I try to config the ov5693 to M(module) mode by config kernel make menuconfig,
After build the kernel image, I get the file ov5693.ko, Then type command “insmod ov5693.ko”
But I don’t see device node file /dev/video0.
I’m using Jetpack3.3 L4T R28.2
hello 27653276,
suggest you refer to Kernel Customization for building external kernel modules.
by default, sensor driver bundle to VI to register a video node, you might also refer to VI driver as below.
$TOP/kernel_src/kernel/kernel-4.4/drivers/media/platform/tegra/camera/*
