I am trying to compile the ov5693 driver as module on L4T 24.2, but I got an error when I run “make modules” command. If I compile this driver as built-in, it compiles successfully with no errors. So, I don´t know the cause of this error. Does anyone has any clue about what this happen and how to resolve it?
This is the driver used with the camera that came in the standard Jetson TX1 Kit, I was able to used the camera and verify that it is recognized and configured correctly by the system, so the driver works fine when it is configured as built-in.
I have not compiled this as a module, but if a dependency feature is missing, I’m wondering what the exact method is that you used for changing this feature to a module? For example, “make menuconfig” would understand dependencies, but directly editing “.config” would not. Should a dependency be missing after using a method which takes into account dependencies, then you probably found a bug.
I was able to successfully compile the ov5693 driver as a module after doing the following changes to the drivers/media/platform/tegra/camera/camera_common.c file and recompile the Kernel.
1) Add this line after camera_common_parse_clocks function definition (line 183):
EXPORT_SYMBOL(camera_common_parse_clocks);
2) Add this line after camera_common_parse_ports function definition (line 224):
EXPORT_SYMBOL(camera_common_parse_ports);
The error was caused because camera_common_parse_ports and camera_common_parse_clocks symbols aren’t available to modules. So it is necessary to export those symbols to be available for modules.
NEW ERROR:
Although ov5693 driver compilation as module was achieved, another error appears when the module is loaded. I don’t understand why this error appears when driver is compiled as a module, if when it is compiled as built-in no error appears and the driver works perfectly. Also, the driver is mounted automatically during boot process, even though the driver is compiled as a module.
Also, I can’t unmount the module with rmmod.
Error log:
ubuntu@tegra-ubuntu:~$ dmesg | grep -i ov5693
[ 3.823797] vi vi: parsing node /host1x/i2c@546c0000/ov5693_c@36
[ 3.823803] vi vi: handling endpoint /host1x/i2c@546c0000/ov5693_c@36/ports/port@0/endpoint
[ 19.401369] [OV5693]: probing v4l2 sensor.
[ 19.401733] ov5693 6-0036: Failed to allocate eeprom reg map: -22
[ 20.211995] vi vi: subdev ov5693 6-0036 bound
ubuntu@tegra-ubuntu:~$ lsmod
Module Size Used by
bnep 14552 2
bcmdhd 7465122 0
cfg80211 449659 1 bcmdhd
ov5693 25496 1
bluedroid_pm 11204 0
ubuntu@tegra-ubuntu:~$ sudo rmmod ov5693
[sudo] password for ubuntu:
rmmod: ERROR: Module ov5693 is in use
ubuntu@tegra-ubuntu:~$ sudo rmmod --force ov5693
Segmentation fault
Module Size Used by
bnep 14552 2
bcmdhd 7465122 0
ov5693 25496 0
rmmod: ERROR: ../libkmod/libkmod-module.c:793 kmod_module_remove_module() could not remove 'ov5693': Device or resource busy
rmmod: ERROR: could not remove module ov5693: Device or resource busy
[ 346.338962] Modules linked in: bnep bcmdhd cfg80211 ov5693(-) bluedroid_pm
[ 347.808439] [<ffffffbffc008f48>] $x+0x18/0x20 [ov5693]
I am developing a driver for ov5647 camera, so I took as a base the ov5693 driver. Because I am using an expansion custom board for camera ports, I needed the driver as module, so I could first run some commands to enable the cameras visibility on the I2C bus before loading the ov5647 driver. But, that was my first approach, so I changed the way I was setting up the camera expansion board, so now I can use the driver as built-in.
Now, my ov5647 driver works fine as built in. I am just debugging the video capture.
