Hi JerryChang,
Here is the log:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140 (root@ubuntu) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #77 SMP PREEMPT Tue Sep 17 07:16:00 PDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92cb3000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefd5000 s61592 r8192 d32616 u102400
[ 0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb3000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29412(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3562324K/4159488K available (15230K kernel code, 2912K rwdata, 6636K rodata, 8576K init, 611K bss, 122028K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f60000 ( 15232 KB)
[ 0.000000] .rodata : 0xffffff8008f60000 - 0xffffff80095e0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095e0000 - 0xffffff8009e40000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e40000 - 0xffffff800a118008 ( 2913 KB)
[ 0.000000] .bss : 0xffffff800a118008 - 0xffffff800a1b0dbc ( 612 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001354] Console: colour dummy device 80x25
[ 0.001374] console [tty0] enabled
[ 0.001392] kmemleak: Kernel memory leak detector disabled
[ 0.001412] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.001427] pid_max: default: 32768 minimum: 301
[ 0.001877] Security Framework initialized
[ 0.002095] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002106] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003267] ftrace: allocating 46960 entries in 184 pages
[ 0.174576] sched-energy: CPU device node has no sched-energy-costs
[ 0.174612] ASID allocator initialised with 65536 entries
[ 0.211153] tegra-id: chipid=22117.
[ 0.211167] tegra-id: opt_subrevision=0.
[ 0.211185] Tegra Speedo/IDDQ fuse revision 4
[ 0.211190] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.211195] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.211201] Tegra: CPU Speedo Value 2086, SoC Speedo Value 1972, GPU Speedo Value 2092
[ 0.211205] Tegra: CPU IDDQ Value 2184, SoC IDDQ Value 2448, GPU IDDQ Value 3085
[ 0.211224] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.211239] DTS File Name: /home/user/nano_32.2/public_sources/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.211247] DTB Build time: Sep 13 2019 00:34:49
[ 0.261072] CPU1: Booted secondary processor [411fd071]
[ 0.292997] CPU2: Booted secondary processor [411fd071]
[ 0.324972] CPU3: Booted secondary processor [411fd071]
[ 0.325064] Brought up 4 CPUs
[ 0.325071] SMP: Total of 4 processors activated.
[ 0.325079] CPU features: detected feature: 32-bit EL0 Support
[ 0.325340] CPU: All CPU(s) started at EL2
[ 0.325358] alternatives: patching kernel code
[ 0.333811] devtmpfs: initialized
[ 0.367956] Initilizing CustomIPI irq domain
[ 0.368344] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.368367] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.379776] pinctrl core: initialized pinctrl subsystem
[ 0.380462] OS set in device tree is not L4T.
[ 0.380892] regulator-dummy: no parameters
[ 0.381228] Initializing plugin-manager
[ 0.381341] Plugin module not found
[ 0.384631] NET: Registered protocol family 16
[ 0.386678] pstore: using zlib compression
[ 0.386712] console [pstore-1] enabled
[ 0.386717] pstore: Registered ramoops as persistent store backend
[ 0.386723] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.405093] cpuidle: using governor menu
[ 0.408692] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.410102] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e44000)
[ 0.410125] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.413605] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.415809] tegra_powergate_init: DONE
[ 0.415824] DTS File Name: /home/user/nano_32.2/public_sources/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.415831] DTB Build time: Sep 13 2019 00:34:49
[ 0.417220] Tegra reboot handler registered.
[ 0.421566] iommu: Adding device tegra-carveouts to group 0
[ 0.421706] platform tegra-carveouts: domain=ffffffc0f9b7d318 allocates as[0]=ffffffc0f9bd00a8
[ 0.422068] iommu: Adding device smmu_test to group 1
[ 0.422118] platform smmu_test: domain=ffffffc0f9b7d558 allocates as[0]=ffffffc0f9bd0110
[ 0.422927] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.422980] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.423035] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.423045] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.423067] mc-err: mcerr ops are set to t21x
[ 0.432292] iommu: Adding device 70090000.xusb to group 2
[ 0.432608] iommu: Adding device 70006000.serial to group 3
[ 0.432675] platform 70006000.serial: domain=ffffffc0f9b85c18 allocates as[0]=ffffffc0f9bd0178
[ 0.433131] iommu: Adding device 70006040.serial to group 4
[ 0.433379] iommu: Adding device 70006200.serial to group 5
[ 0.433562] iommu: Adding device sound to group 6
[ 0.433613] platform sound: domain=ffffffc0f9450198 allocates as[0]=ffffffc0f9bd01e0
[ 0.434163] iommu: Adding device 7000d400.spi to group 7
[ 0.434432] iommu: Adding device 7000d600.spi to group 8
[ 0.434758] iommu: Adding device 70410000.spi to group 9
[ 0.435050] iommu: Adding device 50000000.host1x to group 10
[ 0.435315] iommu: Adding device 54080000.vi to group 11
[ 0.435705] iommu: Adding device 54600000.isp to group 12
[ 0.435958] iommu: Adding device 54680000.isp to group 13
[ 0.436231] iommu: Adding device tegradc.0 to group 14
[ 0.436290] platform tegradc.0: domain=ffffffc0f94b90d8 allocates as[0]=ffffffc0f9bd0248
[ 0.440471] platform tegradc.0: IOVA linear map 0x0000000092cb3000(800000)
[ 0.440860] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.441241] iommu: Adding device tegradc.1 to group 15
[ 0.441289] platform tegradc.1: domain=ffffffc0f94b9318 allocates as[0]=ffffffc0f9bd02b0
[ 0.445451] platform tegradc.1: IOVA linear map 0x0000000092cb3000(800000)
[ 0.445851] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.446137] iommu: Adding device 54340000.vic to group 16
[ 0.446324] iommu: Adding device 544c0000.nvenc to group 17
[ 0.446513] iommu: Adding device 54500000.tsec to group 18
[ 0.446703] iommu: Adding device 54100000.tsecb to group 19
[ 0.446891] iommu: Adding device 54480000.nvdec to group 20
[ 0.447087] iommu: Adding device 54380000.nvjpg to group 21
[ 0.448121] iommu: Adding device 546c0000.i2c to group 22
[ 0.448444] iommu: Adding device 57000000.gpu to group 23
[ 0.448504] platform 57000000.gpu: domain=ffffffc0f94c8318 allocates as[0]=ffffffc0f9bd0318
[ 0.448563] platform 57000000.gpu: domain=ffffffc0f94c8318 allocates as[1]=ffffffc0f9bd0380
[ 0.448604] platform 57000000.gpu: domain=ffffffc0f94c8318 allocates as[2]=ffffffc0f9bd03e8
[ 0.448637] platform 57000000.gpu: domain=ffffffc0f94c8318 allocates as[3]=ffffffc0f9bd0450
[ 0.449550] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.449560] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.449571] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.449575] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.449580] tegra-pmc: ### PMC reset status reg: 0x3
[ 0.501269] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.501276] tegra-pmc: Clear bootloader IO dpd settings
[ 0.501298] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.501363] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.501653] iommu: Adding device 70012000.se to group 24
[ 0.502422] iommu: Adding device 7000c000.i2c to group 25
[ 0.502673] iommu: Adding device 7000c400.i2c to group 26
[ 0.502922] iommu: Adding device 7000c500.i2c to group 27
[ 0.503165] iommu: Adding device 7000c700.i2c to group 28
[ 0.503413] iommu: Adding device 7000d000.i2c to group 29
[ 0.503666] iommu: Adding device 7000d100.i2c to group 30
[ 0.503965] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.504028] platform sdhci-tegra.0: domain=ffffffc0f9540498 allocates as[0]=ffffffc0f9bd04b8
[ 0.504875] iommu: Adding device 700d0000.xudc to group 32
[ 0.508051] vdd-ac-bat: 5000 mV
[ 0.508403] vdd-5v0-sys: 5000 mV
[ 0.509371] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.509417] vdd-5v0-hdmi: 5000 mV
[ 0.509847] vdd-1v8-sys: 1800 mV
[ 0.510284] vdd-fan: supplied by vdd-5v0-sys
[ 0.510321] vdd-fan: 5000 mV
[ 0.510685] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.510715] vdd-usb-vbus: 5000 mV
[ 0.511210] vdd-usb-vbus2: 5000 mV
[ 0.537907] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.540661] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.541801] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.542204] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.550225] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.550587] SCSI subsystem initialized
[ 0.550825] libata version 3.00 loaded.
[ 0.551171] usbcore: registered new interface driver usbfs
[ 0.551218] usbcore: registered new interface driver hub
[ 0.551293] usbcore: registered new device driver usb
[ 0.555213] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.561132] vdd-core: 1000 <--> 1162 mV at 1075 mV
[ 0.561991] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.562062] random: fast init done
[ 0.564999] vdd-ddr-1v1: 1150 mV
[ 0.569098] vdd-pre-reg-1v35: 1350 mV
[ 0.572991] vdd-1v8: 1800 mV
[ 0.576992] avdd-sys-1v2: 1200 mV
[ 0.580988] vdd-pex-1v0: 1050 mV
[ 0.581560] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[ 0.582034] max77620-ldo3: at 3100 mV
[ 0.584995] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[ 0.585478] max77620-ldo5: at 3100 mV
[ 0.588991] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 2800 mV
[ 0.592997] avdd-1v05-pll: 1050 mV
[ 0.596992] avdd-io-hdmi-dp: 1050 mV
[ 0.598073] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.598342] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.599663] max77620 4-003c: max77620 probe successful
[ 0.602393] media: Linux media interface: v0.10
[ 0.602453] Linux video capture interface: v2.00
[ 0.603379] pps_core: LinuxPPS API ver. 1 registered
[ 0.603386] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.603407] PTP clock support registered
[ 0.606992] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.613182] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.613997] Advanced Linux Sound Architecture Driver Initialized.
[ 0.614645] Bluetooth: Core ver 2.22
[ 0.614696] NET: Registered protocol family 31
[ 0.614700] Bluetooth: HCI device and connection manager initialized
[ 0.614715] Bluetooth: HCI socket layer initialized
[ 0.614723] Bluetooth: L2CAP socket layer initialized
[ 0.614753] Bluetooth: SCO socket layer initialized
[ 0.616462] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.616478] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.616525] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.616539] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.619078] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.620133] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.620224] vdd-3v3-sys: 3300 mV
[ 0.620486] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.625053] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.625552] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.625608] vdd-3v3-sd: 3300 mV
[ 0.626414] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.626473] avdd-io-edp-1v05: 1050 mV
[ 0.626938] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.626987] vdd-usb-hub-en: 5000 mV
[ 0.628315] camchar: rtcpu character device driver loaded
[ 0.629056] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[ 0.630545] clocksource: Switched to clocksource arch_sys_counter
[ 0.671423] VFS: Disk quotas dquot_6.6.0
[ 0.671549] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.672034] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.672471] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.672490] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.672699] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.672704] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.672717] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.672745] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.672751] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.672764] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.672772] nvmap_page_pool_init: Total RAM pages: 1009365
[ 0.672778] nvmap_page_pool_init: nvmap page pool size: 126170 pages (492 MB)
[ 0.672870] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.673346] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.674249] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.682433] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.682883] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.683119] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.683318] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.683497] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.683776] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.683779] pre_t19x_iso_plat_init(): max_iso_bw=33280000KB
[ 0.684216] NET: Registered protocol family 2
[ 0.685193] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.685405] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.685940] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.686097] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.686178] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.686684] NET: Registered protocol family 1
[ 0.687405] RPC: Registered named UNIX socket transport module.
[ 0.687410] RPC: Registered udp transport module.
[ 0.687413] RPC: Registered tcp transport module.
[ 0.687416] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.687431] PCI: CLS 0 bytes, default 64
[ 0.687697] Trying to unpack rootfs image as initramfs...
[ 0.923953] Freeing initrd memory: 5432K
[ 0.933507] host1x 50000000.host1x: initialized
[ 0.935445] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.938733] audit: initializing netlink subsys (disabled)
[ 0.938807] audit: type=2000 audit(0.787:1): initialized
[ 0.939627] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.949645] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.951193] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.951990] 9p: Installing v9fs 9p2000 file system support
[ 0.955654] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.955812] io scheduler noop registered
[ 0.956106] io scheduler cfq registered (default)
[ 0.958865] gic 702f9000.agic: GIC IRQ controller registered
[ 0.961814] iommu: Adding device 702ef000.adsp to group 33
[ 0.968535] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.968709] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.969316] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x69a940f
[ 0.969326] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.971350] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.971448] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.971553] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.971738] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.971835] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.971920] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.972008] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.972092] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.972178] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.972260] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.977473] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.979094] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.980973] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.982259] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 0.982667] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 0.983928] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.984164] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 0.984415] Adding domain tsec-pd to PM domain host1x-pd
[ 0.986249] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 0.987123] tsec 54500000.tsec: initialized
[ 0.988660] tsec 54100000.tsecb: initialized
[ 0.989323] Adding domain nvdec-pd to PM domain host1x-pd
[ 0.992288] nvdec 54480000.nvdec: initialized
[ 0.993285] Adding domain vic03-pd to PM domain host1x-pd
[ 0.993464] Adding domain msenc-pd to PM domain host1x-pd
[ 0.993617] Adding domain nvjpg-pd to PM domain host1x-pd
[ 0.997116] falcon 54340000.vic: initialized
[ 0.998300] falcon 544c0000.nvenc: initialized
[ 0.999620] falcon 54380000.nvjpg: initialized
[ 1.004044] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.004162] display board info: id 0x0, fab 0x0
[ 1.004219] generic_infoframe_type: 0x87
[ 1.004356] tegradc tegradc.0: DT parsed successfully
[ 1.004407] tegradc tegradc.0: Display dc.ffffff800ab40000 registered with id=0
[ 1.004993] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[ 1.008128] tegradc tegradc.0: probed
[ 1.012514] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.016966] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 10 channels
[ 1.017877] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.018215] kfuse 7000fc00.kfuse: initialized
[ 1.019719] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.020790] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.022325] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.022342] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 1.022850] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.024220] vdd-gpu: applied init 1000000uV constraint
[ 1.024228] vdd-gpu: 708 <--> 1323 mV at 997 mV
[ 1.024644] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.029578] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.029752] No Device Node present for smmu client: serial8250 !!
[ 1.029773] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.029833] iommu: Adding device serial8250 to group 35
[ 1.033576] console [ttyS0] disabled
[ 1.033709] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.033883] console [ttyS0] enabled
[ 1.034939] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.035237] serial-tegra 70006200.serial: RX in PIO mode
[ 1.035330] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.036226] [drm] Initialized
[ 1.040314] Console: switching to colour frame buffer device 240x67
[ 1.040449] tegradc tegradc.0: fb registered
[ 1.042148] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.042226] tegradc tegradc.1: No lt-data, using default setting
[ 1.042255] tegradc tegradc.1: No hpd-gpio in DT
[ 1.042286] tegradc tegradc.1: DT parsed successfully
[ 1.042336] tegradc tegradc.1: Display dc.ffffff800d4c0000 registered with id=1
[ 1.044026] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.052112] brd: module loaded
[ 1.555257] Host read timeout at address 545c00c4
[ 1.555275] edid invalid
[ 1.557187] tegradc tegradc.1: probed
[ 1.565796] loop: module loaded
[ 1.565940] tegra_profiler: version: 1.134, samples/io: 47/26
[ 1.566095] tegra_profiler: auth: init
[ 1.568432] THERMAL EST: found 2 subdevs
[ 1.568447] THERMAL EST num_resources: 0
[ 1.568458] [THERMAL EST subdev 0]
[ 1.568469] [THERMAL EST subdev 1]
[ 1.569140] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.569143] THERMAL EST: thz register success.
[ 1.569451] THERMAL EST: end of probe, return err: 0
[ 1.571413] hisi_sas: driver version v1.6
[ 1.579908] tegra-qspi 70410000.spi: Prod settings list not found
[ 1.581228] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 1.581238] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 1.581424] tegradc tegradc.1: fb registered
[ 1.584336] libphy: Fixed MDIO Bus: probed
[ 1.584626] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.584634] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.584644] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.584665] tegradc tegradc.1: blank - powerdown
[ 1.584694] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.584699] Extcon DP: HPD disabled
[ 1.584703] hpd: hpd_switch 0
[ 1.584708] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.584717] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.584723] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.584967] tun: Universal TUN/TAP device driver, 1.6
[ 1.584971] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.586996] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.587004] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.587056] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.587060] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.587111] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.587115] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.587159] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.587162] Copyright(c) 1999 - 2017 Intel Corporation.
[ 2.090453] Host read timeout at address 5458045c
[ 2.090473] tegradc tegradc.0: blank - powerdown
[ 2.091614] PPP generic driver version 2.4.2
[ 2.092102] PPP BSD Compression module registered
[ 2.092108] PPP Deflate Compression module registered
[ 2.092160] PPP MPPE Compression module registered
[ 2.092168] NET: Registered protocol family 24
[ 2.092250] usbcore: registered new interface driver r8152
[ 2.092295] usbcore: registered new interface driver asix
[ 2.092351] usbcore: registered new interface driver ax88179_178a
[ 2.092394] usbcore: registered new interface driver cdc_ether
[ 2.092425] usbcore: registered new interface driver net1080
[ 2.092454] usbcore: registered new interface driver cdc_subset
[ 2.092486] usbcore: registered new interface driver zaurus
[ 2.092538] usbcore: registered new interface driver cdc_ncm
[ 2.092772] VFIO - User Level meta-driver version: 0.3
[ 2.094249] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.094272] ehci-pci: EHCI PCI platform driver
[ 2.094331] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.094371] ohci-pci: OHCI PCI platform driver
[ 2.094421] ohci-platform: OHCI generic platform driver
[ 2.097467] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 2.098110] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 2.099341] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f97b5800 id
[ 2.100527] usbcore: registered new interface driver uas
[ 2.100588] usbcore: registered new interface driver usb-storage
[ 2.100695] usbcore: registered new interface driver usbserial
[ 2.101752] tegradc tegradc.0: unblank
[ 2.105352] tegra-xudc-new 700d0000.xudc: device count: 1
[ 2.106742] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 2.106755] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 2.106771] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 2.106781] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 2.106804] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 2.107360] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-05-08 09:42:10 UTC, Version: 50.22 release
[ 2.107417] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 2.107442] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 2.107614] mousedev: PS/2 mouse device common for all mice
[ 2.107739] usbcore: registered new interface driver xpad
[ 2.108376] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 2.108439] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 2.108661] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.108667] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.108671] usb usb1: Product: xHCI Host Controller
[ 2.108675] usb usb1: Manufacturer: Linux 4.9.140 xhci-hcd
[ 2.108678] usb usb1: SerialNumber: 70090000.xusb
[ 2.109366] hub 1-0:1.0: USB hub found
[ 2.109421] hub 1-0:1.0: 5 ports detected
[ 2.110034] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 2.110045] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 2.110183] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.110288] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.110293] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.110297] usb usb2: Product: xHCI Host Controller
[ 2.110300] usb usb2: Manufacturer: Linux 4.9.140 xhci-hcd
[ 2.110303] usb usb2: SerialNumber: 70090000.xusb
[ 2.110774] hub 2-0:1.0: USB hub found
[ 2.110807] hub 2-0:1.0: 4 ports detected
[ 2.140019] tegradc tegradc.0: nominal-pclk:71000000 parent:71000000 div:1.0 pclk:71000000 70290000~77390000
[ 2.140119] tegradc tegradc.0: hdmi: tmds rate:71000K prod-setting:prod_c_hdmi_54m_75m
[ 2.141286] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 2.141303] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 2.176097] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 2.176100] Extcon AUX1(HDMI) enable
[ 2.176507] tegradc tegradc.0: sync windows ret = 250
[ 2.195031] extcon-disp-state extcon:disp-state: cable 40 state 1
[ 2.195035] Extcon HDMI: HPD enabled
[ 2.195064] tegradc tegradc.0: hdmi: plugged
[ 2.210629] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 2.210731] tegradc tegradc.0: read_edid_into_buffer: extension_blocks = 1, max_ext_blocks = 3
[ 2.226364] tegradc tegradc.0: hdmi_recheck_edid: read_edid_into_buffer() returned 256
[ 2.226371] tegradc tegradc.0: old edid len = 256
[ 2.226378] tegradc tegradc.0: hdmi: No EDID change. No userspace active. Using cached mode to initialize dc!
[ 2.237489] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.240140] rtc rtc1: alarm rtc device
[ 2.240160] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 2.240220] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 2.241001] i2c /dev entries driver
[ 2.243313] imx412 6-001a: imx412_probe(): Probing v4l2 sensor at addr 0x1a Sep 17 2019/07:15:45
[ 2.243320] imx412 6-001a: imx412_probe(): of_match_device() OK
[ 2.243327] imx412 6-001a: imx412_probe(): devm_kzalloc() OK
[ 2.243397] imx412 6-001a: imx412_parse_dt(): ...
[ 2.243485] imx412 6-001a: imx412_parse_dt(): mclk name not present, assume sensor driven externally
[ 2.252805] imx412 6-001a: imx412_parse_dt(): avdd, iovdd and/or dvdd reglrs. not present, assume sensor powered independently
[ 2.264530] tegradc tegradc.0: blank - powerdown
[ 2.266562] imx412 6-001a: imx412_parse_dt(): OK
[ 2.266664] [9281]: extract_pixel_format(): pixel_t=bayer_rggb size=10
[ 2.266670] [9281]: extract_pixel_format(): Result format=0x30314752 (RG10)
[ 2.266717] [9281]: extract_pixel_format(): pixel_t=bayer_rggb size=10
[ 2.266720] [9281]: extract_pixel_format(): Result format=0x30314752 (RG10)
[ 2.266771] imx412 6-001a: tegracam sensor driver:imx412_v2.0.6
[ 2.266776] imx412 6-001a: imx412_probe(): tegracam_device_register() OK
[ 2.266781] imx412 6-001a: imx412_power_on: power on
[ 2.308525] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 2.308529] Extcon AUX1(HDMI) disable
[ 2.334564] tegradc tegradc.0: unblank
[ 2.378246] tegradc tegradc.0: nominal-pclk:71000000 parent:71000000 div:1.0 pclk:71000000 70290000~77390000
[ 2.378321] tegradc tegradc.0: hdmi: tmds rate:71000K prod-setting:prod_c_hdmi_54m_75m
[ 2.379531] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 2.379545] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 2.400753] imx412 6-001a: imx412_board_setup(): VC FPGA found!
[ 2.400757] imx412 6-001a: [ MAGIC ] [ mipi-module ]
[ 2.400762] imx412 6-001a: [ MANUF. ] [ Vision Components ] [ MID=0x0427 ]
[ 2.400765] imx412 6-001a: [ SENSOR ] [ SONY IMX412 ]
[ 2.400770] imx412 6-001a: [ MODULE ] [ ID=0x0412 ] [ REV=0x0001 ]
[ 2.400774] imx412 6-001a: [ MODES ] [ NR=0x0002 ] [ BPM=0x0010 ]
[ 2.414490] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 2.414493] Extcon AUX1(HDMI) enable
[ 2.414951] tegradc tegradc.0: sync windows ret = 250
[ 2.422424] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.425391] extcon-disp-state extcon:disp-state: cable 40 state 1 already set.
[ 2.425395] Extcon HDMI: HPD enabled
[ 2.425403] tegradc tegradc.0: hdmi: plugged
[ 2.438557] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 2.475249] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 2.475258] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.475264] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 2.475268] usb 1-2: Manufacturer: Generic
[ 2.476995] hub 1-2:1.0: USB hub found
[ 2.478094] hub 1-2:1.0: 4 ports detected
[ 2.609075] imx412 6-001a: vc_mipi_reset(): sen_mode=0 err=0
[ 2.614812] imx412 6-001a: imx412_power_off: power off
[ 2.616894] imx412 6-001a: imx412_probe(): imx412_board_setup() OK
[ 2.616971] imx412 6-001a: imx412_probe(): tegracam_v4l2subdev_register() OK
[ 2.616977] imx412 6-001a: imx412_probe(): Detected imx412 sensor
[ 2.624745] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 2.628037] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 2.628045] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 2.628535] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.628554] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 2.628564] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 2.628697] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.628709] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 2.628717] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 2.628859] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.628871] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 2.628877] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 2.629051] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 2.629865] tegra_aotag tegra-aotag: Registering sensor 0
[ 2.629920] tegra_aotag tegra-aotag: Invalid temp readout
[ 2.629949] tegra_aotag tegra-aotag: Invalid temp readout
[ 2.629968] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 2.629978] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 2.631212] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.631234] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 2.631420] tegra_aotag tegra-aotag: Invalid temp readout
[ 2.631450] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 2.631844] parse_throttle_dt_data: Num cap clks = 6
[ 2.631851] parse_throttle_dt_data: clk=cclk_g type=2
[ 2.631867] parse_throttle_dt_data: clk=gpu type=4
[ 2.631892] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 2.631911] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 2.631932] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 2.631935] parse_throttle_dt_data: clk=emc type=3
[ 2.632343] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.632454] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.632589] tegra_throttle_probe: probe successful. #cdevs=4
[ 2.633379] FAN dev name: pwm-fan
[ 2.633440] FAN:gpio request success.
[ 2.633517] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 2.633829] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 2.634041] pwm_fan_driver pwm-fan: fan tach request irq success
[ 2.634051] pwm_fan_driver pwm-fan: tach period: 1000
[ 2.634159] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 2.634165] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 2.634171] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 2.634175] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 2.634181] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 2.634186] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 2.634190] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 2.634195] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 2.634200] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 2.634204] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 2.635611] device-mapper: uevent: version 1.0.3
[ 2.636173] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 2.641505] tegra210-cpufreq cpufreq: probe()...completed
[ 2.642203] sdhci: Secure Digital Host Controller Interface driver
[ 2.642205] sdhci: Copyright(c) Pierre Ossman
[ 2.642208] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.642702] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 2.643063] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 2.643191] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 2.648341] tegra-se 70012000.se: tegra_se_probe: complete
[ 2.648858] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.650013] usbcore: registered new interface driver usbhid
[ 2.650016] usbhid: USB HID core driver
[ 2.652177] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 2.652349] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 2.653998] nvpmodel: initialized successfully
[ 2.655092] usbcore: registered new interface driver snd-usb-audio
[ 2.655152] No Device Node present for smmu client: snd-soc-dummy !!
[ 2.655157] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 2.655178] iommu: Adding device snd-soc-dummy to group 36
[ 2.668115] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 2.685095] OPE platform probe
[ 2.685183] OPE platform probe successful
[ 2.685544] OPE platform probe
[ 2.685620] OPE platform probe successful
[ 2.694737] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 2.717489] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 2.717627] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 2.717755] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 2.717884] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 2.718021] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 2.718147] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 2.718281] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 2.718410] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 2.718558] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 2.718693] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 2.733269] u32 classifier
[ 2.733272] Actions configured
[ 2.733343] Initializing XFRM netlink socket
[ 2.734069] NET: Registered protocol family 10
[ 2.734801] NET: Registered protocol family 17
[ 2.734813] NET: Registered protocol family 15
[ 2.734890] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.734938] Bluetooth: RFCOMM socket layer initialized
[ 2.734948] Bluetooth: RFCOMM ver 1.11
[ 2.734953] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.734958] Bluetooth: HIDP socket layer initialized
[ 2.734977] 9pnet: Installing 9P2000 support
[ 2.735012] Key type dns_resolver registered
[ 2.735471] Registered cp15_barrier emulation handler
[ 2.735479] Registered setend emulation handler
[ 2.736509] registered taskstats version 1
[ 2.737045] Adding domain ve2-pd to PM domain host1x-pd
[ 2.737298] Adding domain ve-pd to PM domain host1x-pd
[ 2.739225] isp 54600000.isp: initialized
[ 2.740212] isp 54680000.isp: initialized
[ 2.751559] last reset is due to software reset
[ 2.751563] KERNEL: PMC reset status reg: 0x3
[ 2.751640] BL: PMC reset status reg: 0x3
[ 2.751642] BL: PMIC poweroff Event Recorder: 0x0
[ 2.753101] clk_cbus_recalc_rate: no gbus parent
[ 2.753107] clk_cbus_round_rate: no gbus parent
[ 2.753109] clk_cbus_round_rate: no gbus parent
[ 2.753114] clk_cbus_recalc_rate: no gbus parent
[ 2.753219] clk_cbus_recalc_rate: no gbus parent
[ 2.753223] clk_cbus_round_rate: no gbus parent
[ 2.753225] clk_cbus_round_rate: no gbus parent
[ 2.753229] clk_cbus_recalc_rate: no gbus parent
[ 2.753914] tegra_dvfs: GPU-cap: registered
[ 2.753968] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 2.753971] tegra dvfs: vdd-core: nominal 1075mV, offset 1000000uV, step 12500uV, scaling enabled
[ 2.753974] tegra dvfs: vdd-gpu: nominal 1048mV, offset 708000uV, step 10000uV, scaling enabled
[ 2.755342] tegra_dvfs: vdd-gpu-vts: registered
[ 2.755826] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 2.756524] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 2.757089] input: gpio-keys as /devices/gpio-keys/input/input1
[ 2.766553] usb 1-2.1: new high-speed USB device number 3 using tegra-xusb
[ 2.777783] tegra_rtc 7000e000.rtc: setting system clock to 2019-09-18 07:29:47 UTC (1568791787)
[ 2.778752] vi 54080000.vi: vi_probe: ++
[ 2.781465] vi 54080000.vi: initialized
[ 2.783489] vi 54080000.vi: subdev nvcsi--1 bound
[ 2.783504] vi 54080000.vi: subdev imx412 6-001a bound
[ 2.783705] imx412 6-001a: camera_common_g_fmt(): code=0x300f colorspace=8 w,h=4032,3040
[ 2.793385] usb 1-2.1: New USB device found, idVendor=05e3, idProduct=0608
[ 2.793390] usb 1-2.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.793394] usb 1-2.1: Product: USB2.0 Hub
[ 2.793653] Disable partitions left on by BL
[ 2.793656] disb
[ 2.793702] bwmgr: missing cdev-type property
[ 2.793795] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.793802] DRAM derating cdev registered.
[ 2.794606] hub 1-2.1:1.0: USB hub found
[ 2.794893] hub 1-2.1:1.0: 4 ports detected
[ 2.794915] vdd-fan: disabling
[ 2.794919] vdd-usb-vbus: disabling
[ 2.794921] vdd-usb-vbus2: disabling
[ 2.794931] vddio-sdmmc3-ap: disabling
[ 2.795081] avdd-io-edp-1v05: disabling
[ 2.795084] vdd-usb-hub-en: disabling
[ 2.795170] ALSA device list:
[ 2.795173] #0: tegra-hda at 0x70038000 irq 83
[ 2.795175] #1: tegra-snd-t210ref-mobile-rt565x
[ 2.798323] Freeing unused kernel memory: 8576K
[ 2.816679] L4T-INITRD Build DATE: Wed Sep 18 07:29:47 UTC 2019
[ 2.821230] Root device found: mmcblk0p1
[ 2.824590] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.907104] mmc0: hw tuning done ...
[ 2.907151] mmc0: new ultra high speed SDR104 SDXC card at address 0001
[ 2.907501] mmcblk0: mmc0:0001 EC2QT 59.6 GiB
[ 2.909216] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 3.025975] Found dev node: /dev/mmcblk0p1
[ 3.084525] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.085281] Rootfs mounted over mmcblk0p1
[ 3.086567] usb 1-2.1.3: new low-speed USB device number 4 using tegra-xusb
[ 3.112765] Switching from initrd to actual rootfs
[ 3.116500] usb 1-2.1.3: New USB device found, idVendor=046d, idProduct=c03e
[ 3.116505] usb 1-2.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.116509] usb 1-2.1.3: Product: USB-PS/2 Optical Mouse
[ 3.116512] usb 1-2.1.3: Manufacturer: Logitech
[ 3.120900] input: Logitech USB-PS/2 Optical Mouse as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1.3/1-2.1.3:1.0/0003:046D:C03E.0001/input/input2
[ 3.121131] hid-generic 0003:046D:C03E.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-70090000.xusb-2.1.3/input0
[ 3.198562] usb 1-2.1.4: new low-speed USB device number 5 using tegra-xusb
[ 3.235265] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 3.236165] usb 1-2.1.4: New USB device found, idVendor=04d9, idProduct=1203
[ 3.236171] usb 1-2.1.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.237283] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 3.247066] input: HID 04d9:1203 as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1.4/1-2.1.4:1.0/0003:04D9:1203.0002/input/input3
[ 3.306922] hid-generic 0003:04D9:1203.0002: input,hidraw1: USB HID v1.11 Keyboard [HID 04d9:1203] on usb-70090000.xusb-2.1.4/input0
[ 3.323171] input: HID 04d9:1203 as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1.4/1-2.1.4:1.1/0003:04D9:1203.0003/input/input4
[ 3.341980] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 3.341987] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 3.341990] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 3.341993] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 3.341997] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.342016] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 3.342075] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 3.342214] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.342330] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 3.342353] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 3.342382] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 3.342401] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 3.342550] pci 0000:01:00.0: supports D1 D2
[ 3.342553] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 3.354684] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 3.354711] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 3.354715] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 3.354721] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 3.354737] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 3.354752] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 3.354759] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 3.354762] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 3.354767] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 3.355011] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 3.355015] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 3.355020] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 3.355096] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 3.355260] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[ 3.355277] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 3.364586] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.369714] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 3.369728] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 3.377526] cgroup: cgroup2: unknown option "nsdelegate"
[ 3.386908] hid-generic 0003:04D9:1203.0003: input,hidraw2: USB HID v1.11 Device [HID 04d9:1203] on usb-70090000.xusb-2.1.4/input1
[ 3.400353] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.401100] systemd[1]: Detected architecture arm64.
[ 3.428682] systemd[1]: Set hostname to <user-desktop>.
[ 3.520052] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 3.520062] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 3.658087] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.658120] systemd[1]: Reached target Swap.
[ 3.658339] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.658464] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.658518] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.660119] systemd[1]: Created slice System Slice.
[ 3.660372] systemd[1]: Listening on udev Control Socket.
[ 3.660539] systemd[1]: Listening on Syslog Socket.
[ 3.709533] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 3.993743] systemd-journald[1914]: Received request to flush runtime journal from PID 1
[ 5.238662] imx412 6-001a: imx412_power_on: power on
[ 5.263331] imx412 6-001a: imx412_set_mode(): fmt_width,fmt_height=4032,3040 pix_fmt=0x30314752 'RG10', cam_mode=0
[ 5.283745] imx412 6-001a: imx412_set_mode(): err=0
[ 5.283754] imx412 6-001a: imx412_set_gain: Set gain = 256
[ 5.296714] imx412 6-001a: imx412_set_exposure(): exposure_time=10000000, EXP=0x1838
[ 5.315181] imx412 6-001a: --- imx412_start_streaming(): Dump sensor registers: ---
[ 5.337841] imx412 6-001a: --- Sensor ROI: x0,y0=0,0 x1,y1=4031,3039 dx,dy=4032,3040
[ 5.350393] imx412 6-001a: --- Sensor binning: bin_enb=0 bin_type=0x0 (bin_h=0 bin_v=0) ad_mode=0 line_len=0
[ 5.367892] imx412 6-001a: imx412_start_streaming(): err=0
[ 5.448512] random: crng init done
[ 5.448518] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.520114] imx412 6-001a: vc_mipi_reset(): sen_mode=0 err=0
[ 5.576113] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 5.580724] imx412 6-001a: imx412_stop_streaming(): err=0
[ 5.588363] imx412 6-001a: imx412_power_off: power off
[ 5.596015] imx412 6-001a: imx412_power_on: power on
[ 5.619364] imx412 6-001a: imx412_power_off: power off
[ 5.845343] using random self ethernet address
[ 5.855157] using random host ethernet address
[ 5.869157] Mass Storage Function, version: 2009/09/11
[ 5.869161] LUN: removable file: (no medium)
[ 5.877549] using random self ethernet address
[ 5.877551] using random host ethernet address
[ 5.977789] rndis0: HOST MAC 0e:2a:ab:00:91:ac
[ 5.977855] rndis0: MAC 0e:2a:ab:00:91:ad
[ 5.979117] usb0: HOST MAC 0e:2a:ab:00:91:ae
[ 5.979145] usb0: MAC 0e:2a:ab:00:91:af
[ 5.979539] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 5.984206] l4tbr0: port 1(rndis0) entered blocking state
[ 5.984212] l4tbr0: port 1(rndis0) entered disabled state
[ 5.984388] device rndis0 entered promiscuous mode
[ 5.998687] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 6.006892] l4tbr0: port 2(usb0) entered blocking state
[ 6.006897] l4tbr0: port 2(usb0) entered disabled state
[ 6.007356] device usb0 entered promiscuous mode
[ 6.014922] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 6.191950] android_work: did not send uevent (0 0 (null))
[ 6.229409] android_work: sent uevent USB_STATE=CONNECTED
[ 6.286317] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 6.286323] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 6.611675] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 6.646647] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 6.646654] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.646658] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 6.646661] usb 2-1: Manufacturer: Generic
[ 6.651169] hub 2-1:1.0: USB hub found
[ 6.653835] hub 2-1:1.0: 4 ports detected
[ 6.810587] usb 2-1: usb_suspend_both: status 0
[ 6.810753] usb usb2: usb_suspend_both: status 0
[ 10.917346] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.918441] eth0: 0xffffff800abbb000, 00:e0:4c:68:05:05, IRQ 405
[ 10.968714] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 11.137792] zram: Added device: zram0
[ 11.138243] zram: Added device: zram1
[ 11.140142] zram: Added device: zram2
[ 11.141460] zram: Added device: zram3
[ 11.156053] zram0: detected capacity change from 0 to 518590464
[ 11.200293] Adding 506432k swap on /dev/zram0. Priority:5 extents:1 across:506432k SS
[ 11.204158] zram1: detected capacity change from 0 to 518590464
[ 11.221875] Adding 506432k swap on /dev/zram1. Priority:5 extents:1 across:506432k SS
[ 11.225938] zram2: detected capacity change from 0 to 518590464
[ 11.239001] Adding 506432k swap on /dev/zram2. Priority:5 extents:1 across:506432k SS
[ 11.242445] zram3: detected capacity change from 0 to 518590464
[ 11.254348] Adding 506432k swap on /dev/zram3. Priority:5 extents:1 across:506432k SS
[ 12.868553] tegradc tegradc.0: blank - powerdown
[ 12.929331] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 12.929341] Extcon AUX1(HDMI) disable
[ 12.949643] tegradc tegradc.0: unblank
[ 12.961572] tegradc tegradc.0: nominal-pclk:71000000 parent:71000000 div:1.0 pclk:71000000 70290000~77390000
[ 12.961651] tegradc tegradc.0: hdmi: tmds rate:71000K prod-setting:prod_c_hdmi_54m_75m
[ 12.962680] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 12.962687] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 12.998666] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 12.998668] Extcon AUX1(HDMI) enable
[ 13.002202] tegradc tegradc.0: unblank
[ 13.002211] tegradc tegradc.1: blank - powerdown
[ 14.038622] r8168: eth0: link up
[ 14.038710] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 16.533797] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 16.533809] Bluetooth: BNEP socket layer initialized
[ 17.150154] fuse init (API version 7.26)
[ 18.258192] tegradc tegradc.0: unblank
[ 18.258203] tegradc tegradc.1: blank - powerdown
[ 36.328145] android_work: sent uevent USB_STATE=DISCONNECTED
[ 36.364984] android_work: sent uevent USB_STATE=CONNECTED
[ 36.384221] configfs-gadget gadget: high-speed config #1: c
[ 36.384251] tegra-xudc-new 700d0000.xudc: ep 5 (type: 3, dir: in) enabled
[ 36.384267] tegra-xudc-new 700d0000.xudc: ep 3 (type: 2, dir: in) enabled
[ 36.384283] tegra-xudc-new 700d0000.xudc: ep 2 (type: 2, dir: out) enabled
[ 36.384381] tegra-xudc-new 700d0000.xudc: ep 9 (type: 3, dir: in) enabled
[ 36.384396] tegra-xudc-new 700d0000.xudc: ep 7 (type: 2, dir: in) enabled
[ 36.384411] tegra-xudc-new 700d0000.xudc: ep 4 (type: 2, dir: out) enabled
[ 36.384544] tegra-xudc-new 700d0000.xudc: ep 15 (type: 3, dir: in) enabled
[ 36.384580] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 36.384608] tegra-xudc-new 700d0000.xudc: ep 11 (type: 2, dir: in) enabled
[ 36.384625] tegra-xudc-new 700d0000.xudc: ep 6 (type: 2, dir: out) enabled
[ 36.384866] android_work: sent uevent USB_STATE=CONFIGURED
[ 41.790906] l4tbr0: port 1(rndis0) entered blocking state
[ 41.790911] l4tbr0: port 1(rndis0) entered forwarding state
[ 41.792663] IPv6: ADDRCONF(NETDEV_UP): l4tbr0: link is not ready
[ 41.792690] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[ 87.509343] imx412 6-001a: imx412_power_on: power on
[ 87.532586] imx412 6-001a: imx412_set_mode(): fmt_width,fmt_height=4032,3040 pix_fmt=0x30314752 'RG10', cam_mode=0
[ 87.543690] imx412 6-001a: imx412_set_mode(): err=0
[ 87.543701] imx412 6-001a: imx412_set_gain: Set gain = 256
[ 87.549912] imx412 6-001a: imx412_set_exposure(): exposure_time=10000000, EXP=0x1838
[ 87.558905] imx412 6-001a: --- imx412_start_streaming(): Dump sensor registers: ---
[ 87.570625] imx412 6-001a: --- Sensor ROI: x0,y0=0,0 x1,y1=4031,3039 dx,dy=4032,3040
[ 87.579713] imx412 6-001a: --- Sensor binning: bin_enb=0 bin_type=0x0 (bin_h=0 bin_v=0) ad_mode=0 line_len=0
[ 87.591372] imx412 6-001a: imx412_start_streaming(): err=0
[ 87.808680] imx412 6-001a: vc_mipi_reset(): sen_mode=0 err=0
[ 87.865516] imx412 6-001a: imx412_stop_streaming(): err=0
[ 87.871193] imx412 6-001a: imx412_power_off: power off
[ 87.873480] imx412 6-001a: imx412_power_on: power on
[ 87.896799] imx412 6-001a: imx412_power_off: power off
[ 88.622989] imx412 6-001a: imx412_power_on: power on
[ 88.646201] imx412 6-001a: imx412_set_mode(): fmt_width,fmt_height=4032,3040 pix_fmt=0x30314752 'RG10', cam_mode=0
[ 88.657346] imx412 6-001a: imx412_set_mode(): err=0
[ 88.657354] imx412 6-001a: imx412_set_gain: Set gain = 256
[ 88.663293] imx412 6-001a: imx412_set_exposure(): exposure_time=10000000, EXP=0x1838
[ 88.671692] imx412 6-001a: --- imx412_start_streaming(): Dump sensor registers: ---
[ 88.682506] imx412 6-001a: --- Sensor ROI: x0,y0=0,0 x1,y1=4031,3039 dx,dy=4032,3040
[ 88.691587] imx412 6-001a: --- Sensor binning: bin_enb=0 bin_type=0x0 (bin_h=0 bin_v=0) ad_mode=0 line_len=0
[ 88.701855] imx412 6-001a: imx412_start_streaming(): err=0
[ 88.915407] imx412 6-001a: vc_mipi_reset(): sen_mode=0 err=0
[ 88.972149] imx412 6-001a: imx412_stop_streaming(): err=0
[ 88.977742] imx412 6-001a: imx412_power_off: power off
[ 88.980030] imx412 6-001a: imx412_power_on: power on
[ 89.003481] imx412 6-001a: imx412_power_off: power off
[ 89.010808] imx412 6-001a: imx412_power_on: power on
[ 89.034120] imx412 6-001a: imx412_power_off: power off
[ 89.080558] imx412 6-001a: imx412_power_on: power on
[ 89.103797] imx412 6-001a: imx412_power_off: power off
