Feb 11 16:28:00 tegra-ubuntu systemd[1]: Detected architecture arm64.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Set hostname to <tegra-ubuntu>.
Feb 11 16:28:00 tegra-ubuntu kernel: random: systemd: uninitialized urandom read (16 bytes read, 68 bits of entropy available)
Feb 11 16:28:00 tegra-ubuntu kernel: random: systemd-cryptse: uninitialized urandom read (16 bytes read, 69 bits of entropy available)
Feb 11 16:28:00 tegra-ubuntu kernel: random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 69 bits of entropy available)
Feb 11 16:28:00 tegra-ubuntu kernel: random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 70 bits of entropy available)
Feb 11 16:28:00 tegra-ubuntu kernel: tegra-pcie 1003000.pcie-controller: link 0 down, retrying
Feb 11 16:28:00 tegra-ubuntu kernel: tegra-pcie 1003000.pcie-controller: link 0 down, ignoring
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Reached target Encrypted Volumes.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Listening on Syslog Socket.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Reached target Swap.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Listening on Journal Socket.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Listening on Device-mapper event daemon FIFOs.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Created slice User and Session Slice.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Listening on udev Control Socket.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Listening on LVM2 metadata daemon socket.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Created slice System Slice.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Mounting Debug File System...
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Started Braille Device Support.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Created slice system-serial\x2dgetty.slice.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Starting Create Static Device Nodes in /dev...
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Starting Load Kernel Modules...
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Reached target Slices.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Listening on Journal Socket (/dev/log).
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Created slice system-getty.slice.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Listening on Journal Audit Socket.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Starting Journal Service...
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Reached target User and Group Name Lookups.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Starting Remount Root and Kernel File Systems...
Feb 11 16:28:00 tegra-ubuntu kernel: tegra-pcie 1003000.pcie-controller: link 1 down, retrying
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Listening on udev Kernel Socket.
Feb 11 16:28:00 tegra-ubuntu systemd-journald[214]: Journal started
Feb 11 16:28:00 tegra-ubuntu systemd-modules-load[210]: could not open moddep file '/lib/modules/4.4.38/modules.dep.bin'
Feb 11 16:28:00 tegra-ubuntu systemd-modules-load[210]: Failed to lookup alias 'bluedroid_pm': Function not implemented
Feb 11 16:28:00 tegra-ubuntu systemd-modules-load[210]: Failed to lookup alias 'nvhost_vi': Function not implemented
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Listening on LVM2 poll daemon socket.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Reached target Remote File Systems (Pre).
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Reached target Remote File Systems.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Mounted Debug File System.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Started Journal Service.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Started Create Static Device Nodes in /dev.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Failed to start Load Kernel Modules.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: systemd-modules-load.service: Unit entered failed state.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Started Remount Root and Kernel File Systems.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Started LVM2 metadata daemon.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Starting Load/Save Random Seed...
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Starting udev Coldplug all Devices...
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Mounting Configuration File System...
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Starting Apply Kernel Variables...
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Mounting FUSE Control File System...
Feb 11 16:28:00 tegra-ubuntu systemd-sysctl[225]: Couldn't write '1' to 'kernel/yama/ptrace_scope', ignoring: No such file or directory
Feb 11 16:28:00 tegra-ubuntu systemd-sysctl[225]: Couldn't write '1' to 'net/ipv4/tcp_syncookies', ignoring: No such file or directory
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Starting udev Kernel Device Manager...
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Starting Flush Journal to Persistent Storage...
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Mounted Configuration File System.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Mounted FUSE Control File System.
Feb 11 16:28:00 tegra-ubuntu systemd-udevd[228]: Network interface NamePolicy= disabled on kernel command line, ignoring.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Started Load/Save Random Seed.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Started Apply Kernel Variables.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Started Flush Journal to Persistent Storage.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Started udev Kernel Device Manager.
Feb 11 16:28:00 tegra-ubuntu systemd[1]: Started udev Coldplug all Devices.
Feb 11 16:28:01 tegra-ubuntu lvm[203]: /dev/mmcblk0rpmb: read failed after 0 of 4096 at 0: Input/output error
Feb 11 16:28:01 tegra-ubuntu lvm[203]: /dev/mmcblk0rpmb: read failed after 0 of 4096 at 4128768: Input/output error
Feb 11 16:28:01 tegra-ubuntu lvm[203]: /dev/mmcblk0rpmb: read failed after 0 of 4096 at 4186112: Input/output error
Feb 11 16:28:01 tegra-ubuntu lvm[203]: /dev/mmcblk0rpmb: read failed after 0 of 4096 at 4096: Input/output error
Feb 11 16:28:01 tegra-ubuntu systemd[1]: Started Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Feb 11 16:28:01 tegra-ubuntu kernel: cfg80211: World regulatory domain updated:
Feb 11 16:28:01 tegra-ubuntu kernel: cfg80211: DFS Master region: unset
Feb 11 16:28:01 tegra-ubuntu kernel: cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
Feb 11 16:28:01 tegra-ubuntu kernel: cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Feb 11 16:28:01 tegra-ubuntu kernel: cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Feb 11 16:28:01 tegra-ubuntu kernel: cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
Feb 11 16:28:01 tegra-ubuntu kernel: cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
Feb 11 16:28:01 tegra-ubuntu kernel: cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
Feb 11 16:28:01 tegra-ubuntu kernel: cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
Feb 11 16:28:01 tegra-ubuntu kernel: cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
Feb 11 16:28:01 tegra-ubuntu kernel: cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
Feb 11 16:28:01 tegra-ubuntu kernel: tegra-pcie 1003000.pcie-controller: link 1 down, retrying
Feb 11 16:28:01 tegra-ubuntu kernel: xhci-tegra 70090000.xusb: cannot find firmware....retry after 1 second
Feb 11 16:28:01 tegra-ubuntu systemd[1]: Found device /dev/ttyS0.
Feb 11 16:28:01 tegra-ubuntu systemd-udevd[250]: Could not generate persistent MAC address for ip6tnl0: No such file or directory
Feb 11 16:28:01 tegra-ubuntu systemd-udevd[240]: Could not generate persistent MAC address for dummy0: No such file or directory
Feb 11 16:28:01 tegra-ubuntu systemd-udevd[239]: Process '/usr/sbin/alsactl -E HOME=/run/alsa restore 0' failed with exit code 99.
Feb 11 16:28:01 tegra-ubuntu systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Feb 11 16:28:01 tegra-ubuntu systemd[1]: Reached target Sound Card.
Feb 11 16:28:01 tegra-ubuntu systemd[1]: Reached target Local File Systems (Pre).
Feb 11 16:28:01 tegra-ubuntu systemd[1]: Reached target Local File Systems.
Feb 11 16:28:01 tegra-ubuntu systemd[1]: Starting Clean up any mess left by 0dns-up...
Feb 11 16:28:01 tegra-ubuntu systemd[1]: Starting Set console keymap...
Feb 11 16:28:01 tegra-ubuntu systemd[1]: Starting LSB: AppArmor initialization...
Feb 11 16:28:01 tegra-ubuntu systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Feb 11 16:28:01 tegra-ubuntu systemd[1]: Starting Create Volatile Files and Directories...
Feb 11 16:28:01 tegra-ubuntu systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Feb 11 16:28:01 tegra-ubuntu systemd-tmpfiles[362]: [/usr/lib/tmpfiles.d/var.conf:14] Duplicate line for path "/var/log", ignoring.
Feb 11 16:28:01 tegra-ubuntu systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Feb 11 16:28:01 tegra-ubuntu kernel: random: nonblocking pool is initialized
Feb 11 16:28:01 tegra-ubuntu systemd[1]: Started Create Volatile Files and Directories.
Feb 11 16:28:01 tegra-ubuntu systemd[1]: Started Clean up any mess left by 0dns-up.
Feb 11 16:28:01 tegra-ubuntu systemd[1]: Started LSB: AppArmor initialization.
Feb 11 16:28:01 tegra-ubuntu systemd[1]: Starting Raise network interfaces...
Feb 11 16:28:01 tegra-ubuntu systemd[1]: Starting Network Time Synchronization...
Feb 11 16:28:01 tegra-ubuntu systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Feb 11 16:28:01 tegra-ubuntu loadkeys[354]: Loading /etc/console-setup/cached.kmap.gz
Feb 11 16:28:01 tegra-ubuntu systemd[1]: Started Set console keymap.
Feb 11 16:28:01 tegra-ubuntu systemd-timesyncd[389]: System clock time unset or jumped backwards, restoring from recorded timestamp: Fri 2016-05-06 05:40:13 UTC
May 06 05:40:13 tegra-ubuntu systemd[1]: Started Network Time Synchronization.
May 06 05:40:13 tegra-ubuntu systemd[1]: Time has been changed
May 06 05:40:13 tegra-ubuntu systemd[1]: Started Update UTMP about System Boot/Shutdown.
May 06 05:40:13 tegra-ubuntu systemd[1]: Reached target System Initialization.
May 06 05:40:13 tegra-ubuntu systemd[1]: Listening on GPS (Global Positioning System) Daemon Sockets.
May 06 05:40:13 tegra-ubuntu systemd[1]: Starting Socket activation for snappy daemon.
May 06 05:40:13 tegra-ubuntu systemd[1]: Listening on CUPS Scheduler.
May 06 05:40:13 tegra-ubuntu systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
May 06 05:40:13 tegra-ubuntu systemd[1]: Listening on RPCbind Server Activation Socket.
May 06 05:40:13 tegra-ubuntu systemd[1]: Started Daily Cleanup of Temporary Directories.
May 06 05:40:13 tegra-ubuntu systemd[1]: Started CUPS Scheduler.
May 06 05:40:13 tegra-ubuntu systemd[1]: Reached target Paths.
May 06 05:40:13 tegra-ubuntu systemd[1]: Listening on D-Bus System Message Bus Socket.
May 06 05:40:13 tegra-ubuntu systemd[1]: Reached target System Time Synchronized.
May 06 05:40:13 tegra-ubuntu systemd[1]: apt-daily.timer: Adding 11h 52min 10.085519s random time.
May 06 05:40:13 tegra-ubuntu systemd[1]: Started Daily apt activities.
May 06 05:40:13 tegra-ubuntu kernel: tegra-pcie 1003000.pcie-controller: link 1 down, retrying
May 06 05:40:13 tegra-ubuntu kernel: tegra-pcie 1003000.pcie-controller: link 1 down, ignoring
May 06 05:40:13 tegra-ubuntu kernel: tegra-pcie 1003000.pcie-controller: PCIE: no end points detected
May 06 05:40:13 tegra-ubuntu systemd[1]: Reached target Timers.
May 06 05:40:13 tegra-ubuntu kernel: tegra-pcie 1003000.pcie-controller: PCIE: Disable power rails
May 06 05:40:13 tegra-ubuntu systemd[1]: Listening on Socket activation for snappy daemon.
May 06 05:40:13 tegra-ubuntu systemd[1]: Reached target Sockets.
May 06 05:40:13 tegra-ubuntu systemd[1]: Reached target Basic System.
May 06 05:40:13 tegra-ubuntu systemd[1]: Starting Accounts Service...
May 06 05:40:13 tegra-ubuntu systemd[1]: Started D-Bus System Message Bus.
May 06 05:40:13 tegra-ubuntu systemd-udevd[244]: Process '/usr/sbin/alsactl -E HOME=/run/alsa restore 1' failed with exit code 99.
May 06 05:40:13 tegra-ubuntu systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
May 06 05:40:13 tegra-ubuntu systemd[1]: Starting Modem Manager...
May 06 05:40:13 tegra-ubuntu systemd[1]: Starting LSB: Speech Dispatcher...
May 06 05:40:13 tegra-ubuntu avahi-daemon[443]: Found user 'avahi' (UID 110) and group 'avahi' (GID 117).
May 06 05:40:13 tegra-ubuntu avahi-daemon[443]: Successfully dropped root privileges.
May 06 05:40:13 tegra-ubuntu systemd[1]: Starting NVIDIA specific first-boot script...
May 06 05:40:13 tegra-ubuntu avahi-daemon[443]: avahi-daemon 0.6.32-rc starting up.
May 06 05:40:13 tegra-ubuntu systemd[1]: Starting LSB: automatic crash report generation...
May 06 05:40:13 tegra-ubuntu systemd[1]: Starting Restore /etc/resolv.conf if the system crashed before the ppp link was shut down...
May 06 05:40:13 tegra-ubuntu avahi-daemon[443]: Successfully called chroot().
May 06 05:40:13 tegra-ubuntu avahi-daemon[443]: Successfully dropped remaining capabilities.
May 06 05:40:13 tegra-ubuntu avahi-daemon[450]: chroot.c: open() failed: No such file or directory
May 06 05:40:13 tegra-ubuntu avahi-daemon[443]: Failed to open /etc/resolv.conf: Invalid argument
May 06 05:40:13 tegra-ubuntu systemd[1]: Starting System Logging Service...
May 06 05:40:13 tegra-ubuntu avahi-daemon[443]: No service file found in /etc/avahi/services.
May 06 05:40:13 tegra-ubuntu systemd[1]: Started crash report submission daemon.
May 06 05:40:13 tegra-ubuntu avahi-daemon[443]: Network interface enumeration completed.
May 06 05:40:13 tegra-ubuntu avahi-daemon[443]: Server startup complete. Host name is tegra-ubuntu.local. Local service cookie is 3832014766.
May 06 05:40:13 tegra-ubuntu systemd-udevd[242]: Process '/bin/rm /var/lib/alsa/asound.state' failed with exit code 1.
May 06 05:40:13 tegra-ubuntu systemd[1]: Started Regular background program processing daemon.
May 06 05:40:13 tegra-ubuntu systemd[1]: Starting Permit User Sessions...
May 06 05:40:13 tegra-ubuntu ModemManager[444]: <info> ModemManager (version 1.4.12) starting in system bus...
May 06 05:40:13 tegra-ubuntu systemd[1]: Starting Network Manager...
May 06 05:40:13 tegra-ubuntu cron[463]: (CRON) INFO (pidfile fd = 3)
May 06 05:40:13 tegra-ubuntu systemd[1]: Started Run anacron jobs.
May 06 05:40:13 tegra-ubuntu dbus[435]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkitd.service'
May 06 05:40:13 tegra-ubuntu systemd[1]: Starting oFono Mobile telephony stack...
May 06 05:40:13 tegra-ubuntu systemd[1]: Starting Login Service...
May 06 05:40:13 tegra-ubuntu cron[463]: (CRON) INFO (Running @reboot jobs)
May 06 05:40:13 tegra-ubuntu anacron[472]: Anacron 2.3 started on 2016-05-06
May 06 05:40:13 tegra-ubuntu systemd[1]: Starting Save/Restore Sound Card State...
May 06 05:40:13 tegra-ubuntu systemd[1]: Started GPS (Global Positioning System) Daemon.
May 06 05:40:13 tegra-ubuntu systemd[1]: Started System Logging Service.
May 06 05:40:13 tegra-ubuntu anacron[472]: Will run job `cron.weekly' in 10 min.
May 06 05:40:13 tegra-ubuntu anacron[472]: Will run job `cron.monthly' in 15 min.
May 06 05:40:13 tegra-ubuntu anacron[472]: Jobs will be executed sequentially
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: oFono version 1.17
May 06 05:40:13 tegra-ubuntu ofonod[474]: oFono version 1.17
May 06 05:40:13 tegra-ubuntu systemd[1]: Started Restore /etc/resolv.conf if the system crashed before the ppp link was shut down.
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/plugin.c:__ofono_plugin_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/plugin.c:__ofono_plugin_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: Excluding RIL modem driver
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: Excluding BlueZ 5 Utils Plugin
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: Excluding External Hands-Free Profile Plugin
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: Excluding Hands-Free Audio Gateway Profile Plugins
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: No seats found
May 06 05:40:13 tegra-ubuntu ofonod[474]: Excluding RIL modem driver
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/system-settings.c:ofono_system_settings_driver_register() driver: 0x566158 name: Accounts Service System Settings
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: System does not support Android wakelocks.
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: plugins/smshistory.c:sms_history_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/history.c:ofono_history_driver_register() driver: 0x566070 name: SMS History
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: plugins/push-notification.c:push_notification_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: plugins/smart-messaging.c:smart_messaging_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: plugins/c-ares-dns-client.c:c_ares_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/dns-client.c:ofono_dns_client_driver_register() driver: 0x565f98 name: c-ares DNS client
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/sim-mnclength.c:ofono_sim_mnclength_driver_register() driver: 0x565708 name: MNC length
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/cdma-provision.c:ofono_cdma_provision_driver_register() driver: 0x5656b0 name: CDMA provisioning
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/gprs-provision.c:ofono_gprs_provision_driver_register() driver: 0x565658 name: Ubuntu APN database Provisioning
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/gprs-provision.c:ofono_gprs_provision_driver_register() driver: 0x565600 name: Provisioning
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/nettime.c:ofono_nettime_driver_register() driver: 0x5655a0 name: Network Time
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: plugins/upower.c:upower_init() upower init
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: plugins/dun_gw_bluez5.c:dun_gw_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x565320, name: ublox
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x565268, name: quectel
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: plugins/he910.c:he910_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x5651c0, name: he910
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: plugins/connman.c:connman_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/private-network.c:ofono_private_network_driver_register() driver: 0x565168, name: ConnMan Private Network
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x5650d0, name: sim900
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x565038, name: samsung
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564fa0, name: speedupcdma
May 06 05:40:13 tegra-ubuntu ofonod[474]: Excluding BlueZ 5 Utils Plugin
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564ef8, name: speedup
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564e60, name: alcatel
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564da8, name: icera
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564d10, name: linktop
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564c78, name: nokiacdma
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564be0, name: nokia
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564b48, name: cinterion
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564a30, name: ste
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564978, name: ifx
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x5648e0, name: palmpre
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564838, name: novatel
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x5647a0, name: sierra
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x5646a8, name: huawei
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564610, name: zte
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564548, name: hso
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x5644a0, name: mbm
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x5643f8, name: calypso
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564360, name: wavecom
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x5642c8, name: g1
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/cdma-voicecall.c:ofono_cdma_voicecall_driver_register() driver: 0x564218, name: cdmamodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_devinfo_driver_register() driver: 0x564268, name: cdmamodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/cdma-connman.c:ofono_cdma_connman_driver_register() driver: 0x5642a0, name: cdmamodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x5640d8, name: phonesim
May 06 05:40:13 tegra-ubuntu ofonod[474]: Excluding External Hands-Free Profile Plugin
May 06 05:40:13 tegra-ubuntu systemd[1]: Started Permit User Sessions.
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564140, name: localhfp
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x5640a8, name: phonesim
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/ctm.c:ofono_ctm_driver_register() driver: 0x564080, name: phonesim
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x564030, name: phonesim
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: plugins/phonesim.c:parse_config() filename /etc/ofono/phonesim.conf
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/ussd.c:ofono_ussd_driver_register() driver: 0x563ff8, name: speedupmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/voicecall.c:ofono_voicecall_driver_register() driver: 0x563d78, name: hfpmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_devinfo_driver_register() driver: 0x563ec0, name: hfpmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/network.c:ofono_netreg_driver_register() driver: 0x563e28, name: hfpmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/call-volume.c:ofono_call_volume_driver_register() driver: 0x563e90, name: hfpmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/handsfree.c:ofono_handsfree_driver_register() driver: 0x563f18, name: hfpmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/siri.c:ofono_siri_driver_register() driver: 0x563f88, name: hfpmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/network.c:ofono_netreg_driver_register() driver: 0x563c60, name: dunmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/gprs.c:ofono_gprs_driver_register() driver: 0x563ca8, name: dunmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/voicecall.c:ofono_voicecall_driver_register() driver: 0x563ac8, name: stemodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x563be0, name: stemodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x563b68, name: stemodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/voicecall.c:ofono_voicecall_driver_register() driver: 0x563888, name: ifxmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/audio-settings.c:ofono_audio_settings_driver_register() driver: 0x563938, name: ifxmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x563960, name: ifxmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x5639d0, name: ifxmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: Excluding Hands-Free Audio Gateway Profile Plugins
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/stk.c:ofono_stk_driver_register() driver: 0x563a20, name: ifxmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/ctm.c:ofono_ctm_driver_register() driver: 0x563a60, name: ifxmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x5637a8, name: hsomodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x5637e8, name: hsomodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/location-reporting.c:ofono_location_reporting_driver_register() driver: 0x563728, name: telitmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x563618, name: mbmmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/stk.c:ofono_stk_driver_register() driver: 0x563658, name: mbmmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/location-reporting.c:ofono_location_reporting_driver_register() driver: 0x563698, name: mbmmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/voicecall.c:ofono_voicecall_driver_register() driver: 0x5634e8, name: calypsomodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/stk.c:ofono_stk_driver_register() driver: 0x563588, name: calypsomodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/ussd.c:ofono_ussd_driver_register() driver: 0x5632f8, name: huaweimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/voicecall.c:ofono_voicecall_driver_register() driver: 0x563320, name: huaweimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/audio-settings.c:ofono_audio_settings_driver_register() driver: 0x5633c0, name: huaweimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x563428, name: huaweimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x5633e8, name: huaweimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/cdma-netreg.c:ofono_cdma_netreg_driver_register() driver: 0x563488, name: huaweimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x563208, name: iceramodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x563258, name: iceramodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x563158, name: ztemodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x5630d8, name: swmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: No seats found
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x563048, name: nwmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/voicecall.c:ofono_voicecall_driver_register() driver: 0x562d38, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_devinfo_driver_register() driver: 0x562e68, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/call-barring.c:ofono_call_barring_driver_register() driver: 0x562dd8, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/call-forwarding.c:ofono_call_forwarding_driver_register() driver: 0x5628e8, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/call-meter.c:ofono_call_meter_driver_register() driver: 0x562968, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/call-settings.c:ofono_call_settings_driver_register() driver: 0x562780, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/phonebook.c:ofono_phonebook_driver_register() driver: 0x562e38, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/ussd.c:ofono_ussd_driver_register() driver: 0x562cf0, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/sms.c:ofono_sms_driver_register() driver: 0x562860, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/sim.c:ofono_sim_driver_register() driver: 0x562b70, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/sim.c:ofono_sim_driver_register() driver: 0x562c00, name: atmodem-noef
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/stk.c:ofono_stk_driver_register() driver: 0x562ca0, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/network.c:ofono_netreg_driver_register() driver: 0x562a30, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/cbs.c:ofono_cbs_driver_register() driver: 0x5628b0, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/call-volume.c:ofono_call_volume_driver_register() driver: 0x562ec0, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/gprs.c:ofono_gprs_driver_register() driver: 0x562f20, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x562f50, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/sim-auth.c:ofono_sim_auth_driver_register() driver: 0x562f90, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/gnss.c:ofono_gnss_driver_register() driver: 0x562fd0, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x562390, name: gobi
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_devinfo_driver_register() driver: 0x562018, name: qmimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/system-settings.c:ofono_system_settings_driver_register() driver: 0x566158 name: Accounts Service System Settings
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/network.c:ofono_netreg_driver_register() driver: 0x5620e0, name: qmimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/voicecall.c:ofono_voicecall_driver_register() driver: 0x562050, name: qmimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/sim.c:ofono_sim_driver_register() driver: 0x562128, name: qmimodem-legacy
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/sim.c:ofono_sim_driver_register() driver: 0x5621b8, name: qmimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/sms.c:ofono_sms_driver_register() driver: 0x562248, name: qmimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/ussd.c:ofono_ussd_driver_register() driver: 0x562288, name: qmimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/gprs.c:ofono_gprs_driver_register() driver: 0x5622b0, name: qmimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x5622e0, name: qmimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x562310, name: qmimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/location-reporting.c:ofono_location_reporting_driver_register() driver: 0x562360, name: qmimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x561f40, name: u8500
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_devinfo_driver_register() driver: 0x561f08, name: u8500
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x561e70, name: n900
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x561dd8, name: isiusb
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_devinfo_driver_register() driver: 0x561930, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/phonebook.c:ofono_phonebook_driver_register() driver: 0x561910, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/network.c:ofono_netreg_driver_register() driver: 0x561968, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/voicecall.c:ofono_voicecall_driver_register() driver: 0x5619b0, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/sms.c:ofono_sms_driver_register() driver: 0x561a40, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/cbs.c:ofono_cbs_driver_register() driver: 0x561a80, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/sim.c:ofono_sim_driver_register() driver: 0x561aa8, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/ussd.c:ofono_ussd_driver_register() driver: 0x561b38, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: System does not support Android wakelocks.
May 06 05:40:13 tegra-ubuntu alsactl[491]: /usr/sbin/alsactl: load_state:1683: Cannot open /var/lib/alsa/asound.state for reading: No such file or directory
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/call-forwarding.c:ofono_call_forwarding_driver_register() driver: 0x561b60, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/call-settings.c:ofono_call_settings_driver_register() driver: 0x561ba0, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/call-barring.c:ofono_call_barring_driver_register() driver: 0x561c00, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/call-meter.c:ofono_call_meter_driver_register() driver: 0x561c30, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x561c80, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/gprs.c:ofono_gprs_driver_register() driver: 0x561cd0, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x561d00, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/audio-settings.c:ofono_audio_settings_driver_register() driver: 0x561d30, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/sim.c:ofono_sim_driver_register() driver: 0x561d48, name: wgmodem2.5
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: drivers/qcommsimmodem/qcom_msim_modem.c:qcom_msim_modem_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x561880, name: qcommsimmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: drivers/rilmodem/rilmodem.c:rilmodem_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_devinfo_driver_register() driver: 0x561458, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: drivers/rilmodem/sim.c:ril_sim_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/sim.c:ofono_sim_driver_register() driver: 0x5615f8, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/voicecall.c:ofono_voicecall_driver_register() driver: 0x5614d8, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: drivers/rilmodem/sms.c:ril_sms_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/sms.c:ofono_sms_driver_register() driver: 0x561688, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/network.c:ofono_netreg_driver_register() driver: 0x561490, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/call-volume.c:ofono_call_volume_driver_register() driver: 0x561568, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/gprs.c:ofono_gprs_driver_register() driver: 0x561598, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x5615c8, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: plugins/smshistory.c:sms_history_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/ussd.c:ofono_ussd_driver_register() driver: 0x5616c8, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/call-settings.c:ofono_call_settings_driver_register() driver: 0x5616f0, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/call-forwarding.c:ofono_call_forwarding_driver_register() driver: 0x561750, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x561790, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/call-barring.c:ofono_call_barring_driver_register() driver: 0x5617e0, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/phonebook.c:ofono_phonebook_driver_register() driver: 0x561820, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: drivers/mtkmodem/mtkmodem.c:mtkmodem_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/voicecall.c:ofono_voicecall_driver_register() driver: 0x561308, name: mtkmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/gprs.c:ofono_gprs_driver_register() driver: 0x561398, name: mtkmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x5613c8, name: mtkmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x5611e0, name: qcom_msim
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x561148, name: infineon
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x5610b0, name: mtk
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: plugins/udevng.c:udev_start()
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: plugins/udevng.c:enumerate_devices()
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/history.c:ofono_history_driver_register() driver: 0x566070 name: SMS History
May 06 05:40:13 tegra-ubuntu alsactl[491]: Found hardware: "tegra-hda" "Nvidia Tegra210 HDMI/DP" "HDA:10de0029,10de0101,00100100" "" ""
May 06 05:40:13 tegra-ubuntu alsactl[491]: Hardware is initialized using a generic method
May 06 05:40:13 tegra-ubuntu dbus[435]: [system] Activating via systemd: service name='org.freedesktop.Accounts' unit='accounts-daemon.service'
May 06 05:40:13 tegra-ubuntu ofonod[474]: plugins/push-notification.c:push_notification_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: plugins/smart-messaging.c:smart_messaging_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: plugins/c-ares-dns-client.c:c_ares_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/dns-client.c:ofono_dns_client_driver_register() driver: 0x565f98 name: c-ares DNS client
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/sim-mnclength.c:ofono_sim_mnclength_driver_register() driver: 0x565708 name: MNC length
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/cdma-provision.c:ofono_cdma_provision_driver_register() driver: 0x5656b0 name: CDMA provisioning
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/gprs-provision.c:ofono_gprs_provision_driver_register() driver: 0x565658 name: Ubuntu APN database Provisioning
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/gprs-provision.c:ofono_gprs_provision_driver_register() driver: 0x565600 name: Provisioning
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/nettime.c:ofono_nettime_driver_register() driver: 0x5655a0 name: Network Time
May 06 05:40:13 tegra-ubuntu ofonod[474]: plugins/upower.c:upower_init() upower init
May 06 05:40:13 tegra-ubuntu ofonod[474]: plugins/dun_gw_bluez5.c:dun_gw_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x565320, name: ublox
May 06 05:40:13 tegra-ubuntu alsactl[491]: Found hardware: "tegra-snd-t210r" "" "" "" ""
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x565268, name: quectel
May 06 05:40:13 tegra-ubuntu ofonod[474]: plugins/he910.c:he910_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x5651c0, name: he910
May 06 05:40:13 tegra-ubuntu ofonod[474]: plugins/connman.c:connman_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/private-network.c:ofono_private_network_driver_register() driver: 0x565168, name: ConnMan Private Network
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x5650d0, name: sim900
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x565038, name: samsung
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564fa0, name: speedupcdma
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564ef8, name: speedup
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564e60, name: alcatel
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564da8, name: icera
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564d10, name: linktop
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564c78, name: nokiacdma
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564be0, name: nokia
May 06 05:40:13 tegra-ubuntu nvfb-pre.sh[449]: update-alternatives: using /usr/lib/aarch64-linux-gnu/tegra-egl/ld.so.conf to provide /etc/ld.so.conf.d/aarch64-linux-gnu_EGL.conf (aarch64-linux-gnu_egl_conf) in auto mode
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564b48, name: cinterion
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564a30, name: ste
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564978, name: ifx
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x5648e0, name: palmpre
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564838, name: novatel
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x5647a0, name: sierra
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x5646a8, name: huawei
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564610, name: zte
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564548, name: hso
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x5644a0, name: mbm
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x5643f8, name: calypso
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564360, name: wavecom
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x5642c8, name: g1
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/cdma-voicecall.c:ofono_cdma_voicecall_driver_register() driver: 0x564218, name: cdmamodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_devinfo_driver_register() driver: 0x564268, name: cdmamodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/cdma-connman.c:ofono_cdma_connman_driver_register() driver: 0x5642a0, name: cdmamodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x5640d8, name: phonesim
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x564140, name: localhfp
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x5640a8, name: phonesim
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/ctm.c:ofono_ctm_driver_register() driver: 0x564080, name: phonesim
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x564030, name: phonesim
May 06 05:40:13 tegra-ubuntu ofonod[474]: plugins/phonesim.c:parse_config() filename /etc/ofono/phonesim.conf
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/ussd.c:ofono_ussd_driver_register() driver: 0x563ff8, name: speedupmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/voicecall.c:ofono_voicecall_driver_register() driver: 0x563d78, name: hfpmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_devinfo_driver_register() driver: 0x563ec0, name: hfpmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/network.c:ofono_netreg_driver_register() driver: 0x563e28, name: hfpmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/call-volume.c:ofono_call_volume_driver_register() driver: 0x563e90, name: hfpmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/handsfree.c:ofono_handsfree_driver_register() driver: 0x563f18, name: hfpmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/siri.c:ofono_siri_driver_register() driver: 0x563f88, name: hfpmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/network.c:ofono_netreg_driver_register() driver: 0x563c60, name: dunmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/gprs.c:ofono_gprs_driver_register() driver: 0x563ca8, name: dunmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/voicecall.c:ofono_voicecall_driver_register() driver: 0x563ac8, name: stemodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x563be0, name: stemodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x563b68, name: stemodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/voicecall.c:ofono_voicecall_driver_register() driver: 0x563888, name: ifxmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/audio-settings.c:ofono_audio_settings_driver_register() driver: 0x563938, name: ifxmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x563960, name: ifxmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x5639d0, name: ifxmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/stk.c:ofono_stk_driver_register() driver: 0x563a20, name: ifxmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/ctm.c:ofono_ctm_driver_register() driver: 0x563a60, name: ifxmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x5637a8, name: hsomodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x5637e8, name: hsomodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/location-reporting.c:ofono_location_reporting_driver_register() driver: 0x563728, name: telitmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x563618, name: mbmmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/stk.c:ofono_stk_driver_register() driver: 0x563658, name: mbmmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/location-reporting.c:ofono_location_reporting_driver_register() driver: 0x563698, name: mbmmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/voicecall.c:ofono_voicecall_driver_register() driver: 0x5634e8, name: calypsomodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/stk.c:ofono_stk_driver_register() driver: 0x563588, name: calypsomodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/ussd.c:ofono_ussd_driver_register() driver: 0x5632f8, name: huaweimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/voicecall.c:ofono_voicecall_driver_register() driver: 0x563320, name: huaweimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/audio-settings.c:ofono_audio_settings_driver_register() driver: 0x5633c0, name: huaweimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x563428, name: huaweimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x5633e8, name: huaweimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/cdma-netreg.c:ofono_cdma_netreg_driver_register() driver: 0x563488, name: huaweimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x563208, name: iceramodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x563258, name: iceramodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x563158, name: ztemodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x5630d8, name: swmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x563048, name: nwmodem
May 06 05:40:13 tegra-ubuntu speech-dispatcher[445]: * speech-dispatcher disabled; edit /etc/default/speech-dispatcher
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/voicecall.c:ofono_voicecall_driver_register() driver: 0x562d38, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_devinfo_driver_register() driver: 0x562e68, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/call-barring.c:ofono_call_barring_driver_register() driver: 0x562dd8, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/call-forwarding.c:ofono_call_forwarding_driver_register() driver: 0x5628e8, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/call-meter.c:ofono_call_meter_driver_register() driver: 0x562968, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/call-settings.c:ofono_call_settings_driver_register() driver: 0x562780, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/phonebook.c:ofono_phonebook_driver_register() driver: 0x562e38, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/ussd.c:ofono_ussd_driver_register() driver: 0x562cf0, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/sms.c:ofono_sms_driver_register() driver: 0x562860, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/sim.c:ofono_sim_driver_register() driver: 0x562b70, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/sim.c:ofono_sim_driver_register() driver: 0x562c00, name: atmodem-noef
May 06 05:40:13 tegra-ubuntu NetworkManager[469]: <info> [1462513213.3566] NetworkManager (version 1.2.0) is starting...
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/stk.c:ofono_stk_driver_register() driver: 0x562ca0, name: atmodem
May 06 05:40:13 tegra-ubuntu NetworkManager[469]: <info> [1462513213.3571] Read config: /etc/NetworkManager/NetworkManager.conf
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/network.c:ofono_netreg_driver_register() driver: 0x562a30, name: atmodem
May 06 05:40:13 tegra-ubuntu systemd[1]: Started LSB: Speech Dispatcher.
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/cbs.c:ofono_cbs_driver_register() driver: 0x5628b0, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/call-volume.c:ofono_call_volume_driver_register() driver: 0x562ec0, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/gprs.c:ofono_gprs_driver_register() driver: 0x562f20, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x562f50, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/sim-auth.c:ofono_sim_auth_driver_register() driver: 0x562f90, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/gnss.c:ofono_gnss_driver_register() driver: 0x562fd0, name: atmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x562390, name: gobi
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_devinfo_driver_register() driver: 0x562018, name: qmimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/network.c:ofono_netreg_driver_register() driver: 0x5620e0, name: qmimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/voicecall.c:ofono_voicecall_driver_register() driver: 0x562050, name: qmimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/sim.c:ofono_sim_driver_register() driver: 0x562128, name: qmimodem-legacy
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/sim.c:ofono_sim_driver_register() driver: 0x5621b8, name: qmimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/sms.c:ofono_sms_driver_register() driver: 0x562248, name: qmimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/ussd.c:ofono_ussd_driver_register() driver: 0x562288, name: qmimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/gprs.c:ofono_gprs_driver_register() driver: 0x5622b0, name: qmimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x5622e0, name: qmimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x562310, name: qmimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/location-reporting.c:ofono_location_reporting_driver_register() driver: 0x562360, name: qmimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x561f40, name: u8500
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_devinfo_driver_register() driver: 0x561f08, name: u8500
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x561e70, name: n900
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x561dd8, name: isiusb
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_devinfo_driver_register() driver: 0x561930, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/phonebook.c:ofono_phonebook_driver_register() driver: 0x561910, name: isimodem
May 06 05:40:13 tegra-ubuntu systemd[1]: Started Save/Restore Sound Card State.
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/network.c:ofono_netreg_driver_register() driver: 0x561968, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/voicecall.c:ofono_voicecall_driver_register() driver: 0x5619b0, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/sms.c:ofono_sms_driver_register() driver: 0x561a40, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/cbs.c:ofono_cbs_driver_register() driver: 0x561a80, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/sim.c:ofono_sim_driver_register() driver: 0x561aa8, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/ussd.c:ofono_ussd_driver_register() driver: 0x561b38, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/call-forwarding.c:ofono_call_forwarding_driver_register() driver: 0x561b60, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/call-settings.c:ofono_call_settings_driver_register() driver: 0x561ba0, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/call-barring.c:ofono_call_barring_driver_register() driver: 0x561c00, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/call-meter.c:ofono_call_meter_driver_register() driver: 0x561c30, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x561c80, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/gprs.c:ofono_gprs_driver_register() driver: 0x561cd0, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x561d00, name: isimodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/audio-settings.c:ofono_audio_settings_driver_register() driver: 0x561d30, name: isimodem
May 06 05:40:13 tegra-ubuntu NetworkManager[469]: <info> [1462513213.3717] manager[0x6e11a0]: monitoring kernel firmware directory '/lib/firmware'.
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/sim.c:ofono_sim_driver_register() driver: 0x561d48, name: wgmodem2.5
May 06 05:40:13 tegra-ubuntu NetworkManager[469]: <info> [1462513213.3718] monitoring ifupdown state file '/run/network/ifstate'.
May 06 05:40:13 tegra-ubuntu ofonod[474]: drivers/qcommsimmodem/qcom_msim_modem.c:qcom_msim_modem_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x561880, name: qcommsimmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: drivers/rilmodem/rilmodem.c:rilmodem_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_devinfo_driver_register() driver: 0x561458, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: drivers/rilmodem/sim.c:ril_sim_init()
May 06 05:40:13 tegra-ubuntu NetworkManager[469]: <info> [1462513213.3750] dns-mgr[0x6f58b0]: set resolv-conf-mode: dnsmasq, plugin="dnsmasq"
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/sim.c:ofono_sim_driver_register() driver: 0x5615f8, name: rilmodem
May 06 05:40:13 tegra-ubuntu NetworkManager[469]: <info> [1462513213.3751] dns-mgr[0x6f58b0]: using resolv.conf manager 'resolvconf'
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/voicecall.c:ofono_voicecall_driver_register() driver: 0x5614d8, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: drivers/rilmodem/sms.c:ril_sms_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/sms.c:ofono_sms_driver_register() driver: 0x561688, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/network.c:ofono_netreg_driver_register() driver: 0x561490, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/call-volume.c:ofono_call_volume_driver_register() driver: 0x561568, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/gprs.c:ofono_gprs_driver_register() driver: 0x561598, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/gprs.c:ofono_gprs_context_driver_register() driver: 0x5615c8, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/ussd.c:ofono_ussd_driver_register() driver: 0x5616c8, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/call-settings.c:ofono_call_settings_driver_register() driver: 0x5616f0, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/call-forwarding.c:ofono_call_forwarding_driver_register() driver: 0x561750, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x561790, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/call-barring.c:ofono_call_barring_driver_register() driver: 0x5617e0, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/phonebook.c:ofono_phonebook_driver_register() driver: 0x561820, name: rilmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: drivers/mtkmodem/mtkmodem.c:mtkmodem_init()
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/voicecall.c:ofono_voicecall_driver_register() driver: 0x561308, name: mtkmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/gprs.c:ofono_gprs_driver_register() driver: 0x561398, name: mtkmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/radio-settings.c:ofono_radio_settings_driver_register() driver: 0x5613c8, name: mtkmodem
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x5611e0, name: qcom_msim
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x561148, name: infineon
May 06 05:40:13 tegra-ubuntu ofonod[474]: src/modem.c:ofono_modem_driver_register() driver: 0x5610b0, name: mtk
May 06 05:40:13 tegra-ubuntu ofonod[474]: plugins/udevng.c:udev_start()
May 06 05:40:13 tegra-ubuntu ofonod[474]: plugins/udevng.c:enumerate_devices()
May 06 05:40:13 tegra-ubuntu nvfb-pre.sh[449]: update-alternatives: using /usr/lib/aarch64-linux-gnu/tegra/ld.so.conf to provide /etc/ld.so.conf.d/aarch64-linux-gnu_GL.conf (aarch64-linux-gnu_gl_conf) in auto mode
May 06 05:40:13 tegra-ubuntu dbus[435]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service'
May 06 05:40:13 tegra-ubuntu systemd[1]: Started Avahi mDNS/DNS-SD Stack.
May 06 05:40:13 tegra-ubuntu ofonod[474]: ofonod[474]: Failed to create system keep alive wakelock
May 06 05:40:13 tegra-ubuntu ofonod[474]: Failed to create system keep alive wakelock
May 06 05:40:13 tegra-ubuntu apport[451]: * Starting automatic crash report generation: apport
May 06 05:40:13 tegra-ubuntu systemd[1]: Started oFono Mobile telephony stack.
May 06 05:40:13 tegra-ubuntu systemd-logind[476]: New seat seat0.
May 06 05:40:13 tegra-ubuntu systemd[1]: Started Network Manager.
May 06 05:40:13 tegra-ubuntu systemd[1]: Started Login Service.
May 06 05:40:13 tegra-ubuntu systemd[1]: Starting Network Manager Script Dispatcher Service...
May 06 05:40:13 tegra-ubuntu systemd[1]: Starting Authenticate and Authorize Users to Run Privileged Tasks...
May 06 05:40:13 tegra-ubuntu systemd[1]: Started Make remote CUPS printers available locally.
May 06 05:40:13 tegra-ubuntu systemd[1]: Starting Light Display Manager...
May 06 05:40:13 tegra-ubuntu apport[451]: ...done.
May 06 05:40:13 tegra-ubuntu systemd[1]: Started LSB: automatic crash report generation.
May 06 05:40:13 tegra-ubuntu dbus[435]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
