I get these errors while compiling:
dpkg: error processing package ... (--install):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of ...:
Package ... is not configured yet
Errors were encountered while processing:
nvidia-l4t-init
nvidia-l4t-x11
nvidia-l4t-3d-core
nvidia-l4t-camera
nvidia-l4t-cuda
nvidia-l4t-graphics-demos
nvidia-l4t-gstreamer
nvidia-l4t-multimedia
