I have built the image with the OV5693 driver as a module. Here is the “.config” file I used to build the image.
# Automatically generated file; DO NOT EDIT.
# Linux/arm64 4.9.140 Kernel Configuration
CONFIG_ARM64=y
CONFIG_64BIT=y
CONFIG_ARCH_PHYS_ADDR_T_64BIT=y
CONFIG_MMU=y
CONFIG_DEBUG_RODATA=y
CONFIG_ARM64_PAGE_SHIFT=12
CONFIG_ARM64_CONT_SHIFT=4
CONFIG_ARCH_MMAP_RND_BITS_MIN=18
CONFIG_ARCH_MMAP_RND_BITS_MAX=24
CONFIG_ARCH_MMAP_RND_COMPAT_BITS_MIN=11
CONFIG_ARCH_MMAP_RND_COMPAT_BITS_MAX=16
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_ILLEGAL_POINTER_VALUE=0xdead000000000000
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
CONFIG_FIQ_GLUE=y
CONFIG_RWSEM_XCHGADD_ALGORITHM=y
CONFIG_GENERIC_BUG=y
CONFIG_GENERIC_BUG_RELATIVE_POINTERS=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CSUM=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_ZONE_DMA=y
CONFIG_HAVE_GENERIC_RCU_GUP=y
CONFIG_ARCH_DMA_ADDR_T_64BIT=y
CONFIG_NEED_DMA_MAP_STATE=y
CONFIG_NEED_SG_DMA_LENGTH=y
CONFIG_SMP=y
# CONFIG_IOMMU_HELPER is not set
CONFIG_KERNEL_MODE_NEON=y
CONFIG_FIX_EARLYCON_MEM=y
CONFIG_PGTABLE_LEVELS=3
# CONFIG_ARM64_NON_SHARED_TLBI is not set
CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
CONFIG_IRQ_WORK=y
CONFIG_BUILDTIME_EXTABLE_SORT=y
CONFIG_THREAD_INFO_IN_TASK=y
# General setup
CONFIG_INIT_ENV_ARG_LIMIT=32
CONFIG_CROSS_COMPILE=""
# CONFIG_COMPILE_TEST is not set
CONFIG_LOCALVERSION="-tegra"
# CONFIG_LOCALVERSION_AUTO is not set
CONFIG_DEFAULT_HOSTNAME="(none)"
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_SYSVIPC_SYSCTL=y
CONFIG_POSIX_MQUEUE=y
CONFIG_POSIX_MQUEUE_SYSCTL=y
CONFIG_CROSS_MEMORY_ATTACH=y
CONFIG_FHANDLE=y
# CONFIG_USELIB is not set
CONFIG_AUDIT=y
CONFIG_HAVE_ARCH_AUDITSYSCALL=y
CONFIG_AUDITSYSCALL=y
CONFIG_AUDIT_WATCH=y
CONFIG_AUDIT_TREE=y
# Sensors used on soc_camera driver
# NVIDIA overlay Encoders, decoders, sensors and other helper chips
CONFIG_VIDEO_IMX185=y
CONFIG_VIDEO_IMX219=y
CONFIG_VIDEO_IMX268=y
CONFIG_VIDEO_IMX274=y
CONFIG_VIDEO_IMX318=y
CONFIG_VIDEO_LC898212=y
CONFIG_VIDEO_OV5693=m
CONFIG_VIDEO_OV9281=y
CONFIG_VIDEO_OV10823=y
CONFIG_VIDEO_OV23850=y
CONFIG_I2C_IOEXPANDER_PCA9570=y
CONFIG_VIDEO_TC358840=y
CONFIG_I2C_IOEXPANDER_SER_MAX9295=y
CONFIG_I2C_IOEXPANDER_DESER_MAX9296=y
CONFIG_VIDEO_IMX390=y
# Tegra BPMP Driver
CONFIG_ARCH_TEGRA_18x_SOC=y
CONFIG_ARCH_TEGRA_19x_SOC=y
CONFIG_ARCH_TEGRA_23x_SOC=y
Up until this point, everything correct. The fact is that, once I load the module, I cannot remove it. This is what I do to generate and load the module:
- Generate the .ko binary with the following makefile:
ifneq ($(KERNELRELEASE),)
obj-m := ov5693.o
else
KDIR := /lib/modules/$(shell uname -r)/build
PWD := $(shell pwd)
all:
$(MAKE) -C $(KDIR) SUBDIRS=$(PWD) modules
install:
$(MAKE) -C $(KDIR) SUBDIRS=$(PWD) modules_install
$(MAKE) -C $(KDIR) SUBDIRS=$(PWD) $@
endif
- Load the module
sudo insmod ov5693.ko
I check the module is correctly loaded by capturing some images via Gstreamer. Works fine.
Remove the module
sudo rmmod ov5693.ko
In this last step, I get the error “Module ov5693 is builtin”. Why is this happening?
